Dear rxpert. I have washer Maytag Neptune Model MAH5500BWW Model 67787785ZH. After, The washer completed the Work, that still have water inside of washer (I hand to turned the basket inside the washer I hear water noise still inside). Can you tell me what wrong, And My sister had One that also had a same problem. Thank you Very much.
  • 5,911 Answers
This is actually normal. It is normal to have water between the wash basket (stainless steel tub) and the outer wash tub (plastic). There shouldn't be a problem unless the water is excessive enough to pool inside the wash tub itself or overflow onto the floor. You will always find a small amount of residual water between the tubs. Don't waste your money on a service call unless you absolutely have to.
Posted on Apr 10, 2008
My washing machine sounds like it still has water in it when i spin it and it smells musty
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Aug 28, 2011 | Maytag Neptune MAH5500B Front Load Washer
Hi I have a Maytag Neptune model MAH5500BWW Serial B4585662GA. When I turn the drum, I can still hear water inside/behind the drum. Thank you
This is normal. There is a balance ring filled with water attached to the inner drum. The balance ring is sealed and is not supposed to be empty. When you turn the inner drum by hand, you're hearing the water settling down from the now upper chambers of the balance ring.
Oct 14, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune model # MAH5500BWW. It appears that there is still water inside the tub after completing a wash cycle. I only noticed it as I tried to get a stuck sock from the top of the tub and...
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Vlad,
First Choice Appliance
Aug 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune Model #: MAH5500BWW is flashing
The error code you describe is not listed in Maytag's book of codes. The link below will take you to Maytag's website error code page where you might be able to match it up.
http://maytag.custhelp.com/app/answers/detail/a_id/2885/session/L3NpZC8yY3lEMjNEag==/sno/0
Jul 15, 2009 | Maytag Neptune MAH5500B Front Load Washer
Tub fills with water
replace water valve in the washer. Serial number is needed to find the correct part number. It's likely 22003834, but call any parts supplier with model/serial numbers to verify.
Good luck,
Vlad
Jan 12, 2009 | Maytag Neptune MAH5500B Front Load Washer
Door Lock
on your model all wax motor door latch's have to be replaced,go to repair clinic .com and you can order the part or go to ebay,and put in maytag neptune mah5500bww wax motor and it will come up and the guy selling the motors has pictures on how to install,let me know-mike
Jun 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
