My TV set not showing the whole screen
My Aucma TV is showing a horizontal strip at the center instead of the whole screen? what might be the problem
  • 48 Answers
Is there still a picture?
Posted on Jun 21, 2010
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
When using PS3 on RCA D52W19 TV, the screen does not fit ( it is zoomed and off-center) in 1080i resolution.
hello!
Have you tried to toggle "format" or "screen size"? On those sets non HD and HD settings could be adjusted separately. Try that, first. If no luck, try similar settings on PS3. I bet, you will be able to match screen format there, as well. To me it looks, like picture formats are mismatched. Also: try to use "component" cables, instead of DVI adapter cable, if nothing works.
good luck,
Alex.
Feb 16, 2012 | RCA D52W19 52" Rear Projection Television
TV shows only about a one inch wide horizontal strip in middle of screen, the rest is black. It actually looks like it is showing what is supposed to be at the very bottom of the screen but is perfectly...
In the old days that meant that your "flyback transformer" went bad and needed to be replaced.
Now a days it might be cheaper to just buy a new TV set - especially if it's over ten years old. Give it to Goodwill and see if one of their workers can fix it for resale to lower income folks..
Jul 24, 2010 | Emerson EWC20D3 20 in. TV/DVD Combo
Horizontal line in toshiba TVs
its the horizontal output IC
Feb 14, 2010 | Toshiba 28N33 28" TV
I have a KDF-55E2000 Sony Grand VVEGA Color Discoloration
Bad news: The issue can only be solved by replacing the optical block for the TV. This was a defect in the design of this TV. Replacing this part is very expensive (over $1000) and time consuming (need to take whole TV apart).
Good news: Sony extended the warranty for the optical block for this model. They are covering the cost of parts and labor for this TV. Contact Sony to have them refer you to a authorized service center near you.
Oct 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Picture in wrong position, too big for screen
Hi
maybe the system settings is not set in default mode
Thanks!
Mar 05, 2009 | JVC AV27F476 27" TV
Distorted picture
i was just working on a set with the same problem .. i found a east west correction curicit with a falty transistor. something in that cuircit has failed.
Jan 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
JVC 27" CRT TV AV-27BP3 display shows single horizontal line
I have a similar problem on my CRT computer monitor (AcerView 76c). It is an old screen and I think it is just at the end of its life, much like your TV. Having some background in physics, I would be pretty sure that the problem is with the cathode ray tube's vertical deflection system. The horizontal deflection electrodes are working while the vertical one is not. This results in a display of a single horizontal line (or in my case, a few superimposed) in the centre of the screen. Where both X and Y (horizontal and vertical) deflectors fail then the electron gun firing would result in a single bright spot in the dead-centre of the screen.
So really, we have no choice but to move on and buy a new set as repair is probably just as, if not more, expensive than replacement with a new device. Seeing as your post was in 2007, I hope you managed to solve the problem.
Best wishes,
SZ (Sydney, AUS)
Dec 24, 2007 | Televison & Video
Televison & Video Logo
155 people viewed this question
Top Televison & Video Experts
Electro Med Services...
