Question about Sony KP-51HW40 51" Rear Projection Television
Sony KP-51HW40 Convergence issue
I am trying to determine the best solution to my problem with a convergence issue. when powered on the convergence is way out of whack. I can go into service mode to fix it but if it ever gets turned off, I have to go back in and manually make the adjustments to the whole screen and all the colors. I have heard that replacing the D-Board can be a simple fix for for a non-certified tech type. Are there others for a non-professional?
  • Sony Master
  • 8,617 Answers
Can you adjust the convergence by the convergence menu without going through the service menu? The settings through the convergence menu should save automatically. Have you replaced the convergence ICs? If so the settings should save, if not the D board will need to be replaced or at the very least rebuilt. Let me know if you need further assistance with this issue.
Posted on Apr 10, 2008
Distorted picture and color
This kind of problem occurs due to failure of convergence output ICs in Sony KP-51HW40 tv.
Replace convergence output ICs to solve tv problem.
This set uses two of the STK-392-570 IC chips for this (convergence problem)
Local tv repairman will do this job if you have no experience of electronics stuff repair.
Dec 22, 2010 | Sony KP-51HW40 51" Rear Projection...
Picture looks like a 3-d screen
Thanks.
Nov 12, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a sony kp-51hw40 that I just received
This problems also cause by the 2 STK convergence ICS and some or all it resistor are dead.Require changing the 2 STK convergence ICS and some or all it resistors will solved this fading out and shuting down.
Jul 11, 2010 | Sony KP-51HW40 51" Rear Projection...
Convergence problem, now there is a smell of burning,and the tv will not turn on
The bias resistors have smoked and also taken out the convergence ic's. Best advise, have a qualified tech diagnose it.
Jan 14, 2010 | Sony KP-51HW40 51" Rear Projection...
My colors wont stay converged
put a convergence repair kit in the set that will usually repair the Issue. You can get the Sony convergence repair kit which works with your model at the following link. The kits contain the replacement parts and complete instructions www.tvrepairkits.net
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Convergence issues on Sony KP-51HW40
you cant realign them they are factory set so you would need to replace them if the colors are out of line or you cant reset it manually. the tube are preset and not meant to be redajusted
Dec 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Intermittently convergence problem.
Try resoldering both convergence ICs located on the D board if that doesnt correct the problem you will need to replace both ICs let me know if I can assist you further.
Apr 04, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51 in. Rear Projection
If Flash Focus doesn't work,  change out convergence
IC's first ( STK392-560 X 2 ), then activate Flash Focus.
Can you please describe what you are seeing as a problem?
Then I will help with whatever you need.......T.
Nov 01, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40
I read it online that this is a very simple problem. It needs highvoltage splitter. I tried to open the front panel to see where the splitter is. However, I need some hint as to how to open the front panel. Good luck. Kiran
Feb 19, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
186 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
