Question about Karcher 1750 psi Electric Pressure Washer
I have karcher 397m when i start fuse blows can you please tell me what wronge with machine thanks mr narendra dhokia
Hi got a old 555c karcher hot pressure wash each time I turn it on the fuse blows checked wirers
I had one that the motor would stick and blow the fuse until I rotated the fan on motor just a bit
Sep 20, 2017 | Karcher Garden
My karcher 310 will not switch on and fuse is good
you need to check you nozzle for blockage or wrong size you could be throwing the overload switch on the motor
Oct 10, 2012 | Karcher Garden
I HAVE AN OLD, ABOUT 15 YEARS,PRESSURE WASHER MODEL 270M. RECENTLY IT STARTED TO PULSATE WHEN I ACTIVATED THE WAND CONTROL. IT PULSES AT THE RATE OF ABOUT 1 SECOND INTERVALS. IT WILL NEVER STOP AND RUN. I...
To me this problem sounds like there is something wrong with the pump.
I think its better to buy another Karcher machine and get the 12 month warranty. As with old pressure washers you could spend money on certain parts to fix the machine but a few weeks/months down the line a different part of the machine could break and then you end up having to buy a new machine anyway.
Also being 15 years old you would have to check to see if parts are still made for the machine. This is because once Karcher discontinues a machine parts for that machine are manufactured for 10 years from that discontinue date.
Jan 17, 2011 | Karcher Garden
Hello I just borrowed a k archer k 2.87 water blaster from a friend and forgot to turn water on before starting motor. Motor stopped after a few seconds and now won't start. Online guide says to change...
Most of the time it is the GFCI on the end of the plug that goes bad. If it were me I would cut off the GFCI and wire in a standard 120v plug. If it still doesn't work after that then there is a good chance that something electric internally has gone wrong which isn't going to be worth repairing.
Oct 24, 2010 | Karcher PSI Electric Pressure Washer
Everytime i switch on my 6.80 pressure washer the fuse blows on the machine
This sounds like the bypass (unloader) valve is sticking and the internal switch it activates is being held in a half open position. This will blow a fuse. It could also be loose wiring inside. If you ran it with an extension cord you may have weakened the fuse. Sorry, I cannot find a schematic anywhere. I think it is European, correct?
Aug 21, 2009 | Alfred Karcher Pressure Washer
Karcher k3.48 pressure washer appears to be seized up?
if the machine is blowing fuses then it could be the motor! if not then maby the start cupasitor has failed
Jun 01, 2009 | Karcher PSI Electric Pressure Washer
My karcher hds 745 has started blowing fuses. it switches on the power light comes on and it makes a buzzing noise for about five seconds and then blows the mains 13amp fuse. i have replaced it twice but...
Dear dumbelldaveb,
Having a 13A fuse I am concluding that the machine is single phase. Most probably you have a faulty capacitor. Check the capacitor and if you find it expanded and leaking...then you must change it with a new one. If you see the capacitor is normal just the same it could be shorted. So change the capacitor with a new one and try to start the machine WITHOUT LOAD. Which means no water inlet and no gun attached. Doing this you can also remove temporarly the micro switches. If the motor still hums, then most probably there is a fault in the electric motor.
Now if you find out that the fault is the capacitor (which in my opinion it is the case)...you must see why the capacitor broke. If when using the machine and the gun is closed, the machine starts on and off on its own,...this will damage the capacitor. This on and off fault could come from a leaking gun. Or a leak from the seals. Whatever....the machine must not be left going ON and Off when the gun is closed. This ON and OFF could be due to faulty micro switches and control valves.
I am very sorry to mention a lot of things, but I hope as in many cases,..the changing of the capacitor will solve the problem. I wish to add that the electrical lead wire must be checked. On many occasions I found that the electrical lead wire from the plug to the machine was damaged and shorted, ..due to pulling, wear and tear.
Regards,
Fulltech.
Apr 19, 2009 | Karcher Garden
you have an electrical short in the motor windings. you'll have to either replace the motor or buy another washer. also check to see if the motor isn't locked up with a piece of trash. to do that you'll have to dissassemble housing until you get to the motor. it should turn easily by hand. if so you have a short.
Apr 19, 2009 | Karcher 2500 PSI Pressure Washer
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
Brother SE-270D dispaly just F06 in LCD Panel
Contact Brother
http://www.brother-usa.com/homesewing/
To the left on the above site is a software download page.
If you need further help.. email brother...they will tell you how to fix this. Takes them a day or so to answer.
Sounds like the technician may have put in a wrong fuse himself. Hoping it was a Brother authorized dealer.
Jul 29, 2008 | Brother SE-270D Computerized Sewing...
Karcher 1750 psi Electric Pressure Washer Logo
147 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
