Question about Mitsubishi VS-45607 45" Rear Projection Television
What could be the problem?
My television (mitsubishi vs 4507ca 45" projection) one day after rolling blackouts turned off and never again was ABLE to turn back on. When the power button is pressed on the set itself, it tries to turn on, makes a click sound once, looks like the screen will turn on, then the screen turns back off and makes another click sound and thats it. everytime!
the click sound like it is comming from close to where the power cord connects to the television.
what may be the problem?
same thing, the vertical IC or regulator IC? if so how much do those things cost to repair, just so i dont get ripped off.
  • 121 Answers
If you have a tec do it will be beween 400 and 500 dollars all the parts you need are probably under 50 dollars if you would like I can post you a link where you can buy a service manual and they provide free tec support
Posted on Apr 12, 2008
Horizonal picture rolls
the pip location is on the bottom part of the remote
Apr 07, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi
This is a case of bad capacitors in the PIP (picture in picture) module. If you have any electronics repair experience, you should be able to do the repair yourself. Here is some more detailed instructions:
http://forum.eserviceinfo.com/viewtopic.php?p=59404#59404
Jan 15, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607 Vertical Hold Problem
Good Day; Just replace the caps first, 99.9% fix if not replace 9v regulator. Good Luck, big IRISH.
Nov 23, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Good Day, skieebumm;
There no adjustment. Try this: (MENU DOES NOT ROLL) CHECK C2A04, 10 UFD 50V OFF PIN 5 OF IC2A01 ON THE VIDEO PCB. 2. CHECK C2046, 47 UFD @ 50V OFF OF DL2001 ON THE VIDEO PCB. 3. (MENU DOES ROLL) CHECK C2B14 10 UFD @ 50 V NP OFF THE BASE OF Q2B02 ON THE VIDEO PCB. Good Luck, big IRISH.
Sep 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Vs-45607
Good Day, chefkenny;
This the fix ya you are looking for;
CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Aug 07, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi Big Screen VS-45607
probaly bad wiring or shorts in the wires or something is intefearing with your tv if it is wiring it might be a fire hazard
Feb 13, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607
Do self test first goto www.ctechnicians.com
Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi rear projection tv
I've worked on a few of these sets and have found C2P08 to cause something like rolling bars in the picture and have found C2P05 to cause lines jumping in the picture.
Feb 05, 2007 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi vs-4507ca
It just click ON and OFF, right? If you hear the hight voltage noise tring start, may be the Tv has bad vartical IC or regulator IC. If you have no experience with electronic you will need a technician to halp you.
Sep 11, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
