Question about Plantronics CS60 Professional Headset
A number of users are experiencing crackling whilst on a call using a Plantronics C60, when switching to the desktop phone the noise goes away. Handset has been replaced and frequency changed. Any thoughts Please
3 Suggested Answers
keekus
  • 83 Answers
SOURCE: USERS ARE SAYING PEOPLE CANNOT HEAR
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge. To check press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: Technical spec for plantronics C60 headset
Plantronics CS60
Type: Headphone
Acoustic Seal: Sealed/Closed/Sound Canceling
Headphone Frequency Response: Hz
Headphone Sensitivty: 14 dB/1mW dB/1mW
Wireless Technology: Infrared
Battery Time: 9 hours hours
Battery Type: Alkaline
Radio Frequency Range: 1.8GHz
Transmission Range: 100 m.
Compliant Standards: TCO '07
When I try to dial out the phone has loud crackling noise.
You have a line problem call your Telcom provider.
Feb 06, 2016 | Lands Phones
I own a Plantronics Discovery 975. It connected fine with the bluetooth and I used it on skype mainly. Then one day whilst on skype, the noise was crackling, the computer crashed and I had to restart the...
The headset may still be listed on the computer, you need to delete it and then re-pair it back up the computer. When your computer crashed you didn't say if the bluetooth is on the computer or if it is something that is an adapter, which may have been damaged in the crash.
Good luck from Headsets Direct!
Sep 11, 2011 | Plantronics Discovery 925 Bluetooth...
Plantronics M175 headset makes crackling noises when speaking with it on and is not loud and clear.
The 2.5mm jack on your phone, that the M175C plugs into, is more than likely causing you the problem. The phone manufacturers do not dedicate a lot of power to the 2.5mm jack, so sometimes people have a hard time hearing you or you hearing them. If you are using a cordless phone, you could use a Plantronics CS55H wireless headset. This headset is intended for only one phone line, not multiple lines. The CS55H's TR1 plugs directly into the wall jack instead of your cordless phone. This eliminates using the 2.5mm jack on the handset that is causing you problems. The headset come with a one year warranty.
Plantronics CS55H Wireless Headset
Good Luck from Headsets Direct!
Jun 22, 2011 | Plantronics M175 Headset
User has a iCom Bluetooth Hearing Aid adapter paired with her Plantronics Voyager 500A base station on a Cisco 7940. When on an active call and she receives another incomming call, her current call is...
Make sure that the Plantronics 500A base inteli-sensor switch is set to the number one setting (should be set on the one line, not the two line setting, on the right side of the 500A base unit). Also if you are using an EHS (Electronic Hook Switch) instead of an HL10 Handset Lifter, that could be the issue as well. The only other thing is to check the user guide for the hearing aid and make sure that there is not an "auto answer" setting that may need to be turned off. Here is a link below for the 500A / 510S user guide.
Plantronics 500A/510S User's Guide
Apr 04, 2011 | Plantronics Voyager 500A Deskphone Adapter...
The people I talk to say that they hear an echo through their headset. This goes away if I reboot my headset. Is this problem caused by my headset or my blackberry tour cell phone.
It sounds like a phone issue, and the headset is a trigger. Please remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and take the battery out for a few seconds, then replace the battery and turn it back on again. You'll need to purge from the phone any pairing information for your Voyager Pro headset and pair it again to your phone. Carefully follow the instructions in the link below for the Plantronics Voyager Pro.
Plantronics Voyager Pro Plus User's Guide
Dec 07, 2010 | Plantronics Voyager PRO Bluetooth Headset
Headset won't stay connected.
The headset may not be pairing up correctly due to the difference in bluetooth applications. If you have a new telephone with the headset already paired up to the very first phone, it will automatically go to phone number one or the phone that it was last used with. If the answer is not in the users guide, you can try Plantronics tech line 800-544-4660.
Plantronics Explorer User's Guide
May 12, 2010 | Plantronics Explorer 330 Headset
Jun 15, 2009 | Plantronics CS60 Professional Headset
Plantronics CS60
Type: Headphone
Jan 16, 2009 | Plantronics CS60 Professional Headset
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Plantronics CS60 Professional Headset Logo
95 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
