Question about Electrolux Freezers
Electrolux premier eco EU1070T circuit diagram
Electrolux premier eco EU1070T circuit diagram please
2 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Electrolux premier eco freezer leaking. Water
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help
Posted on Oct 11, 2009
How do I know when the ECO power switch is on or off?
check with the manufacturer's website. we have no idea as to your make/model
Jul 31, 2016 | Freezers
Wiring diagram for Electrolux RH06FD1F
I suggest that you try contacting their factory service help. They might be able to send you a print for it or tell you what to look for over the phone.
Jul 01, 2014 | Freezers
Where is the thermostat on my electrolux freezer (E32AF75FPS)?
Hi spazmodius, thank you for your post! This particular model has a thermistor to relay the temperature inside the unit to the Main Control Board. The thermistor is located behind the evaporator panel, to the right of the evaporator. I hope this information helps to some degree. If there is anything else that I can help you with, please feel free to reconnect!
Aug 03, 2013 | Electrolux E32AF75FPS Upright Freezer
Electrolux freezer only works on super
you should read the catalogue.
Mar 08, 2013 | Electrolux Freezers
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Stopped freezing, has power, compressor quiet
dear sir /madam
i think there is electrical trouble so please remove first electrical cord from main source then check any wire is remove or burn from it,s point ,if it,s then please contact to your maintenance personnel for repair it.
thank you
please vote!
Aug 28, 2010 | Electrolux Freezers
I have 660 hobby van and a electrolux fridge gas and electric, when you turn it on with electric nothing happens when you try gas i can hear it light but the fridge does not get cold please can you help
Hi , I am guessing this is a kind of RV. If it is, I am wondering if you just got it?? If you did just get it then I will say that those kinds of Refrigerators can take up to four hours to show good cooling. Just a thought. Wayne
May 21, 2010 | Electrolux Freezers
Exclaimation triangle red light is on - Electrolux CUU6174
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 07, 2010 | Electrolux 3.53 cu. ft. / 100 liter...
Hi there. I have Electrolux freezer EUU 6174. The problem is that the compressor is switching on and off for 5 seconds and the temperature is to hight. I can't store any food in the freezer. can u help me?
your problem is likely the starting capacitor .. that is a metalic part (about the size of a fist) that is mounted on the compressor or near it .. it will have wires going to the compressor .. the capacitors are not very expensive and usually easy to change but make sure the unit is unplugged .. you can either write the numbers down off the capacitor or remove it and take it with you to a parts place to get a match ... take a photo or draw a diagram so you know where the wires go .(they usually just plug in) . .. you can order one from electrolux (might be higher price) .. dont allow the unit to continue running with the bad starting cap since the compressor can be damaged eventually ... if you call a repairman .. then make sure you tell him its a bad starting cap so he can bring one wiith him and avoild a second trip .. give him the model number and numbers off the capacitor if you can ... often the capacitor is actually two capacitors in one can ... one is for the compressor and the other is hooked up to the fan ... in that case replacing one would also replace the other ..
Dec 23, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Electrolux premier eco freezer leaking. Water appearing on the floor. Ice building up inside the freezer.
Oct 11, 2009 | Freezers
Freezers Logo
82 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
