Question about Garden
I have a 5hp B.& S. horizontal crankshaft engine that has started to flood badly. I suspect that the needle valve is stuck open but I don't see it. The carb. is mounted on top of the gas tank. How do I fix this, thanks.
  • 420 Answers
On models with the carburetor mounted on top of and part of the fuel tank do not have a float and needle valve. make sure the air cleaner bolt/screw is all the way in or else the engine will **** fuel through the threaded hole for it. If this is a different kind of carburetor let me know.
Posted on Jun 07, 2010
Injector sprays too much fuel after starting. Engine floods out
Suspect (potentially) either a stuck injector, or a failed/failing fuel pressure regulator. One sign of a failed fuel pressure regulator can be gas in the oil. (I suffered that side effect, along with bogging, and black smoke rich running, worsening as warmed up, turned out to be fuel pressure regulator). If the injector is loose in the throttle body, or has bad o-rings, can also cause some wonky behavior. Good luck.
Mar 14, 2015 | 1992 Geo Tracker
Gas leaks out side of pressure washer
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
Jul 27, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
What is causing my 12hp kohler engine to backfire and quit running when given any throttle?
That sounds like either bad (old) gasoline or the carburetor needs cleaning very badly - it's running very lean.
Jul 19, 2014 | Kohler Engine 12hp Cs Command Horizontal...
2003 Honda VTR 1000 SP-2 (RC51) dumping fuel out the exhaust
Hi, Anonymous and the usual suspects are:
1. Fouled spark plug.
2. Fuel injector stuck open.
3. Carburetor float needle valve, not seating.
4. Carburetor float stuck open.
5. Exhaust valve stuck open.
6. Exhaust valve bent.
7. Fuel valve leaking back through the vacuum line.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Gas coming out of exhaust help
Fule Dumping out of exhaust will not start
Honda VTR1000F Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VTR1000SP 2 Owners Manul
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 23, 2012 | 2003 Honda VTR 1000 SP-2 (RC51)
If I tilt engine side to side or front to back it smokes excessivly. Otherwise runs good no smoke
is the oil level overfull ?blueish smoke or the float level off and it's flooding black smoke blackish smoke
Apr 28, 2012 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
What's causing my 1986 accord lx carburetor engine to flood itself shortly after being turned off hot. it does it every time. the other thing is when i loosen the gas cap a ton of pressure is...
I would suspect the needle valve and seat in the carburetor bowl is sticking open thus allow fuel to flow into the intake which is flooding the engine.
Aug 09, 2011 | 1989 Honda Accord 4 Door
Starts but then floods and drips fuel out of carb
Sounds like you are getting too much fuel to the engine. The possible reasons are located inside of the carburetor.
1. the fuel needle valve is stuck open 2. the metering diaphragm is touching the fulcrum arm (attached to the needle) too soon {may need adjustment} 3. the check valves in the carburetor are stuck open and need to be cleaned.
I recommend contacting a dealer like www.arcolawn.com and having them price a whole carburetor. Sometimes they are cheaper than the rebuild parts. Good luck
Joe
Feb 15, 2011 | Homelite Factory Reconditioned 26cc...
Cannt start 360v/8 dodge cw two barrel Holley floods badly
your needle jets on the float may be sticking or could have come loose from its retainer pc.
Nov 08, 2008 | 1983 Plymouth Gran Fury
Garden Logo
51 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
