Question about Navigon 2100 Portable GPS Receiver
MY NAVIGION O/S Windows CE5 got corrupted. I accidentally deleted some partition in its ROM. How to restore it please?
    Brigadier General:
  • 4,090 Answers
The only way to restore it is to return it to the manufacturers representative. Not all of CE5 is installed, only certain parts of it and unless you know what parts and how to follow the correct sequence you will be going around in circles forever. bite the bullet and take it to the professionals.
Please rate my help++++Thanks for using FIXYA
Posted on Jun 07, 2010
What can I do to rescue data deleted by pressing "Shift+ Delete" on Windows 7?
Using Shift+Delete to remove files/folders bypasses the recycle bin which is your normal means of recovering accidentally deleted files. You can go to download.com and search for file recovery programs. Some are available that will search your hard drive and can maybe recover what you lost. It is important to do so as quickly as possible because once files are permanently deleted on the hard drive, the sectors that they occupied are no longer protected and can be overwritten by any program or file.
Dec 25, 2014 | Computers & Internet
Windows partition tool to repair windows drive
Try this:
http://www.stellarinfo.com/windows-data-recovery.php
It'll works best against all cases of data loss and will recover files exactly in the state it was before deletion.
May 05, 2014 | Avanquest Fix-It Utilities 8 Professional:...
How can i recover my files when i accidentally formatted my drive d twice
The only chance you have is to find a free "undeleete" program and try to recover as much as possible.
Afterformatting a harddrive and later installationof Windows you cant expect to recover that much as - If the position where the file wasstored is owerwritten by windows files - recovery is not possible. If I were you - forget it - bu as mentioned there is a chance to recover some of the files. Search via google for Undeleete program (free) - or by a proper program.
Regards
Feb 17, 2012 | Intel Computers & Internet
Recover partition format
Did you want to recover formatted partitiom or recover the format (or called file sytem,such as NTFS and FAT32) of partition?
You can recover formatted partition with partition recovery program.I have succeed with Tenorshare data recovery.It can recover partition after deeply scanning your hard drive to look for lost data you accidentally formatted.You can get it here:http://www.any-data-recovery.com
If you want to recover the file system of partition,you can copy your data into a portable device and then transfer the file system of partition.
May 30, 2011 | Computers & Internet
Trying to restore XP back to Factory Status. Have Trojan Horse (placed in 'Chest)'. No Documentation CD but have all nec specs. What to do with Restore Disc? Have Operating System CD. Ta!
If u want it to factory status then u need to reformat
Insert the Windows XP CD-ROM into your CD-ROM drive or DVD-ROM drive, or insert the first Windows XP Setup boot disk into the floppy drive disc if you are starting from Setup boot disks, and then restart the computer.
NOTE: To start your computerfrom the Windows XP CD-ROM or from the Setup boot disk, your computer must be configured to start from the CD-ROM drive or DVD-ROM drive or the floppy disk drive.
In some cases, you may have to modify your computer's BIOS settings to do this.
(If you are starting from the Windows XP Setup boot disks, insert each of the additional disks when you are prompted, and then press ENTER to continue after inserting each disk.)
At the Welcome to Setup page, press ENTER to continue.
Press F8 to accept the Windows XP Licensing Agreement.
If an existing Windows XP installation is detected, you are prompted to repair it. Press ESC (do not repair).
All existing partitions and unpartitioned spaces are listed for each physical hard disk. Use the arrow keys to select the partition or space where you want to create a new partition, and then press D to delete an existing partition or press C to create a new partition using unpartitioned space.
If you press D to delete an existing partition, you must then press L (or press ENTER, and then press L if it is the System partition) to confirm that you want to delete the partition. Repeat this process for each of the existing partitions that you want to use for the new partition.
When all the partitions are deleted, you can then select the resulting unpartitioned space and then press C to create the new partition.
Type the size (in megabytes, or MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition using the maximum size.
If you want to install Windows XP, use the arrow keys to select the partition you want to install Windows XP on, and then press ENTER.
Select the format option that you want to use for the partition, and then press ENTER. The options are:
  • Format the partition by using the NTFS file system (Quick)
  • Format the partition by using the FAT file system (Quick)
You may also see:
  • Leave the current file system intact (no changes)
Most people will want to choose: "Format the partition by using the NTFS file system".
After Setup formats the partition, follow the on-screen instructions to continue Setup until Windows XP fully installs.
Oct 18, 2008 | HP Computers & Internet
Windows could start because the following file is missing or corrupt: system 32/drivers/pci.sys
Hello:
You can try repairing the installation of windows.
You need a windows installation disk or system recovery disk.
insert the disk in the CD/DVD RoM
boot your pc from the cd rom.
the system will prompted you repair , press r and then select the 1 or 2(most probably 1)
supply password of the administrator. if no password strike enter
Type: chkdsk /r then strike enter
the system will check and restore.
wait until completed.
If incase its a recovery disk:
boot your pc in the cd rom
the recovery disk you got to option;
either ; you partition and format the entire disk
or leave the current file only the system will be deleted and restore the new system( Something like that)
you have to decide either of the two option. you can try each option:
all of that will be corrected by installation of new windows: windows installation method is here: http://support.microsoft.com/kb/316941
may this help,
melnavz
Sep 11, 2008 | Computers & Internet
Navigon 2100 Portable GPS Receiver Logo
206 people viewed this question
Top Navigon GPS Experts
Will Halftowaite
Are you a Navigon GPS Expert? Answer questions, earn points and help others
