My BB bold 9700 has suffered a total power failure. It worked before i slept last night but i knew something was wrong when the phone alarm didn't wake me up this morning. I tried switching it on but it just wouldn't come on. I have tried charging the battery, I have swapped batteries with a colleague's and it still didn't work. I tested my own battery on my colleague's and it worked so my battery is OK. Any suggestions pls???
SOURCE: blackberry bold suddenly shut down
Lots of battery issues with the Bold. Try taking the battery out, keeping it out and connecting to PC with USB. Do any lights come on? Red light should appear. Put battery in while connected to USB.
Another fix that I found for a friend-leave the battery out of the unit for a day-put it in and plug in power cord or USB. It worked.
SOURCE: My new BB Bold 9700 battery suddenly drained while plugged in?!?!
keeping it plugged in shouldn't have hurt the battery. i would return it if you have a warrenty left... otherwise i would connect to bb desktop mngr and reset to factory settings.(origional settings your phone came with)
SOURCE: Blackberry bold 9700 Bluetooth problems
Many quirky behaviors for these
devices are fixed every time a new software version is released.
You might check that you are using the most current system software for
your BlackBerry Bold 9700 Smartphone.
The
latest software as of March 20, 2010 is BlackBerry Handheld Software v5.0.0.64
Instructions for reinstalling BlackBerry Bold 9700 Firmware and System Software are here.
SOURCE: I have a new BB Bold 9700 and I unlock it, but
I think its having unlocked problem... In here http://www.wickedunlock.com/ - Wicked Unlock you can get best codes for the Blackberry mobiles..Just get and follow the instructions for your mobile.. Its very simple..
SOURCE: Not able to sent sms
you more than likely need service books. i have the same phone and have delt with the exact same issue. first take out the battery with the phone on and leave it out for 45 seconds. next open your messages and delete all that you can. you can highlight the date in your inbox and select menu and then delete prior and it will empty your inbox. this will work! thank you!!
