Question about Lexmark P4350 All-In-One InkJet Printer
The paper keeps going to the right on the slant and now wont go down so i cant print anything. I have tried clearing it but there doesnt seem to be any obstructions. What can I do please help?
  • 241 Answers
Your printers rollers could be worn and need a cleaning. Have a certified technican do a maintenance cleaning and this should resolve your issue.
Posted on Jun 08, 2010
At random times, when a user prints, a document, pdf, picture ect.., it's slanted. It also happens when a user scans to themselves. What can cause this to happen?
There mite be something in the path of the paper which the paper hits and so it is slanted have you tried scanning on the big glass instead of thru the document feeder does it happen then? Now the printing is something else are you talking about copying or printing. If print I would check the paper draws ensure the guide are snug up against the paper. Do you internal prints slant such as the meter count print out or the fax info reports. or the demo page? If the problem is coping then place the original on the big glass and see if the slant There are small mylar guides though out the document feeder if some one pulled the original document out in the wrong direction they mite have flipped on of them causing a corner of the paper to hit one slanting the original ALWAYS pull the original out in the same direction as the flow of the document. Try sticking a business card down thru the way the paper flows you mite be able to reset the offending mylar.
Jul 22, 2014 | Konica Minolta bizhub C250 All-In-One...
Cant clear Error Code E161-403E on canon iPF605
to enter SERVICE MODE the machine has to be switched OFF. While the machine is off, hold down the sheet or roll feed button and the information button. Keep these pressed and switch the machine on, keeping the buttons pressed until you see an S in the top right-hand corner of the display, then let go of the buttons. You should now be in SERVICE MODE.
later go to maintenance menu choice replace print head.
then follow their picture image to replace the print head.
first try to print nozzle check in services mode.
Scroll right to the service mode box (rightmost box) and press OK. You should then see the word 'DISPLAY'. Scroll right until you see the choice 'ADJUST' appear. Then scroll down until you see the choice 'NOZZLE 1' appear and press OK. If you haven't already loaded paper, the printer will prompt you to do so and then it will print out the NOZZLE CHECK PATTERN.
check go any nozzle no firing out ink..
Dec 06, 2011 | Canon imagePROGRAF IPF605 InkJet Plotter...
Paper goes in slanted and wont print
Take the paper out off the printer and make sure there is no debris inside of the area where the paper normal loads from. If there is something stuck, you would have to shake the printer a bit to maybe get it loose to get the debris to come out.
Keep in mind sometimes kids put things in there and it gets in the way of the paper path. Also make sure there is no paper stuck in the paper path at all as this can cause the paper to go in slanted.
Aug 16, 2009 | Lexmark X2500 All-In-One Printer
Will not print - for scann or print - makes the
Give this a try: Disconnect all the cables to the printer. Hold it upside down and shake it really hard for 30 seconds. This should clear anything stuck inside the printer.
Jul 01, 2009 | Dell 924 All-in-One InkJet Printer
My Epson DX4000 Printer keeps getting paper jams and wont print
still printing but the paper goes no further?. It may be the paper is locked by paper feeder mecahnics, Open case, check it, and may be there is something "material" broke.
May 24, 2009 | Epson Stylus Pro 3800 InkJet Printer
Wont Print
try to go under control Panel - Administrative Tools - Services, then scroll down to Print Spooler and stop the service, then restart it. Try to print now.
good luck
Mar 31, 2009 | HP Officejet J5780 All-In-One Printer
HP Photosmart C5180 (wont accept photo paper but will normal paper)
Load the printer with the slick glossy paper face down. See if it will print.
Jun 06, 2017 | HP Photosmart C5180 All-In-One InkJet...
Kodak esp 3 all in one
I Have one of these printers and it hasent been nothing but trouble
I wont buy another Kodak anything,
My solution, take it back and get a HP,
Sep 01, 2008 | Kodak ESP 3 Multifunction Printer/ Copier/...
Print alignment
hi, the printer has rubber rollers which pulls the paper in during printing, it seems like one side of the intake pully does not have enough presure or the rubber has hardned or worn out, hence it is slipping off,check that area , let me know.
Dec 16, 2007 | HP DeskJet 820Cse Printer
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Lexmark P4350 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
