Question about Kenmore 15073 Stainless Steel Built-in Dishwasher
Kenmore 30" stainless steel tub Model#665-110729120 Serial#FM2101476
Have a clean blinking light, (seven time intervals), I have tried tuning power off, to clear. No luck. I did run the hot water before all this happened.
My problem right now is to clear this light, and then to try to figure out why it happened, the control board is brand new.
  • Dshwasherboy Apr 10, 2008
    It doesn't have a heated dry option, it does have a hi-temp scub button though.
  • 5,911 Answers
Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
Posted on Apr 10, 2008
  • Jeff Rockwell
    Jeff Rockwell Apr 10, 2008
    I really wish you would have given me a chance to troubleshoot this further with you before you rated it as "Inappropriate". Feedback works real well in these forums.
Kenmore elite washer not starts just blinking lights.
What light(s) blink? How many times to they blink? Do they blink all the time, or just when you press a key? If it's just 1 light that blinks 3 times whenever you press a key, then you have the child-lock (or control-lock) function turned on. If you look at your control console closely, you should see some key near the lock symbol (frequently the Heated Dry key), with the notation "hold 3 seconds". Press and hold that key for 3 to 4 seconds to de-activate the child-lock.
Sep 13, 2014 | Kenmore Elite Stainless Steel 24" BuiltIn...
Electric range lights keep nking
Here is a link. On the right side of that page is a link to contact Kenmore for assistance with their products. Good luck.
Mar 29, 2014 | Kenmore 30" Slide-In Electric Range...
Blinking light on Kenmore Pro 13873K dishwasher: won't run
May be the drain pump is jammed. Try to clean the area and after that try to reset the panel. Download the user manual and there must be the reset sequence.
Nov 18, 2017 | Kenmore 13873 Stainless Steel Built-in...
I have a kitchen-aid dishwasher model # KUDio1ibl6 and it will not come on and the clean light flashes 7 times then pauses and blinks 7 time again. Do you have any Idea what this code stands for I do not...
Hello Asa,
The light blinking seven times is a error code specifically it's error #7 .The E-7 error indicates the part called the flow meter is bad. To clear that error code and get the dishwasher to start push within 3 seconds
HIGH TEMP WASH -HEATED DRY-HIGH TEMP WASH- HEATED DRY
then push CANCEL sereval times to dishwasher shuts off..it should start and run then
If the blinks 7 times again the flowmeter will need to be replaced
ON some models the "HIGH TEMP WASH" button is labled power scrub instead of high temp wash
so in that case push POWER SCRUB-HEATED DRY-POWER SCRUB-HEATED DRY then cancel as described above
In case the E-7 error returns and the flowmeter needs to be replaced the part number for it is W10195536
Gene
Aug 24, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
The clean light flashes clean, seven times. I can reset the machine, but the problem persists. How do I determine if it is the heating element?
Kitchen Aid models with the stainless steel tanks flashing clean light requires changing out both the heating element and the electronic control due to a change in voltage on the heating elements. By ordering the heating element, it comes with the electronic control. For your particular model it is a part #8194200. Just shop around to the different parts stores online, to get the best price. This will fix your problem.
Jul 30, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kenmore Elite,clean led flashes seven times & repeats
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore 24 in. 16593 Stainless Steel...
I want to change from a white door panel to a stainless steel front on dishwasher. kenmore model 3 16374300 . Where do I order the front.?
Warner's Stellian in Saint Paul can help for exchange. For cleaning stainless steel we reccommend DeBruce Polish. The "green cleaner" DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on stainless steel, glass cook tops, polished granite marble and more. DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is perfect on stainless steel, glass cook tops, polished granite marble and more.
We buy DeBruce at debrucepolish.com.
Dec 13, 2009 | Kenmore 24 in. 15173 Stainless Steel...
Age of Kenmore side by side refrigerator
Brand: Kenmore
Type: side by side refrigerator
Country: USA
Model: 106.58123700
Serial: HRW2754229 This product appears to have been manufactured the week of June 30, 2008
for anything like that next time on any other appliance check out this link by clicking it directly
http://www.appliance411.com/service/date-code.php
Apr 01, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 15073 Stainless Steel Built-in Dishwasher Logo
380 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
