Question about Whirlpool LSN1000LW Top Load Washer
Fails to start, but when you bang lid down, program begins
  • 5,911 Answers
You need to check your lid switch. This is the most common cause of the problem you are experiencing. Symptoms may include, filling and stopping on the intial fill cycle, stopping right after the wash cycle, not advancing to rinse or spin cycles, and a wash tub that will not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
IMPORTANT: SLAMMING THE WASHER LID IS NOT RECOMMENDED AND CAN ACTUALLY CONTRIBUTE TO THE PREMATURE FAILURE OF THE LID SWITCH, LID STRIKE AND/OR CAUSE THE LID TO BECOME MISHAPENED OR BOWED.
If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Jun 07, 2010
    Brigadier General:
  • 4,090 Answers
Check the switch on the lid That may be faulty and need replacing
Please rate my help++++Thanks for using FIXYA
Why is lid not locking?
Replace the lid lock. If you post a model number I can give you a part number. Over time lid locks sometimes wear out over time( most of them are 90% plastic). Lid locks should be relatively inexpensive. Also if this is a top load washer you can replace it yourself instead of hiring someone.
Aug 13, 2017 | Fisher and Paykel Washing Machines
GE top loading washer turns off by itself
How about a lid switch. Try pushing down on lid to restart.
May 10, 2010 | GE WBSR3140DW Top Load Washer
Water leak from top drawer. Had F1 flood alarm
Top right corner: it means the bad right actuator could not pull down the lid seal on that side causing a leak. The actuators are sold in pair. They are not expensive. Replace both of them when you order them in. Need to inspect the rubber seal around the top lid since if it is distorted another 60 bucks to get a new lid for replacement also. The new lid comes with the york to engage with the actuators.
May 08, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Kenmore top load washer- have to bang lid several
This is most certainly caused by a faulty micro switch on the lid. Have the switch checked out and replaced if need be.
Best wishes,
Graemevm
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer works fine till it gets to the spin cycle, makes very loud bang bang bang like it's going to blow up, did find two brass pins under the balance plates in a small cup that it droped down into, lined...
those are shipping pins pull them back out,check the tub springs,also the triangle the tub sits on has 3 pads it rides on check them also,somebody has bypassed the lid switch,it's ok,let me know what you find-mike
Apr 29, 2009 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore top load washing machine model #110.24422300 that is only 4 years old, I have done 1 or 2 small or medium loads each week. My problem is that at the beginning once the water is filled it...
Very good chance that the lid switch has failed. This is the switch that is pushed down by the lid itself upon its closure. Try pushing the switch down manually with a pen, or something small and see if it works.
Mar 14, 2009 | Washing Machines
Washer Doesn't move from cycle to cycle
this washer has a problem with the lid hinge screws coming loose. check the left hand hinge and you will find the screws loose.
this cause the lid switch to not engage and then nothing will happen until it thinks the lid is closed.
try to tighten the screws and listen to see if the switch "clicks" when you open and close the lid.
that should fix it until the screws come loose again.
Jan 30, 2009 | Whirlpool LSR6334LQ Top Load Washer
Maytag Atlantis MAV6200 fills but doesn't do anything afterwards
If nothing turns on than your Lid Switch is probably it.It is the first most common fix on this model. Please Rate This !!!
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer won't start. It was giving me problems for over 2 years where I would have to occassionally bang on it to get it to start or start betw. cycles. It runs great if it starts.
sounds ike a ppossibl elid switch issue, this machine wont do much of anything with out a proper workin lid switch ( banging on the lid ususally tripps the switch
Apr 03, 2008 | Washing Machines
Kenmore 80 series washer wont rinse/spin
I fixed the same problem by using this site: http://forum.doityourself.com/archive/index.php/t-156215.html
Mar 17, 2008 | Washing Machines
Whirlpool LSN1000LW Top Load Washer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
