Question about Nokia 7610
My phone is hanging i cant operate it fast - Nokia 7610
It hangs when operate the keys fast
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
Aug 20, 2012 | Motorola Mobility ZN300 Cell Phone
Hang
remove the memory card for a day or two ,u will find that the phone is not hanging any more thats mean change the memory card
Just create a new profile and in that just change ur Keytone levels to zero. the device will never hang. It even works very fast. Actually the simultaneous operations of keytone sounds, the vibrations while clicking any icon jams the phone memory. hence the problem. For more stability also reduce the vibration level to low level.Its the hardware problem by nokia, because of insufficient internal memory.
Jan 09, 2012 | Nokia 5800 XpressMusic Smartphone
The speedometer bounces all over and i cant tell how fast i'm going
The speedometer cable needs to be oiled it is hanging inside of housing and when it comes loose it makes the speedometer jump up and down from cable hanging up inside of housing.
May 21, 2011 | Dodge Ram 3500 Cars & Trucks
My n73 hangs all the time... try to upgrade the phone software by following the nokia homepage instruction but seems the *#0000# doesn't open the options of downloads. think it might be locked by the...
The N73 runs on a Series60 operating software, which is a very advanced and multitasking software, that can run many applications and background and pop-up operations at the same time. So, this operating software require fast processor and high RAM (minimum requirements for good performance- 70 MB of RAM and 369 MHz processor). Unfortunately, the processor of N73 is too slow and the RAM is insufficient for multitasking. That's why, the processor and RAM is often overloaded and as a result it hangs. There's nothing you can do for this, but if you don't use too many programs at the same time, you might not face the problem. I recommend you to use a better task-manager like Handy Taskman and Jbak Taskman, which can show you the current status of your phone's RAM and allow you to manage active tasks. Handy Taskman can be downloaded from http://www.epocware.com , but it is not a freeware. So, you can download Jbak Taskman (for Symbian 9.x) from http://jbak.ru/jbaktaskman_en.php instead. Jbak Taskman is a freeware.
Aug 22, 2010 | Nokia N73 Cellular Phone
Hanging with my nokia 2630
hi, delete some applications you downloaded, pictures,etc on your phone so that your phone memory can have enough space to operate.
cheers
May 28, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
MY NOKIA N70 HAS HANGING PROBLEM PLEASE GIVE ME A SOLUTION.
Some good advice from someone who has been looking for this solution for many months, FORGET jumper solutions because you are just wasting your time with this and forget reheating the board as well.
I do not have a diagram to upload but those of you should know where the black bga chip is on the left hand side of the keypad system connector, that is all you have to replace, no jumpers needed. I have just finished my fourth N70 in this way, just change the chip and nothing else.
you can also find the chip on 6680 board.
Aug 01, 2009 | Nokia N70 Cellular Phone
I cant switch on my p990i phone.
Try power cycling the phone:
1. Remove the battery and leave it out for 5 to 10 minutes.
2. Put the battery back and turn the phone ON.
If you get the same problem, contact the manufacturer for possible firmware upgrade or repair.
Have a great day!
Jul 26, 2009 | Sony Ericsson P990i Smartphone
What to do when my iphone is hang? plz reply it
Connect your i phone to pc through folder option show hidden files alongwith system files and known file types you will get folder option in tools menu of any open folder. Check for any exe file delete it. If your phone hangs and unable to restart then simply take out the battery of your i phone.
Jun 19, 2009 | Apple iPhone Smartphone
Nokia 7610 Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
