I have purchased an ASUS ASUS P5K SE Motherboard. I want to run a MDT RAM at 667 Mhz DDR2, is it possible as it says nothing in the asus website The ASUS P5K SE Motherboard Qualified Vendors List (QVL) says that it only runs at rams at 1066 Mhz and MDT is not on the list. I used MDT in my previous PC which was MSI. I want to know can I run a 350 Watt PSU on the system successfuly
  • Roger Stace Jun 08, 2010
    very good
    Thanks
  • Computers & ... Master
  • 5,660 Answers
"The Asus P5K SE Motherboard Qualified Vendors List (QVL) says that it only runs ram at 1066MHz and MDT is not on the list"
Really? I beg to differ.
The motherboard manual states,
" The chipset officially supports the memory frequency up to DDR2 800MHz. Tuned by the Asus Super Memspeed Technology, this motherboard natively supports up to DDR2 1066MHz."
1) Notice the 'Up To'.
Supports UP TO 800MHz, and with the SMT it supports UP TO 1066MegaHertz.
It will support DDR2 at 667MHz, 800MHz, and 1066MHz (With SMT)
The QVL doesn't encompass all ram memory that is available out there.
The Ram Memory used has to be;
A) Unbuffered
B) DRAM chips used cannot be any larger than 64MB
[DRAM chip.
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
The Black rectangular chips, shown on the module of DDR Sdram example above, are DRAM chips.
http://en.wikipedia.org/wiki/DRAM
C) Should follow the JEDEC standard for DDR2 Sdram.
For one, it should follow the JEDEC standard for DDR2 voltage.
1.8 Volts.
Some high performance ram is set to use a slightly higher voltage. The Asus motherboard is set to use DDR2 at 1.8 Volts by default. (Factory settings=Default)
The MDT DDR2 at 667MHz is not high performance ram memory. It will be set to use 1.8 Volts.
Asus Support>Downloads,
http://support.asus.com/download/download.aspx?SLanguage=en-us
Up to the Left side of the page is the heading - Download, in white.
Under it is the - Input Model to Search, box.
Put your mouse cursor in the box, leave it there.
Left-click once.
Type - P5K SE
Go to the Select Category box below it, and left-click on the down arrow, on the right side of the box.
In the drop down list click on - Manual
Now click on - Search info, below it.
Left-click on the blue P5K SE to the left.
Choose the Operating System. Left-click on the down arrow on the right side of the box. I chose Windows XP in the drop down list..
It doesn't matter.
Left-click on Search below.
Now scroll the next page down to Version E3202
Left-click on Global (DLM)
In the security box that pops up, make sure you use capital letters for the letters shown.
Left-click on Submit.
It's a PDF file download. Make take up to 30 seconds before you see the first page. May also take time to fully download. Advise letting it download before looking through it.
I posted the link so that if you have a motherboard manual, and it does not have the information this one has, then you now have the official Asus version.
Ram Memory information starts on Page 37.
Page 40 shows the QVL for DDR2 at 800MHz.
Page 41 shows the QVL for DDR2 at 667MHz.
This QVL does not list MDT either.
It's okay, it will work. The MDT ram memory has SPD support.
[Serial Presense Detect
http://en.wikipedia.org/wiki/Serial_presence_detect
Maximum Total Amount of ram memory is 8GB. You better have an O/S that will recognize 8GB, however, to realize this.
Has to be a 64bit O/S. (Operating System)
Windows XP Home, and Pro that are 32bit versions, will only recognize 3.2 to 3.5GB of ram memory.
Maximum Amount for EACH ram slot is 2GB.
If you only install one ram memory module, make sure it is in Slot 1. (DIMM A1 on that motherboard. The ram memory slot that is closest to the Processor)
350 Watt PSU? Not planning on gaming I see.
Depends on what PSU you have (Power Supply Unit), but it could be old enough to be just putting out 70 percent, of the maximum rated wattage.
245 Watts.
Continued in an additional Comment
Posted on Jun 07, 2010
  • joecoolvette
    joecoolvette Jun 07, 2010
    Asus Support>Power Supply Calculator,
    http://support.asus.com/PowerSupplyCalcu...
    I don't know what Processor you're planning on using, so I don't know what the maximum Wattage it is going to use. I also cannot enter the Processor information, into the correct parameters on the power supply calculator.
    You can.
    Enter the information, then come back, and tell me the results in a Comment.
  • joecoolvette
    joecoolvette Jun 08, 2010
    Thank you for the rating, and the comment, valro_trust, you are Most Kind!
Does ASUS P5GC-MX/1333 Motherboard supports DDR2 800mhz ram.?i'am havin 1gb ddr2 667mhz ram and i want to add 2gb 800mhz ram to it
Hello Tarun - No it doesn't. It would run OK but you would not gain any performance as the ram will only run at the same 667 MHz.
The limitation of RAM speed is dictated by the specs of the Intel 945 Chipset the motherboard is based on. But certainly add more ram, especially if your running Windows Vista or Windows 7 which both need at least two GB of RAM to perform well.
Happy upgrading and thanks for using Fix Ya.
Mikeywaf
Mar 21, 2011 | ASUS P5GC-MX/1333 Motherboard
Can asus p5gz-mx support 2gb kingston 800mhz ram
Click here to view the Specifications of your computer mainboard.
Unfortunately only 2 x DIMM, max. 2GB, DDR2 533/400 MHz memory modules are supported.
Meaning that it is not possible for the 2gb kingston 800mhz RAM to run, according to the Specs.
Sorry to inform you of this fact!
damnor01
Jan 23, 2011 | ASUS P5GZ-MX Motherboard
I want to upgrade my from 512 to 2GB RAM. Pls let me know which brand RAM and speed will suport to upgrade the same. my motherboard is P5RD2-VM, with intel pentium D 820 processor. pls guide me on the...
Your Motherboard will support:
2 x 240-pin DIMM's (4GB Max)
Unbuffered
non-ECC
667/533/400 MHz DDR2
You should be pretty safe with any main brand name of memory from your local computer shop.
Below is a list of ASUS TESTED and Qualifed Vendor RAM.
Jan 02, 2011 | ASUS P5RD2-VM Motherboard
Is it ok to install a 1 gB DDR2 667 Mhz in this motherboard?
please reffer to your motherboard user manual or go to asus support on the net and browse for your motherboard model to know what memory card can be use on your board.
Oct 13, 2010 | ASUS P5VD2-MX SE Motherboard
Trying to upgrade a Compaq SR1020NX computer. The HP website still has old info, likely based on the original bios. The motherboard is an Asus A8M2N-LA. What CPU upgrades will run on that board? Is there...
The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor  Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB)  2000 MegaTransfers/second
Chipset  GeForce 6150 LE chipset
BIOS features  Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor  Micro-ATX: 9.6 in X 9.6 in
Memory  Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Feb 15, 2010 | AMD Athlon 64 X2 5400+ Processor...
I am using this ASUS (asus M2N-MX nvidia mcp61p chipset
According to the manufacturer's web-site:
http://usa.asus.com/product.aspx?P_ID=0pKBwEIE8tqMT4j7
this motherboard has 4 x DIMM sockets,
supporting a maximum of 4 GB
of DDR2 800/667/533/ Non-ECC, Un-buffered Memory
and supports Dual Channel memory architecture.
So, add one 512MB DDR2 533 Mhz RAM into one of the slots,
being sure to leave *ONE* *EMPTY* slot between the two sticks,
in order to enable the high-performance "dual-channel" option.
Try your computer -- it should feel faster.
If you still think that need more RAM, buy two 512MB (or two 1024MB) DDR2 533 Mhz RAM, putting the 2 sticks into the two empty slots.
Dec 26, 2009 | ASUS M2N-MX Motherboard
ASUS P5VD2-MX SE recognizes only up to 2500MB RAM
Actually you are doing better than you think, According to your MB specs it is only supposed to hold a max of 2GB (1GB per slot). The updated BIOS may be allowing for the additional 500MB.
If you would like to verify, here is a link to the manual for your MB:
P5VD2-MX SE Manual
See page viii.
Thanks for using Fixya.
Wayne
Sep 09, 2009 | ASUS P5VD2-MX SE Motherboard
I put 2gb of DD2 ram in 800 mhz it wont show a screen? To fast of
Eee PC models use 533/667 MHz DDR2 RAM via a standard SO-DIMM module.
The hardware supports up to 4GB (2GB for the 1000 series, and some of the 900 series).
Feb 25, 2009 | ASUS Eee 900 Notebook
Computers & Internet Logo
227 people viewed this question
David Payne
David Payne
