Question about Sony Ericsson S312 Mobile Phone - Silver
Suddenly the bluetooth connectivity is not working. It always in ON Mode and when i tried to turn off the bluetooth it is getting cancelled. And the bluetooth searching is also not working . Overall the bluetooth is not working.
  • 112 Answers
You should restore default factory setting
go to phone setting-master reset-restore factory setting it will ask for a password get from your phone manual
after that check whether it is working or nor otherwise contact your manufacturer
Posted on Jun 07, 2010
How do I get the blue tooth to cancel the "in use" signal"?" The phone or car functions do not respond to any prompts.
Maybe i don't get it, but you can simply turn off bluetooth on your iphone to cancel all bluetooth connections immediately. Re-Enable bluetooth to re-engage your connections.
If you wan't your iPhone to "forget" a paired bluetooth device just go into the bluetooth settings and tap on the little info badge for the device you want to remove. From there you can delete this pairing.
Apr 24, 2014 | Apple iPhone4 4G iPhone 4
Suddenly stopped working, not charging.
it is possible that the bluetooth connection being cut midcall to have froze the bluetooth headsed, one thing you should try is to power it up in connection mode and see if it works, there are different combinations of buttons, assuming you have power and volume buttons to do a hard reset to it... otherwise i think you should take it where you bought it and ask for solution even if warranty period is over because it simply isn't normal what happened.
best of wishes and hope i helped. good luck
Mar 10, 2014 | Motorola Mobility HK202 Bluetooth Headset
Bluetooth problem rebooting my xperia arc s
my phone worked like that when i wanted to turn on my bluetooth after i upgraded it to android 4.0.4 suddenly my phone hanged then just started to rebooting , i take it to sony.s agent for 3 times . they always flashed it but after one or two days again it rebooted,i thing thats better to take it back to android 2.3.4 or 2.3.7 (xperia gamer) thats better i'll try that then say the results
Dec 13, 2012 | Sony Ericsson Xperia Arc S
I paired my H710 with my lg Chocolate touch and the phone recognized it and it seemed to be connected. I haven't used it for a while and when I try to connect it says that communication failed. I have been...
To put your headset again in pairing mode, you must assure that your phone's bluetooth radio is turned off. Only then, open your headset's boom. After it is in pairing mode, turn your phone's bluetooth radio on, and make it search for new devices.
Hope it works for you.
Regards, Carlos
Jul 03, 2010 | Motorola Mobility H710 Bluetooth Headset
Bluetooth connection
First I would need to know the model Bluetooth you have so I could tell you what to do to reset the headset. You can always reset a bluetooth headset to repair it to another device. Normally though to reset a bluetooth headset, you would have to power the Bluetooth device off and then press and hold the device to get it in pairing mode. Usually when in pairing mode the device's light usually stays lit a solid color such as red or purple, or it flashes two different colors simultaneously. At that point you can get your device to find the headset (make sure that you device is bluetooth capable, is on, and is visible to devices) and then pair it. There is always a passcode or pin associated with the headset which creates a secure connection between your device and your bluetooth headset. The default pin code is 0000. Hope you get it working, if it doesn't shoot me a message with the make and model of the bluetooth headset and I can walk you through it.
Dec 17, 2008 | Cell Phones
Can,t connect my Plantronics220 Earpiece to my phone
Begin with headset turned off. 1. Press and hold down the call control button
for 8 seconds until the headset status indicator begins to flash blue then red. The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing, use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
Oct 13, 2008 | Plantronics Explorer 220 Bluetooth Headset...
Bluetooth technology
switch of your bluetooth delte your freind from your bluetooth list turn on bluetooth again....and let your freind connect to you hopefully this should work because i had the same problem with my phone
p.s make sure on your phone your phones visiblty is on :D
hope this helps
Feb 26, 2008 | Motorola Mobility L6 Cellular Phone
Hbh-pv705
I had this problem. I fixed it doing follow: hold volume keys together, so the indicator is flashed red and green (reset to default settings mode). Then press power button to turn the headset off. Then turn it on again and try to find the headset again from my phone. Then select "pair" from phone menu and typed "0000". The led stopped flashing and headset was connected. Before this my phone couldn't see the headset at all. Hope it will help you! (sorry for my English, I'm from Russia =))
Nov 27, 2007 | Sony Ericsson HBH-PV705 Headset
Bluetooth enabling
Does it work properly otherwise? Is this the only place it gets stuck?
Sep 16, 2007 | Garmin StreetPilot c550 GPS Receiver
Sony Ericsson S312 Mobile Phone - Silver Logo
100 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
