Question about Dell M209X Ultra Mobile Projector Projector
I have vertical lines on my display - how do I get rid of them?
Try loosening the screws that hold the lamp in, there is a possible short in the encasement.
Posted on Jun 23, 2010
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
Vertical lines
It sounds like dead pixels in the LCD display. the only way to get rid of the lines is to replace the Display unit in the laptop. This can be a very expensive repair so I'd check it in with an IT professional first.
Nov 07, 2013 | Sony VAIO VGN-NS135E/S Notebook PC
Vertical scan lines
It sounds that there is a loose contact to some connection wires, the flat wires that comes in, and go out the T'Con board. Re-seat all the flat cables and check. http://electronicshelponline.blogspot.com/ Check this link too. It has screen shots to different faulty displays. Pull up older posts and compare with these images to your TVs screen, and make confirm. Remember, vertical lines can be due to a faulty LCD display screen too.
Jun 06, 2013 | Vizio SV320XVT 32 in. TV
Pink vertical line
To start try reinstalling display adapter drivers. Try also to start from a boot disk or to install a different operative system.
If it does not go, and does not depend on the system, a static vertical lines is either faulty display adapter or faulty LCD display. Usually the video adapter.
Jul 20, 2009 | Compaq Presario M2000 Notebook
I have sony vaio notebook VGN-FS8900 with display problem. display showing vertical lines across, and not accepting display drivers such that resolution and color quality not changing.Laptop using nvidia...
It sounds like your video GPU may be burnt or have vertical artifacts. You can try to downgrade the video driver, or if you're tech-savy enough, you can underclock it slightly, and that should get rid of the lines. If you have any troubles, repost and i can try to help some more.
Sean Huffstickler
Jun 03, 2009 | Sony VAIO VGN-FS8900 Notebook
One big black verticle line 2 inches from left side...Help
Honestly you have a big problem because the driver IC & Tape Carrier Package inside controller board at vertical area are damage or itself defective could cause you have 2 inches line appear in your display. The best solutions for this replace lcd panel to fix vertical line.
Mar 28, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Multiple lines on screen
Try connecting an external monitor to the your laptop and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Mar 15, 2009 | Compaq Presario M2000 Notebook
Vertical lines on display
Well, in most cases it means you have a faulty lcd or flex cable.
cost is anywhere from $40-$125 to fix
http://horizonwirelessonline.com
Jan 16, 2008 | Nokia 1600 Cellular Phone
Vertical line in centre of my zenith plasma p60w26 tv
I also have this problem, but with 2 black vertical lines on the right side of screen half way through. Lines disappear from time to time but reappear. Is there anything I can do to get rid of them. Help me out please
.... Thank You.
Jan 02, 2008 | Zenith P60W26 60 in. HD-Ready Plasma...
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
Dell M209X Ultra Mobile Projector  Projector Logo
619 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
