Question about Acer Aspire E500 PC Desktop
Acer aspire e500 back fan
I have a acer aspire e500
i removed the fan on the back of the unit for replacement and now have forgotten which why it goes does it **** air in or blow air out
    Brigadier General:
  • 4,090 Answers
The fan blows air to the outside of the box
Please rate my help++++Thanks for using FIXYA
Posted on Jun 07, 2010
I have an acer e500 tower wont boot a cable from what looks like the front panel near on switch is disconnected from motherboard and i dont know where it fits
Should be an input that says pwr or pwr sw on the motherboard. Really the power switch input is usually 2 pin and the only one on the mobo.
Sep 20, 2012 | Acer Aspire E500 PC Desktop
Aspire e500. The power button is not working, it does not feel like it is hitting a connection. I am a beginner at this. Does anyone no how to fix in simple terms
look where your power cable plugs in the back of your comp[uter and make sure the power switch is turned on for your power supply if you have one.
Jan 29, 2011 | Acer Aspire E500 PC Desktop
Very noisy fan
You can try using caned air. turn off and unplug the computer then used the caned air on the fan to blow out any dust. plug it back in and power it on and see if the fan is any quieter. If not then it could be that the fan is going bad and may need to be replaced. Most computers will have a coupl of fans, case fans, CPU heatsink fans, videocard fans, power supply fans, so you will probably need to open the case up to get to all of them and make sure they are clean.
Apr 12, 2010 | Acer Aspire E500 PC Desktop
PC start up failer
  1. remove the two rear screws and remove all the cards attached to the main board
  2. unplug all the cables that connect from the drives to the board.
  3. power on the unit
  4. if the unit powers up, install one of the cards you removed and complete step 3
  5. if the system does not power up, the last card or device activated will be your culprit and will need to be replaced or left out.
if you find that your system will not show a bios splash screen with all the other components removed, then you are looking at either a video, or power supply failure. Listen to your system for spinning fans and hdd activity. touch the hdd if you cant hear it when you power up the system, paying close attention to when the drive activates. It should activate almost immediatley, pause, and then run for a short boot period. if nothing, then if may be your power supply. you will not be able to see any lights at all, no light on the motherboard, drives, or power LED is the best indicator of a shot power supply
Good luck, please rate this post
Mar 23, 2010 | Acer Aspire E500 PC Desktop
Dear Sir, I have this Desktop Acer model: E500-H34, Aspire E500, P/no: AS.S32000.006GE, Mfg: 220805 have some problem from my brother. The problem is when I switch on the power and press the 'ON' button...
Reconnect all cable to motherbord
Refix RAM .
Pull cmos cell for 10 minutes then all motherbord settings are defaults.
Also pull processsor fan and processor refix both.
then check .
If still same issue then your motherbord is faulty.
If it is in warrenty then use warrenty otherwise you have to repair it .
Aug 24, 2009 | Computers & Internet
Display problem for my acer aspire e500 desktop
contact ACER customer care... for updating display driver.....
Jul 30, 2009 | Acer Aspire E500 PC Desktop
Unlocking bios password
to reset the bios simply remove the battery (looks like a watch battery) on the motherboard and then replace it again.
Or try this site for more advice
Hope this helps
Oct 31, 2008 | Acer Aspire SA20 PC Desktop
Acer aspire e500 won't turn on
Check that all the power supply units are switched on( Wall Plug, UPS, CPU), If all is ok and the problem exists, replace the CMOS battery.( if the sys works replace your CMOS Battery, configure the cmos settings also)
Jan 03, 2008 | E-Machines T1360 PC Desktop
Acer Aspire E500 PC Desktop Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
