Question about Epson AcuLaser C1900 Printer
Error code E021 service required, this is the error i get periodically with my epson acculaser c1900 printer
  • 32 Answers
SOURCE: service require E008
E008. Is a Main Motor Problem.
Main Motor, Engine, power unit
E021. Transfer Belt Cleaner Contanct/ Rease Problem.
Cleaner pressure flapper solenoid, Belt cleaner detect sensor, engine PCB.
Make sure inside on unit, has no toner spilled in it.
Posted on Feb 15, 2008
clusterfx
  • 67 Answers
SOURCE: Service Call e021
I believe that is a dirty sensor error message.
Posted on Feb 23, 2008
  • 14 Answers
SOURCE: Worn Photoconductor Epson C1900 laser Printer
hi this solution has already been covered in full lengths. Epson c900 and c1900 are similar. have a look at my posting on this. photoconductor reseting by Labatt in this forum. read from the start.
http://www.fixya.com/support/t146110-epson_aculaser_c900_photoconductor
Posted on May 22, 2008
hdsportyem
  • 11 Answers
SOURCE: Epson Acculaser CX11NF Error 'Service Req E527'
Hi.. To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the toner cartridge if stuck.
Thanks
jim report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Posted on Feb 18, 2009
  • 11 Answers
SOURCE: EPSON AcuLaser C1900 with Error "Service Req E020"
ERROR CODE: E020
“SECONDARY TRANSFER VOLTAGE CONTACT/RELEASE PROBLEM”
Solution
�� Electric parts which can cause the trouble:
• Transfer Roller Pressure Solenoid (SL2)
• Transfer Roller Pressure Position Detection Sensor (PC7)
• Engine Board (PWB-A)
Posted on Sep 06, 2009
What does error code EO23 mean on an Epson Aculaser C1900
this error refers to a misalignment of the carousel, i have one that randomly does it at the moment, i also have a replace black toner even though the toner is full, i'll get back to ya when i find a fix, the service manual says it can either be the 2nd motor, clutch or sensor, but in my case all three are working fine.
Oct 07, 2009 | Epson AcuLaser C1900 Printer
Ghost image on Epson Acculaser C4000
Ghosting can be caused by several components: 2nd BTR transfer roller, Photoconductor Unit (PCU) or the Fuser unit. The most likely is the PCU contacts being dirty, caused by toner getting between them. Open the front of the printer (cover B) and lift out the photoconductor. Clean all of the metal contacts down the sides of the PCU with a cloth and wipe out any loose toner from inside the printer and give the contacts inside the printer on the R/H side a good clean. Replace the PCU and close the front cover.
Hopefully all will now be well, if not open cover A and clean the transfer roller on the inside of the cover. If problem persists you will need to get a Tech out to look further as without seeing the printer it is pretty hard to diagnose.
Good luck.
May 20, 2009 | Epson AcuLaser C1900 Printer
ERROR CODE: E020
Solution
May 18, 2009 | Epson AcuLaser C1900 Printer
Thanks
  • Cancel »
Feb 18, 2009 | Epson ACULASER CX11NF All-In-One Printer
Acculaser C1900 Printing too low on paper
Which post. There are hundreds of thousands to choose from.
Jun 27, 2008 | Epson AcuLaser C1900 Printer
Service require E008
Feb 14, 2008 | Epson AcuLaser C1900 Printer
Epson AcuLaser C1900 starts printing too low
I have a C1900 with an error "Service Req E021". I appreciate any help as to what this refers to please.
Jan 05, 2008 | Epson AcuLaser C1900 Printer
The Cleaner Pressure Flapper Solenoid it dead or dying. You can try moving it by hand to see if you can prolong it, but basically it needs a new one. Its a job for an engineer really.
See the image below for it's location.
Sep 17, 2007 | Epson AcuLaser C1900 WiFi Printer
Epson AcuLaser C1900 Printer Logo
216 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
