Siemens gigaset se587 4 port wireless router will not connect to my computer. Error code 106 keeps comming up. any solutions?
  • 86 Answers
Go into 'control panel' then 'network connections' and right click on your 'local area connection'. Select 'internet protocol' at the bottom of the list and click on 'properties'. Ensure that 'Obtain an IP address automatically' is selected. Run through the installation disk again and my guess is it will work. Despite this being relatively simple no one at tiscali suggested this over the course of 2 weeks which I found astonishing.
Posted on Apr 10, 2008
Find se567 manual
Try this link
http://setuprouter.com/router/siemens/gigaset-se567/manual-1055.pdf
Dec 05, 2012 | Siemens Gigaset Se567 54 Mbps 4-port...
How can i configure siemens gigaset 504 agu for bsnl broadband connection
Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Search siemens gigaset 504
They have very easy setup instructions
http://etisalatsupport.blogspot.com/2012/07/siemens-gigaset-504-router.html
Save file for next time.
http://www.etisalat.ae/eportal/en/images/docs/userguides/modem&drivers/Setup-ADSL-Siemens504AGU.pdf
Oct 25, 2012 | Computers & Internet
Wireless LAN not active
loptop not connect to router as wireless
Oct 11, 2009 | Siemens Efficient Networks SpeedStream...
Error when connecting usb wireless adapter
hi there, windows vista, as we all know is more focused on to the security... but it becomes very difficult if it detects other devices as an error...
With vista you can try to run the installation CD for the router, so that the vista knows that there is a driver for that router, without that it will not recognize the router and will keep detecting as an error...
was i helpful?
for more help log on to http://primustel.blogspot.com
Nov 18, 2008 | Computers & Internet
Gigaset se568 siemens wireless Security setting
i have a little problem with my siemens gigaset SE568, here all led lights are glowing except the internet, i checked my net connection with another modem and the result was positive but what is the problem here i can't figure out,please help me,rahat
Jul 27, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens 4200 2 computers
Yes and No! The 4200 gives you the option to connect via USB or Ethernet. You can only use one or the other to connect. You have two options. The first DOES involve another "gadget". The second does not!
Solution #1
I realize you're not looking to use additional equipment, but a network hub, switch or router will give you what you need. You can pick up a very inexpensive router for under $50 or even better a wireless router for a few bucks more.
I recommend a Linksys Wireless Router (Model - WRT54G) as it is very user friendly and comes ready to use. Just connect the port labeled "Ethernet" to the "WAN" port of the Linksys Wireless Router. Then connect both of your computers to any of the four "LAN" ports.
Solution #2
You can connect the first computer directly to the 4200 via USB and connect the second computer directly to the first computers ethernet port using a Network Crossover cable. Without a router of hub between the two computers, a crossover cable is required to allow them to talk to each other.
Once you have them connected to each other, on the first computer open the network connection properties for your internet connection (will be the one setup during the install of the USB modem) and click "Share This Computers Internet Connection".
Now the first option is surely the most reliable and keeps the traffic separate.
Hope this help!
Jul 20, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Siemens gigaset se587 wlan dsl wpa
You can try this link, this has a step by step instruction and screen shots as well. I hope this one helps.
http://portforward.com/english/routers/wireless/Siemens/Gigaset-SE587/wireless.htm
May 04, 2008 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
Error 106
the ipaddress of the router may not be 192.168.1.1 it should say somewhere on the router or the documentation
if you are suing DHCP to allocate the IP address, and the router is set as a DHCP server you should be able to see the ipaddress using whatever tools Apple give on settign up networks.
I think there is possibly something wrong with your telephone line setup check that no phone is connected unless its through a adsl filter, or you have an adsl socket on the master socket in the house. The fact that you are not getting the online light to light up suggests to me that the router isn't talking ADSL network. consider removing ALL phones temporarily and see if that helps...
you should be able to PING an IP Address, again I don't know how youd do that on a MAC, hate 'em personally.
usually all you need to know are the IP address of the gateway (the router). set the DNS to the same IP address, unless Tiscali advise otherwise
the ADSL filters should only remove the hissing noise on the telephone line, so after plugging in the filter the phone should work as normal..
Apr 29, 2008 | SMC EZ Connect Wireless Networking Starter...
Computers & Internet Logo
301 people viewed this question
David Payne
David Payne
