Question about Bose Lifestyle 25 System
Bose Lifestyle 25 CD Skipping/jumping
I have a Bose Lifestyle 25 which has started jumping/skipping when playing CD’s. I bought a lens cleaning kit but it only made a slight difference so wanted to clean the lens internally or adjust the laser power inside. Does anyone know how to do either of these?
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: My Bose Lifestyle 25 System has been erratically
This kind of problem happens when optical lens got thin layer of dust that causing problem to laser beam to read data properly. Please put lens cleaning disc in unit and press play button, cleaning disc has little brush that will clean optical lens, this will hopefully solve skipping problem.
If cleaning disc does not help then unit will take apart to clean optical lens manually with good quality cotton swab.
Hope these info will help you.
Thanks.
Posted on Dec 04, 2010
My technics eh770 cd player is skipping so i now can't play cds
If the laser pickup is skipping, it is near end of life. Buy a CD cleaning kit and follow instructions, if there is no change the laser pickup assembly will need to be replaced, not cost effective to repair far cheaper to replace player.
Jun 09, 2012 | Technics Audio Players & Recorders
Kenwood portable cd player dpc-741 skips.
Hello
The skipping happens because the lens is weak,to solve this problem open the cd player so you can see the lens.Clean the lens with cotton wool dabbed in a little methylated spirit(wipe carefully).This should stop the skipping.
If the skipping continues then the lens is too weak to play CD's so it is best that you change the lens of your CD player.
Aug 11, 2010 | Kenwood Audio Players & Recorders
Jumping and skipping
Hallo
Ok, it sounds to me like the laser lens is dirty, the easiest and cheapest sollution is to buy a cd laser lens cleaner.
This is actually a cd which you insert into the cd trey and it will clean the laer lens in the player. Hope this can help.
Kind Regards
Andrea
Dec 09, 2009 | Bose Acoustic Wave (32022) 5-Disc CD...
When using my 5disc cd player it keeps skipping and causing static intermitingly.The cd's are new and play fine on my small BOSE with only one cd unit.What do I do??? ngly
First thing I'd try is cleaning the laser with a CD / DVD lens cleaning disc. You can find them just about anywhere (Walmart, Target, Best Buy)
Just follow the instructions on the disc (basically just play it) the disc has brushes built into the bottom which will clean the laser lens automatically.
Let me know if that clears up the problem.
--RescueTechLA
Dec 02, 2009 | Bose Wave Radio
Cd player is skippping - I have cleaned the cds. still skipping. It is a bose wave radio single cd player.
Hello my friend,
I suggest to test with many different CDs, if it's still skipping in all CDs. i will say that it's a lens issue, in this case you buy some CD cleaner which has some special lotion which clean the lens. but if this doesn't help also, at this time i will say that the lens needs to be replaced and i hope that you device is still under warranty because the repair will be free for you.
Best Regards,
Oct 30, 2009 | Bose & Wave& Music System
My DVD player has had continual playback problems for many months. It skips and pauses often while playing back DVDs and CDs. These same CDs and DVDs play flawlessly in other (much less expensive) players...
Might need a tune from bose repair man, Burnt dvds sometimes has problem but wipe normally fixes it. But cds i have't had problem burnt or orginal, scraches dont usally worry to much, Thats why thinking repair man.
Hope this helps:)
Cd normally hot from unit if its in for a while.
Aug 16, 2009 | Bose Lifestyle 38 System
CD changer won't play CDs.
time to clean the lens...get a good CD lens cleaning kit
Aug 12, 2009 | Bose Lifestyle 25 System
My bose lifestyle 20 system was skipping cds. i used the canned air to try to clean it out. i even took the alum cover..(thanks to someone here that posted the how to's ) now it wont play cd's. the...
You have probably changed the alignment of the laser.
It sounded like the laser was weak anyway.
It should be repairable.
Lasers can be realigned.
If the unit is more than 4 years old and had a bit of use, I would try and replace the laser.
Jun 13, 2009 | Bose Lifestyle 20 System
CD is skipping
Probably need to clean the lens inside the player. If you have compressed air you can GENTLY spray inside the tray to remove dust, otherwise go to Walmart and buy a CD cleaning kit to clean your lens. If it still skips then you might have a bad disc or player
Hope this helps
TankMurdock
Apr 27, 2009 | Aiwa NSX-D30 CD Shelf System
Plays cd's but lots of skipping going on. I tried cleaning with a CD player disc cleaner that I got today. That didn't help. None of the CD's skip in another machine. Thanks!!
When optical lens got dusty or thin layer of dust on lens, cd starts skipping, as you tried cleaning with lens cleaner cd but no result.
You need to open the unit and clean the lens with good quality cotton bud / swab with care.
Still no joy, replace optical lens.
Oct 10, 2008 | Sony XPLOD CDX-GT200 CD Player
Bose Lifestyle 25 System Logo
124 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
