Tascam 38 roller is like goo-- retrieved machine from storage recently some lights are out no counter fast forward ewind good no play action-- can it be revived one more time for transfers? hopefully the 20 yr old tpes can still make sound- rick rbmusic@iname.com thanks
  • dskollodge Jan 29, 2009
    I have the same problem. Pinch roller is like goo on my Tascam 38 eight track. Everything else is like new. Can I get a pinch roller somewhere?
    Help
    Dskolldoge@comcast.net
No way to fix a bad pinch roller.Buy a new one from Tascam 323-726-0303 ex.840 is the parts dept.
Posted on Apr 18, 2008
I have a Tascam 488 mk II that will rewind and fast forward, but will not Play or record. Does anyone know a solution to fix this problem?
Check too make sure that the tabs on the cassette itself are there if they are gone place a piece of tape over them, then try recording again. It may be a belt issue open the unit and see if all the belts are present cassettes usually have 2 or 3 separate belts one controlling the fast forward and rewind and another for record and play more than likely this is the issue, If so belts for these units are obsolete try searching science and surplus magazine catalog they carry a variety of large rubber band / belts you may get lucky and find one there good luck I hope this helps you
Mar 31, 2015 | Tascam 488 MKII Portastudio
Tascam 34b plays too fast
First, push the Pitch control in so that it is turned off. Then if that is not it the deck need a servicing. Also make sure the Pinch roller is making good contact top the capstan shaft- if not the tape will slide through.
Feb 14, 2014 | Audio Players & Recorders
Tascam 38 reel-to-reel 8 track- the ff and rew work and cue instantly; it will not move forward when the play button is pushed. It is as if something is stopping it's motion. To my knowledge it i
Hi James,
I am a past Teac Technician. The answer may be a bad capstan belt- is the round metal thing rotating that makes contact with the rubber Pinch Roller? These belts become lose over time and the DC motor become defective in time due to wear- Before they burn out they can be serviced but only by a person with knowledge about how to take them apart. Otherwise the part can be $120 plus installation. I have not seen sticky Pinch Roller linkages in these models so I will say it is probably not that.
If you are near Chicago I can help you out. If you are near New Jersey Russ can help. If you want to discuss, contact me.
skywavebe@sbcglobal.net
I work on all Teac and Tascam units now full time.
I am also known on tapeheads.net as well.
Oct 31, 2012 | Audio Players & Recorders
Left deck doesn't "play" anymore.
There is a mechanism problem in the Pinch Roller part of the deck.
It needs to be looked at by a Technician to correct.
Feb 24, 2011 | Tascam 302 PRO DUAL CASSETTE DECK Single...
Tascam midstudio 644 powers up and can rewind and fast forward.
You have not mentioned the model. Hope you have checked the belt and the motor that drives teh main capstain and the reel drives. If this does not work then replace and proceed. Also the pinch roller could be defective and not holding pressure to the spindle. Check the roller for hardening of the rubbers. replace if this is faulty. I hope with the set loaded with a tape you can find which drive is not spinning to take up. This should be able to confirm you with the right section. Hope this helps. Good day
Jul 12, 2010 | Tascam Audio Players & Recorders
Tascam 644 midistudio tape deck problem
Halo I have the same problem. The motor that moves the tone heads up only shake a bit but dont move it up to the tape.
The take up clutch motor does not move at all and there is no volt on the motor.
Did you find a solution?
Greatings
Fredrik
Jul 06, 2008 | Audio Players & Recorders
Sony VCR rewind and counter problem
The belts are slipping. Every 5 years is about right for replacing them all.
Jan 24, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Dual Cassette Deck won't stop or auto-reverse
There is a tape tension sensor which, it appears, isn't working. Check to see if the linkage to this sensor may have been misaligned while you were replacing the belts. Also check to see that the sensor isn't binding or sticking.
Nov 27, 2007 | Audio Players & Recorders
Toshiba MV13P2
since it fast forwards, and rewinds, my first guess (that the take-up mechanism is worn, which also causes the machine to "eat tapes" after it stops) not likely..... the other common problem is misaligned sensors (especially if you recently had a tape jam in it, or found a foreign object, like a pen, or piece of candy in it...... another possibility is that if it's with a particular tape, you may have visible gaps in the coating on the tape, which would trigger the sensors, basically saying "STOP.... END OF TAPE..." there are other sensors and sensing conditions that could cause the same problem....... have the mechanism and electronics looked at by an expert.......
Aug 01, 2006 | Toshiba MV13P2 13 in. TV/VCR Combo
369 people viewed this question
 Grubhead
Grubhead
