Question about Electrolux Garden
Removal of the clutch assembly from my partner Hedge Trimmer
How do I remove the clutch assembly from my Partner HG55-12 hedge trimmer so that I can replace the starter cord?
boscia
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
SOURCE: sharpen hedge trimmer blade??
My trick is to make sure that I always lube the blades after each session with a 3/4 engine oil + 1/4 kerosene mix - making sure that every tooth gets a drops or 2, then run it for a seconds to spread the oil & leave the blades overlapping. Doing this allows the blades to self sharpen I've found. 2 stroke oil , unmixed is about the perfect viscosity aswell.
Posted on Feb 18, 2010
philwalker78
  • 608 Answers
SOURCE: What is the spark plug gap on a Electrolux/Partner
Hi, the gap should be .8mm or 30 thou. Hope this helps, regards Phil.
Posted on May 31, 2011
SOURCE: craftsman hedge trimmer fuel line replacementa craftsman
My Sovereign SHT 26 hedge trimmer has a damaged fuel pipe which needs replacing; please advise
Posted on Jul 16, 2011
What spark plug do I buy for a partner hg55-12 hedge trimmer?? Mine is missing
Contact a retailer for this info. Also contact the factory customer support site online.
Jun 21, 2016 | Garden
I have a partner colibri strimmer. How do I lock the driveshaft to change the line spool head ?
You should have a small hole in the side of the head that a small rod goes in to lock it. Just line the holes up and stick the rod or a nail in there and it should be locked.
Jul 11, 2014 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
I need to replace the clutch that is screwed on to the end of the crankshaft on my Stihl HS 45 Hedge Trimmer. How do I get the old clutch off of the crank?
Remove the plug and insert a length of old pull cord into the hole, makin sure to leave some to pull it out with. Also making sure the piston is at bdc, you turn the clutch counter clockwise
Oct 26, 2013 | Stihl Hs45, Hs 45 Hedge Trimmer Bottom...
How to remove the clutch assembly on a stihl 015 AV
Remove spark plug.
Use a piston block to stop the piston rising.
Remove the chain sproclet cover.
Turn the clutch with a socket clockwise to undo.
Dec 11, 2012 | Stihl Chainsaw Hedge Trimmer Clutch 015 Av...
I need to find a replcement cap for the fuel tank for an Electrolux Partner HG22 hedge trimmer. Please help me find out where I can buy one! Thank you
sheesh , thats a tough one, I'm sure if you take the ccap to a local lawn mower repair ashop they can cross reference one for you
Jun 22, 2011 | Electrolux Garden
What is the spark plug gap on a Electrolux/Partner HG 550 petrol (Gasoline) hedge trimmer
May 31, 2011 | Electrolux Garden
I need to remove the clutch assembly from the shaft. Is there a special tool or technique I need to know about?
You will need to remove the bolt from the centre of the centrafugal clutch and remove it from the shaft with a flywheel puller. Good luck!
Aug 11, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
I'm having problems figuring out how to change or repair the string pull on a craftsman 22 inch gas hedge trimmer. It looks to me like you have to remove the clutch. How do you do that?
remove screws on both sides of plastic housings, remove spark plug, pull off plactic cap on the bottom side of the clutch plate. stick a wooden stick in that hole to keep the crank shaft from turning when you put an adjustabloe wrench on the clutch, unscrew clutch to get other half of housing off to get to the pull rope.
Jun 06, 2010 | Craftsman 22" Gas Hedge Trimmer
Garden Logo
108 people viewed this question
Top Electrolux Garden Experts
Phil Walker
Phil Walker
John
Are you an Electrolux Garden Expert? Answer questions, earn points and help others
