Question about Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4
What is the flow rate of this pump/minute? Tsurumi Pump Model 80BA21.5 Bore 80 3fase 380-415V 50hz
    Problem Solver:
  • 18 Answers
1000 Litter per minute
265 Gallon per minute
www.tsurumi-europe.com
Hope i help you
regards
TsurumiMan
Everywhere Always
Posted on Jul 29, 2010
Davey XJ70 pumps bore water but flow dwindles when garden hose attached thus requiring pump to be turned off to stop burn out. Marc
possible it is a jet pump that has a return hose back to the foot valve to assist the pump to lift the bore water higher to work the pump
if that is the case ,when you turn on the tap on the pressure to the lift jet is reduced and so the pump cannot lift the water from the bore --it runs out of water
the fix here is to restrict the flow out of the tap so that jet pressure is maintained--- don't turn the tap on more than 1 turn
the reason is the lift height is too great ,indicating that the bore water level is lower than it normally is
Feb 22, 2017 | Water Garden
PLACEMENT CAPACITOR FOR A TSURUMI PUMP MODEL HS2.4S WHERE CAN I BUY ONE?
being that this us a sump pump that goes in the water you need to take it to a pump rebuilding company. so that new seal are put in. I would never do a repair even on a cord to a sump pump for that reasonl. Never what to know that I made a mistake that killed someone.
Please take the pump to a company that does that. Look in the old fashion yellow pages or on line for someone close to you
Thanks and be safe
Tom
Sep 08, 2011 | Tsurumi Pump s Submersible Water Pump ...
Tsurumi pump 40pu2.15s my pump only humming and stop pumping water. what is the cause?
Most likely cause is a blocked impeller. Disconnect from power supply, remove pump from sump, take off pump base to expose impeller and check for freedom of rotation. If all appears OK and pump still just hums it could be a blown capacitor - unless you really know what you are doing I suggest you employ an experienced expert to proceed further. Where are you located?
Mike Goody
Jul 19, 2011 | Tsurumi Pump Plumbing
How much hydralic does 2"
What do you mean by Hydralic?
there is no hydraulic oil in it,
and its a Honda gas engine,
Jan 03, 2011 | Tsurumi Pump Tsurumi Diaphragm Pump 120cc...
My Tsurumi 50pn2.4s has a bad bearing. Where can i buy bearings and seals?
Probably any bearing store will have the right one,but you will need a mechanical seal from a Tsurumi pump Distributor,
www.tsurumipump.com
Jul 21, 2010 | Tsurumi Pump s Submersible Trash Pump -...
No problem just looking for a parts book on a tsurumi lb3-750 sub
Here is a breakdown of the pump. The contact number is at the bottom right of the page.
http://www.uco.no/Global/Bruksanvisninger/Pumper/synkepump_642422-232_br.anv.pdf
Website http://www.Tsurumi-Europe.com
Hopefully this will help you locate your parts.
Thanks for using FixYa,
Kelly
May 04, 2010 | Tsurumi Pump s Submersible Water Pump ...
Tsurumi submersible pump with a bad bearing.
Mostly likely no.. These pumps have a sealed bearing that can not be serviced.
Apr 17, 2010 | Tsurumi Pump s Submersible Trash Pump -...
Tsurumi submersible vancs series pond pump has
To get a new owner manual send them an email and they will email or send you one,
info@tsurumiamerica.com
Is the pump was working fine for a long time before that happen?
if yes
There is a motor problem,
You can check your pump power cable try to find any damage or hole in it.
If the cable fine
And if the impeller and wheel still turn before triping the breaker It would be a good thing to check the amperage with a special electronic tool to see how much amperage the pump take,
or
if you are good in manipulating tool we can send you the breakdown or i can support you to open it and to check the motor trying to find any burn part in it. That way we will know right away if its worth to fix it.
let me know
Jun 09, 2009 | Tsurumi Pump s Submersible Trash Pump -...
Service manual /equivalent oil requirement
I do believe that this motor running without any oil, i am not to familliar with this particular model, all the Tsurumi model that i know run with air ''magnet'' insulate motor,
Please check with our head office
www.tsurumiamerica.com
Hope it help you
TsurumiMan
Everywhere Always
Dec 05, 2008 | Tsurumi Pump 2x25 Blk Pond Flex Hose
Tsurumi Pump s Submersible Trash Pump - 3000 GPH, 1/2 HP, 2in., Model# HS2.4 Logo
131 people viewed this question
Top Tsurumi Pump Plumbing Experts
Donni Steen
Tom Chichester
Are you a Tsurumi Pump Plumbing Expert? Answer questions, earn points and help others
