Question about Nokia 3110 Cellular Phone
Enter restrition code
Mx key
use easyly unlock .........
HOW DO I FIX ERROR MESSAGE H3-00 ON MY MX M753N
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Feb 25, 2015 | Sharp Mx-M753n mx-M753n
Free unlock restrition code for nokia 2220
Hi free unlock code are unavailable for your Nokia 2220 mobile so you better go for paid codes ..You can get restriction code from online providers like Prounlocking.com who render unlock code for all mobile models ..You must first check that whether the code is available for your country and network provider to which your mobile is locked at present .If yes then pay for it and unlock your Nokia 2220 mobile .
Jun 29, 2013 | Nokia Unlocked 2220 Slide Silver Gray Fm...
I need restrition code 4 nokia 5220 on virgin
hi to get restriction codes visit mobileulocksolutions.com here they ask the imei number of your mobile .finally they deliver you codes to unlock your mobile .then visit mobileunlockguide.com here they provide free instruction guide about how to use codes in your mobile.
May 31, 2012 | Nokia 5220 XpressMusic Cellular Phone
Need a restrition code for my nokia x3-02
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.
You can get the unlock code through online..........i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Nov 06, 2011 | Nokia Cell Phones
Restrited code for for nokia 2730c-1 code0591371 RM-678 imei 359370/03/441216/7
Hi you can unlock your mobile by unlock codes and its the safe and best way of unlocking..and also don't try with hardware/software unlocking because there is risk involved..for unlock code you can contact your provider or can get it from online providers..one of my friend got unlock code for his mobile from simpleunlocking and unlocked his mobile..you can too try getting codes from them to unlock your mobile..
Sep 15, 2011 | Nokia 2730 Cell Phone
6300 restrition code for my nokia 6300
You can get the Restriction code from here
Theunlockspot.com/nokia/rs10wp8 and unlock it from Network lock.
Sep 15, 2011 | Nokia 2630 Cell Phone (Unlocked) - Black
SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Aug 28, 2011 | SHARP MX-3100N
My nokia ask for a code 6500s imei no.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 0760677541(Unlock code)
Follow this instructions carefully
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1 - Switch on your Nokia 6500 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6500.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6500 would then display the message "SIM Restriction Off" and will be unlocked!
Note: For Nokia 6500 mobile phones locked to the network Fido in Canada follow these instructions:
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star (*) three times quickly
The letter w appears if you press the button star (*) four times quickly
The symbol + appears if you press the button star (*) two times quickly
The CODE (0760677541) you need to enter is the unique unlock code for your Nokia 6500
GOODLUCK
Nov 13, 2009 | Nokia 6300 Cellular Phone
I NEED THE RESTIRTION CODE O ACTIVATE AND UNLOCK
contact ur local nokia store or service operator for the restrition code
Aug 24, 2009 | Nokia 2760 Cellular Phone
Nokia 3110 Cellular Phone Logo
59 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
