Question about Dell E173FP 17" LCD Flat Panel Monitor
Hello, my dell 15'' flat screen moniter doeas not want to work. unlike us! LOL Any way the monitors green light comes on and thats it. no message, no error, just black death. help?
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder jopints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement bd: www.lcdrepair.us
Posted on Jun 07, 2010
Picture on for aprox. 2 s. Power led stays green. Same on several computers.
Posted on Sep 03, 2010
  • reirasr Sep 03, 2010
My dell monitor cuts off after minutes. the screen goes black and the green light shuts off after exactly 15 mins.
mines simler after 20mins goes of on its own mine got a build in power save mode that i cannot change think it eco settings i tryed display setting on pic moniter still does it videcs stat on and when i move my mouse it comes back mabe a auto stand buy setting
Feb 04, 2011 | Dell E173FP 17" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Moniter is only shows self test e173fpc
It sounds like your video card may be kaput. Can you try another monitor on it? If you use a monitor that you know works, and it does the same thing - then your video card has failed.
Alternately, you can try a different card and the same monitor.
Jun 08, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell 15 inch lcd monitor issue
The first thing you should do is change the monitor for another known working monitor to make sure it is the monitor that is faulty and not the video output of your computer.
Aug 03, 2008 | Dell E156FP 15" LCD Monitor
Monitor shuts off but green light stays on
I perhaps can. I would think inverter or ccfl's.
Jun 12, 2008 | Dell UltraSharp 2407WFP 24" LCD Monitor
Dell monitor E152fpb
The orange light means that the moitor is not seeing any signal. Make sure that the cable is in the correct position on the PC. If that is correct, try it on another PC to determine whether or not the monitor was damaged internally during moving or the PC is not sending out a video signal.
Dan
Mar 20, 2008 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Green led light flashing on 700p proview flat panel and no picture
Any high switching power supply of the same voltage and amperage rating will work for you. You may have to cut the end off of your old one and wire it to the new one to make it work but don't waste your money buying a specific power supply.
Good Luck!
Feb 16, 2008 | Computers & Internet
Dell E173FP 17" LCD Flat Panel Monitor Logo
354 people viewed this question
Alun Cox
