Question about Heybrook HB1 Speaker
Find original replacement tweeter for HB1
I'm looking for original (vifa) tweeters for HB1, failing that, what is a possible substitute
    Champion:
  • 222 Answers
Just buy the same wattage rating, same ohms rating and most specially the same diameter, price depends from the name, there's a lot on the internet
Posted on Jun 08, 2010
Need to replace tweeters. Anyone have specific info on aftermarket tweeters that will work
Replace tweeters with units having the same impedance as originals so amplifier loading is the same.
If unable to get exact replacement for unit, then it is important that you also replace the corresponding tweeter(s) on other channel since all speakers sound different and have different efficiency. Result will be unbalanced sound.
Mar 12, 2015 | Audio Players & Recorders
My jamo d115 speaker tweeter distorts or rattels when any serious bass kicks in, how do you stop this?w
Possible this is a distortion from the Amplifier if the speakers are not damaged. however it is important to switch the speakers to confirm if the fault is relative to the particular channel in which case the amplifier is faulty. If not the speaker can be the culprit. All what is needed is to reduce the BASS level a bit lower when the volume is increased so as to allow the cross over to work. Also if teh cross- over network is faulty within the speaker the bass can vibrate on the tweeter.
Dec 01, 2011 | Jamo Audio Players & Recorders
Polk rti6 tweers blown...4 speakers.....can these tweeters be repaired
It may be possible to have the tweeters repaired by Polk however if you have the skills your least expensive route would be to replace the tweeters and install them your self. I would recommend using the internet to find replacement tweeters either through Polk or possibly Ebay, or Amazon. Each tweeter has 2 wires that must be removed before uninstalling. Note the polarity and where they connect. red is + POSITIVE , BLACK IS - NEGATIVE
Apr 15, 2011 | Polk Audio RTi6 Main / Stereo Speaker
How do i tell if my problem if the high freq diaphram or the cross over
The crossovers in professional speakers don't fail that easily. It could be a blown tweeter. To confirm remove the metal grille-- remove the screws of the Horn Tweeter -- remove the cable connectors on the tweeter terminals ( Red and Black wire ). Now if you have a multimeter put it in Ohms range and touch the probes on the tweeter terminals-- It should show a reading betwwen 4 to 8 Ohms depending what is written on the back of the tweeter magnet. If you do not have a Multimeter you can take an ordinary cell/battery ( 1.5v ) from a TV remote and touch the terminals of the Horn Tweeter with the battery. + to the tweeter + ( a small red dot or mark will be there on the tweeter ) and -- to the tweeter -- . When you touch the terminals or give 1.5 volt supply the tweeter will make a scratching noise.
If you do not hear the scratching noise - it indicates a blown tweeter coil and will need replacement.See link below for spares:-
http://legacysoundservice.com/catalog1/product_info.php?products_id=1417
But if it does, you are in trouble and will need professional help from a electronic technician.
Could be blown HF Amplifier, suspect the crossover last. They seldom fail.
Revert back for more help
Apr 02, 2011 | JBL PRX515 Speaker
Just the tweeter is playing and not the mid
It's a midrange component speaker. Possibly your midrange speaker is blown. Check your wiring.
You hear the tweeters i am assuming because the vehicle has tweeter component speakers that are separate from the midrange and low components.
Apr 19, 2010 | VIFA P17WJ-00-08 Car Mid-Range Speaker
Tweeter not working
Check the continuity of the removed tweeter with a VOM meter (I use an original Heatkit MM-1 available on eBay for $20) and do the 1.5 volt battery click & scratch test mentioned above.
Celestion A3 tweeters (also used in the A1 and A2 speakers) or the replacement diaphragms are no longer available from Celestion. A1 speakers show up regularly on the United Kingdom eBay website for $300 or less and are small enough to economically ship to the USA. You would also end up with a midrange spare speaker (assuming it is the same as in the A3 cabinets)
The part number for the A series 3 bar tweeter is T4969/P. The 3 bars refers to the 3 bars in the casting to protect the dome. I got this number from the box of my spare tweeter I have the earlier 1 bar castings in my A3's.
Go to www.ersatzteil-versand.at do an "artikelsuche" (article search) for the number T4969/P and something extremeley similar shows up except that they list the manufacturer as Onkyo. The part number and description are so similar to what is printed on my spare tweeter box it would be worth 81 euros to see what shows up.
I have designed an adapter plate for either a Scan-Speak Revelator Tweeter D2904/710002 4 ohm, 1" soft dome, 70 mm diameter magnet, $220 or a Vifa D27TG35-06 6 ohms, 72 mm diameter magnet, 91 db, $37.50..Both are available from:
http://www.speakercity.com/ in Burbank, CA
I only modeled the front flange of the tweeter to save time. I have not built any of these yet but the price would probably be $400 for a pair of adapter plates and speaker flange modifications. But when you are done you would have replaceable tweeter for a long time to come. The 2 protective bars are drawer handles available for $3 each.
Other possibilities are:
http://www.audioloudspeakers.co.uk/boultons.shtml voice coil rewinding in the uk
http://www.speaker-repairs.com.au/coils.htm voice coil rewinding in australia
http://www.speakerex.com/diaphragms_new.html in Florida can rebuild the woofer and replace the midrange but no longer have the 4 ohm diaphragm for the tweeter.
If you want the drawings (and 3D geometry file necessary for the machinist to make the curved edges) for the adapter plate and tweeter flange modification contact me at mercedes280se-4@yahoo.com
Feb 11, 2010 | Celestion A3 Speaker
Wharfedale
Hello georgesverme,
I'd recommend starting with the local importer of Wharfdale products to see if they have exact replacement tweeters for sale. Contact:
Bob Springston, Sound Import, LLC
Phone: (508) 422-9788
Email: sales@soundimport.com
If you are unable to get tweeters from them, see if they will recommend a replacement or at the very least, provide you with the specifications, including the impedance, crossover point,frequency response, and power handling capability. If they won't or can't provide the information, then you are on you own. You'll want a relatively high-quality product, most likely 8ohm (but could be 16), crossover between 5-8KHz, frequency response from crossover to infinity (or at least beyond the range of human hearing).
Then try www.partsexpress.com. They have a large selections of speaker building products and carry small tweeters like yours in several brands, price ranges, and quality levels. Vifa is excellent. Tang Band is good. Goldwood is acceptable for entry-level speakers.
Hope this helps.
Aug 06, 2009 | MTX Audio TX4001 Component Speaker System...
KEF KHT6000ACE TWEETER DIED. HOW CAN I GET A NEW SPEAKER?
if the original KEF tweeter is no longer available there are other brand tweeters that should fit as a replacement option. just contact a repair center (us) and you can get options.
cathy@speakerex.com
Jun 13, 2009 | KEF Audio KHT6000 Speaker
Replacement KEF Coda III TWEETER Type SP1087
Go here and find a nice substitute. Many to choose from and it may be better to purchase a pair of them rather than have mis-matched ones. They should be inexpensive enough for you, as low as $2 up to $480. You just need the size of the mounting hole to find a replacement though.
http://www.parts-express.com/speakers.cfm
Nov 21, 2008 | KEF Audio Model Three Main / Stereo...
Heybrook HB1 Speaker Logo
191 people viewed this question
Top Heybrook Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Heybrook Audio Player and Recorder Expert? Answer questions, earn points and help others
