Question about Samsung Digimax 420 Digital Camera
My lens is zoomed out and wont close, is there a reset button or something to resolve this?
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jun 07, 2010
My Coolpix L320 was working fine, then all of a sudden got stuck with the lens zoomed all the way out and a message on the screen that says, "Turn the camera off, remove the lens cap, and turn the cam
after changing the battery and gently push back on the lens it should automatically close if not then check around it it must be something stuck in between it
Jan 18, 2015 | Nikon Coolpix L320 Black Digital Camera...
Hello please help in live view mode when i press the button to zoom 0x/5x/10/ the pic is very close in my LCD screen.my question is that when i am at 5x or 10x when i want to see my pics i have taken in...
The zoom button merely zooms in on the display. It magnifies a portion of the picture so you can get a better look at what you're about to photograph. LiveView or otherwise, if you want to zoom, you have use the zoom ring on your lens (assuming you're using a zoom lens in the first place, of course).
Nov 07, 2010 | Canon EOS 500D / Digital Rebel T1i Digital...
The zoom on the sb600 wont adjust accordingly to the zoom of my lens
Three things come to mind.
First, make sure that you are in fully automatic mode - easily done by reset (holding down "Mode" and "On/Off" at the same time. If you hit the "zoom" button it takes it out of automatic zoom and cycles through manual zoom settings until you get to auto again.
Second - make sure the camera is in an auto mode - manual mode could stop it from zooming.
Third - make sure that you don't have the diffuser pulled down. That can keep it from zooming also.
Mar 30, 2010 | Nikon Speedlight SB-600 TTL Flash
My zoom kens wont come out
If your lens fails to extend or retract, try cleaning it with a lint-free cloth and some lens solution. If it still won't move, try resetting it. Many cameras have reset buttons that restore the camera to the default factory settings.
hope this helps you
please do rate me on this issue
Dec 20, 2009 | Cameras
Zoom error showing on display screen of my daughters fuji finepix f40fd digital camera. Unable to press button to take photos and when I try to turn camera off the zoom lens goes in and out twice before...
The lens Is trying to close properly but the focus mechanism has a problem, most likely jammed, so the lens cannot correctly close or work properly.
It will need to be opened up and reset.
Please email me. My email address is listed in my tips section on my profile.
Aug 28, 2009 | Fuji FinePix F40fd Digital Camera
Lens wont come out
Try Power Resetting the Camera which should resolve the issue.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persits after Power Resetting the Camera service of the Camera is recommended.
Jun 15, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
Zoom lens wont close
Sounds like you broke a lens gear, or it is jammed with sand.
Nov 17, 2008 | Cameras
It wont turn on, And the zoom is extended.
I had exactly the same problem. Lens stayed open, when powered on you get three beeps and nothing. I found when I pulled the lens out a little harder it gave a little click. When I powered on it worked perfectly.
Nov 25, 2007 | Samsung Digimax S800 Digital Camera
Blurry Pictures!!!:(
This is something that will probably have to be sent in to be fixed. First try resetting your camera. In REC mode press menu go to setup tab go up to reset press right arrow highlight reset & press set. If that doesn't work send it in to repairs.
Jul 10, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Casio wont take pictures
That lens error msg means that you need to send it in. There is no resetting that you can do to fix that. Call the repairs center at 800-706-2534 and then keep choosing option 1. Tell them what's going on and that you would like to send it in for repairs. If they ask just lie and tell them you already talked to tech support. LOL
Jun 15, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Samsung Digimax 420 Digital Camera Logo
55 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
