Question about Toshiba Computers & Internet
Shifted key operations not as normal or shown on keys, e.g. @ and '' transposed.
  • Toshiba Master
  • 6,993 Answers
its normal, its not all keyboard that has there "@" on number 2. Even the latest HP laptops that are produced these days have their @ on the same position like yours. You will find @ at the right side of the key board, near later "L".
Its normal, there is nothing to worry about because its not a fault. Just try to get use with the new changes.
Take care.
Posted on Jun 13, 2010
My Ketron Sd5 seems to play a different key on the right than on the left. For example if I play a beat in the key of G (left) the right hand side plays in A. Can you help?
You need to check your manual for instructions on key transpose. The right side has been transposed one key higher. If you don't have the manual, try resetting the instrument by removing the internal battery and reinstalling it. Good luck!
Aug 01, 2016 | Ketron SD5-61-Key Arranger Workstation...
How do i fix a Yamaha P95 that sounds Es with Fs and Bb with Bs across all the octaves?
Whether it happens to all of the key?
If yes, transpose setting may have changed. Change the setting to normal (0).
If the normal transpose, but tuning is still not standardized, check Pitch Setting.
To Restore Standard Pitch setting:
Hold down the A-1, B-1, C0 and C # 0 keys simultaneously and press any key between C3 and B3.
View image :
fix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-0.jpgfix-yamaha-p95-sounds-es-fs-bb-bs-across-vzw3qjj2ajjzgyoqcmqtppa4-4-1.jpg
If the above procedure is still no effect, try resetting the factory settings / Initialize overall: :
This is the steps:
Initializing the Settings
When you initialize the settings, all backup data stored to this instrument will be initialized and reset to the factory default settings.
Turn off the power to the instrument. Then, simultaneously hold down the C7 key (right-most key on the keyboard) and turn the power on again.
NOTICE
Do not turn off the power to this instrument while it is initializing the data in its internal memory (that is, while the button indicators are flashing).
View image:
Notes:
If this instrument somehow becomes disabled or malfunctions, turn off the power to the instrument, then perform the initialization procedure.
Sep 07, 2015 | Yamaha Music
I have a Roland E-70 Intelligent Synthesizer, buit the manual does not give instructions on how do transposition. I need to transpose the instrument to play a music in a lower key. For example, when I...
section 7 page 89 of the E-70 manual I downloaded from http://www.rolandus.com/support/owners_manuals/?group=2
describes the use of the transpose button.
In short, you set the value for the transpose function in the parameter menu (section 9 in the manual) ranging from -11 to +11 semitones.
In your case I would set the value for the tranpose button in the menu to minus 2 as you want a full note (= 2 semitones) down from C to B-flat and G to F etc.
And you activate or deactivate the transpose function itself by hitting the transpose button. The little red led next to the button shows whether the function is on (led is lit) or off (led is not lit).
Hope this helps
Mar 12, 2012 | Music
Why is my new EWI4000s must transpose to D to get the normal C key? When I turn off and TRANS BUTTON, the key is B.
Two things to check... check that the "tuning" is set to A440 as the adjustment range would reach a one note offset... Next check that the glide plate has not bent the pitch to the next note... If you are using MIDI, make sure the external device is not transposed on receive.
Sep 04, 2011 | Akai Ewi4000s Electronic Wind Instrument
The use of the Transposer control. I am very much a beginner in music in spite of my advanced years, and I have been puzzling over how to use this control. Would I be correct that all I need do is to...
A SIMPLE way of looking at the transposer is that it shifts EVERY key on the keyboard left (+) or right (-) by the number of the transpose. ALL keys, black and white are counted. As far as counting sharps and flats I would NOT depend on that. The transpose would for instance allow you to play a song you knew in "C" and have the sounds moved to a different key. For instance, a transpose of +2 would move EVERY C to "sounding" D, C# to D#, D# to F, E to F#, F to G, F# to G#, G to A, G# to A#, A to B, A# to C, and finally B would sound C# pitch. Given a key like G for a song that has one sharp (F#) to play this by keying it in the key of "C" you would use a transpose of +6 or minus 6. The number of key positions (including black) between the key you want to play in and the key the song is in. For a song in D that is played in C you would use either a +2 transpose or a -10 depending on whether you wanted the higher or lower octave to sound. Looking at it this way I do NOT believe the method you proposed would work... Look at it the way I described and you won't go wrong.
Jul 26, 2011 | Yamaha Music
I have Casio Ctk-496 and I have MIDI-USB wire. It all works, but Transpose button doesn't transpose and casio chord doesn't work with my computer. And all is still working even if I pull out IN wire from...
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Mar 30, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Software problem, my keyboard prs s500 have lost it key arrangement order ,where by now key f is found in key g, .please help me how to restore its arrangement
Look in your manual under "transpose". The transpose feature shifts the keys up or down often up to a full octave. This allows you to play in ANY music "key" you know and generate sound in a different one for say a vocalist who only sings in another...
Mar 25, 2011 | Yamaha Music
Keyboard seems to be stuck in key of D How do I get it back to C ?
On page 105 of your X5D manual, read up about "transpose". Setting the transpose shifts the notes plus or minus from the normal.
If you don't have a manual, you can download one for free.
Nov 13, 2010 | Korg X5d
Transpose feature on the Roland RD-600 digital piano
If you want to play in C and carry the sound of Bb,
1. From C, count down two half-steps to Bb
2. Press and hold the Transpose button and press the key on the keyboard that displays through the window, "-2"
3. To turn off the transpose feature, just press the Transpose button again.
Feb 23, 2009 | Roland Vs-2000CD Digital Studio...
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
