Question about Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive
How do you change the wing mirror on a vauxhall combo van 2003 complete unit
    Problem Solver:
  • 5 Answers
Lucky You, I can’t wait to get back to Europe, home actually, anyways your vauxhall 2003 combo van. Take your door panel off, start with armrest, unscrew it, these screws are right under the area you would be resting your arm on, this area is seen by large holes, these can be deep so a long medium Philips should be used.
Nest is door handle to unlock door, you have plastic cover or metal, some have a small screw or slots to fix it securely. Unscrew or use a thin small screw driver to gently pull each slot from panel or lock mechanism. Now your window is most likely manual, so I will explain this first, two ways these are secured, the handle you use to roll window up and down, a screw right in the middle, just unscrew or a ring clip, this is between the door panel and handle and is removed by a special tool made to do this or a screw driver on one side of clip, a quick tap with your hand on top ot screw driver or by prying from the top of the inside of ring between gear and clip.
Your door panel uses snaps generally, but some have screws where snaps would be as well, around the outer edges of the door panel , if snaps are used gently use a wide instrument rather the your fingers, this can break fittings of panel, so use a wide flat instrument, a large screw driver or a mini crow bar used to pull nails.
If speakers are mounted, be careful not to rip speaker wires, just pull the wire fasteners from the side of magnet, remember their location so you reinstall them correctly.
Now with a flashlight look under and up to see your mount base for wing window, remove the fasters and pay attention to the top pivot for wing window, most of them are pins and easily removed by a slightly sideways downward slowly pulling down, careful not to bend pivot slot or pivot pin. Some have also been secured by a screw on the top of door frame where pivot is mounted. Which is an obvious dismantling procedure, remove fastener, usually a screw, another Philips of some sort star screw or an alien screw. That’s it now your wing window should be free and in your hands. The reverse to install a new wing window. Good luck
ZQDesign
Posted on Jun 08, 2010
Testimonial: "Thanks but there was an easier way just pop off the triangle plastic cover take out the 3 screw with a star drive and jobs a good one."
I have fitted new doors to my Combo van but when I have shut them they will not open on the key or by the handle!! Doh! Can anyone help?
Get the AA or RAC to get you in. You need the key to the new doors, or swap the locks from the doors you had.
There are a number of YouTube videos showing ho to break into your own vehicle.
Dec 29, 2015 | Vauxhall Cars & Trucks
Does a Vauxhall corsa 2005 Sri come with indicators on wing mirrors
No they are on the wing from the factory, aftermarket mirrors may be available with them fitted
Dec 20, 2015 | Vauxhall Cars & Trucks
2003 vauxhall combo orange spanner light comes on and theres a loss of power when the van gets warm, it really struggles to pull between 2000-3000rpm is it the egr valve?
would say cam sensor fault. engine getting warm and it playing up. would need the codes to be read but would say cam sensor.
Mar 17, 2013 | Vauxhall Cars & Trucks
How do i take out the broken glass in wing mirror
it's just clipped on. order the new glass and it will be obvious where the clips are on the back. the glass and backing are one unit, this is clipped onto the mirror housing in the middle.
Jun 30, 2009 | 2003 Toyota Corolla
Wing mirror indicator not working
I changed mine a few years ago (2005 Sharan). Price of the LED part was ~£20 from the main dealer. Biggest problem was taking the mirror unit apart. I spent ages removing the mirror then seperating the parts. Later some ne'r-do-well knocked into the mirror on a bike, folding it towards the front of the car, and it all just came apart in such a way as to make changing the indicator easy!
May 04, 2009 | 2005 Volkswagen Golf
Removing a speed limiter from a vauxhall combo cdti van
The speed-limiter is likely to be enabled via the ECU. Removing the limiter is a five-minute job if you have access to the GM Tech 2 electronic management/diagnostic tool.
If the van is yours then there's no legal requirement for the limiter. You could just book it in at a Vauxhall dealer for the limiter to be removed. They may charge you for an hour's labour though. Still worth doing in my opinion.
Jan 25, 2009 | 2005 GMC Sierra
Vauxhall combo van 2003 ex post-office - curtesy lights
the head light i dont know but the indicators i can help with, on the right hand side under the bonet, behind the metal panel, there is a black box unsrew it be carefull and have the key ready as the alarm will go off change the indicator relay the lid of the box will tell u which one it is thy should now work thanks jezza
Jan 02, 2009 | Enlight Combo (5601908) (Beige) (5601908)...
Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
1,349 people viewed this question
Top Enlight Computers & Internet Experts
Larry Maranto
Jerry Umali
Raymond Solomon
Level 1 Expert
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
