Question about Car Audio & Video
Which are poss and neg wires on cq-c1011n please
  • 94 Answers
Yellow would be your 12 Ign. Red 12 Constant, Black is ground
Posted on Jun 07, 2010
2003 chevy venture problems
Yes the battery can be effected (drain) but in any kind of weather, unless you turn the radio off when you turn the engine off. The power wire in either application is connected directly to the battery as opposed to being connected to the ACC terminal which will be switched on and off with the ignition. You should connect the power wire (should be RED in color) from the radio plug to the terminal (marked "acc") on your fuse box located somewhere under your dash board. It sounds as though it's possible that the RED power wire and the YELLOW "Memory" wire have been switched, the power wire should be switched with the ignition and the Memory wire should be connected directly to a Battery terminal (marked as Batt also on the fuse box) or to the battery itself. All of these wires should be labeled with a small tab indicating there connection. Example Red wire marked (+ poss power), Black wire (- Neg Ground) Yellow wire (Memory) and usually 2 Green, 2Grey, 2 Blue, 2Purple as for the Speakers Poss. & Neg. respectively.
Dec 29, 2013 | Cars & Trucks
I need to know the wiring hook up for my panasonic cq-vd6503u
I need to know the wiring diagram for a panasonic cq-vd6503u
Nov 05, 2010 | Panasonic CQ-VD6503U Car DVD Player
How do i store the radio stations on my panasonic cq-c1011n
seek to a station you like then press and hold any preset 1-6 for a few seconds to lock a station to it.
Nov 01, 2010 | Panasonic CQ-C1011NW CD Player
I need a diagram of how to wire 2 gto 1202d subwoofers. i need to now whats the best way of wiring them to get the maximum power out of them and they will be getting wired on to a 4 channel vibe amp. if...
on 1 channel connect both poss. wires to poss of the amp.......on another channel connect both neg. wires to neg. of the amp...if there is a bridged switch select bridged on....i hope this helps
Jan 03, 2010 | Car Audio & Video
Panasonic cq-c1011n car stereo
It has 1 pre out for amplifiers, if you use this with an amplifier with a built in filter then it will be fine.
Jan 03, 2010 | Panasonic CQ-C1011NW CD Player
I purchased a1959 544 And both battery posts are connected to ground this is not correct and the heater fan says 6 volt is this system positive ground?
look at battery and idenify neg and poss posts if the cabel from neg post is connected to the starter solenoid then it is poss earth no way can both be connected to ground it would cause a dead short
Dec 08, 2009 | Volvo S40 Cars & Trucks
Simple question, Terminals on the battery are
ALL BATTERY LEADS ARE THE SAME
Red wire is Poss or the biggest term/Black wire is Neg which goes to the smallest term which is earth..
Red is Feed wire to starter motor/Alternator lights etc Black or earth wire goes to engine somewhere on bolt on the block and also a small thinner wire goes to the body any where as long as its clean and no paint. and away you go (easy)
Let me know if you have any more problems Ron
Poss is+ Neg is--
Oct 05, 2009 | 2002 Mitsubishi Eclipse
Panasonic CQ-DP383U resetting the security?
check the fues on the back of the cq dp383u you will have to pull out the deck itself there a 15amp fuse beside the wireharness it might have blowen if not the unit is more than likely fried but check with a audio shop for testing
Jan 21, 2009 | Panasonic CQ-DP383U CD Player
Car Audio & Video Logo
43 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
