Question about Garden
Carby tune up air/fuel mixture screws how many turns in/out Idle screw turns in/out
    Brigadier General:
  • 4,088 Answers
Make sure the fuel filter, air cleaner, and muffler are not clogged. Turn both jet screws CW to stops (lightly), then back out 1-1/2 turns CCW each. This is a basic setting which should allow the engine to start and run. Allow the engine to warm up, then pull the throttle full on--it should be 4-stroking. Turn the H screw CW until the engine speeds up somewhat, but still 4-stroking. Proper setting is 4-stroking unloaded, but immediate 2-stroking when cutting. Release the throttle and adjust L CW until the engine runs fairly smoothly, yet allows the engine to 'follow-the-throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Posted on Jun 12, 2010
How many turns in air screw?
turn the mixture screw all the way in then back it out between 1 1/2 turns to 2 turns
that will get the engine to idle from there set the idle speed with the throttle screw to desired idle rpms
now turn the mixture screw in slowly until you see/hear a fall in rpms
now screw the screw out until again you hear /see a fall in rpms.
half of the number of turns back in from in to out will be the desired air /fuel mixture setting
adjust the idle with the throttle screw if it has altered
you can repeat the procedure again to fine tune the mixture after adjusting the throttle screw
Sep 14, 2015 | 2006 Hero Honda Splendor+
Why would my 1997 harley sportster xl 883 run hotter then usual & when it's hot and I shut it off it doesn't want to shut right off I can't figure . The carburetor was rebuilt. tune up was done .
I suspect that the engine tune up was not well done as a hot running motor after a carby overhaul indicates that it is running too lean
could be possible carby to manifold gasket failed or leaking or the carby bolts not tight
could be incorrect float level or the air /fuel mixture screw not adjusted correctly
if the carby has a solenoid near the mixture screw then if that is not working properly ,the motor will "run on" after the ignition is turned off as the pistons will still be getting a charge through the idle circuit that is being ignited by hot spots in the cylinder.
Aug 12, 2015 | Motorcycles
What is the adjustment screw under the throttle?
Hi Darren, on the right hand side of the carburator there is an idle adjusting screw with a spring behind it, turn screw clockwise to increase idle counter clockwise to decrease idle. At the front of the carburetor on the bottom of the venturi bore there is also an air/fuel mixture screw inside a carb body lug that may or may not be plugged with an aluminum cap that's about 3/16" thick. This cap can be drilled out to acess the air/fuel mixture screw. Turning screw clockwise will lean out mixture and lower idle, turning screw counter clockwise will richen mixture and raise idle. Start by turning gently the screw clockwise until it just barley bottoms out then back it out 1 3/4 turns. You need to balance the two adjusting screws to obtain an idle of 950-1000 RPM then back out air/fuel mixture screw 1/8 turn, snap throttle to confirm responce, you may continue to back out air/fuel mixture screw untill desired throttle responce is achieved, if you see black smoke coming out of exhaust you have gone to far and need to turn screw back in 1/8 turn at a time, final adjustment should be made with the engine at normal operating temperature. For more information about your question please visit the websites below. Good luck and hace nice day.
CV Performance Tuners Kit part 1
CV carburetor tuning part 2 Mixture screw adjustment
Harley CV carb mod
Adjusting Throttle Cables on Harley part 1 by Dr Chaos
Jul 09, 2015 | Harley Davidson FLSTC Heritage Softail...
2004 Honda VT 1100 C2 Shadow Sabre carburetor adjustment
Hi, Anonymous it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1995 VT1100C2 Air Fuel Mixture Pilot adjust
VT1100 Mixture Screw Location
Honda Shadow VT1100 Owner Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda shadow vt1100 Owners Workshop Manual
Apr 27, 2014 | 2004 Honda VT 1100 C2 Shadow Sabre
Fuel mixture cbr600fs
Air fuel mixture screw question CBR Forum Enthusiast forums for Honda CBR...
99 Honda CBR 900rr carburetor removal and air fuel adjustment
Honda CBR600F4I 2001 Service Manual
Honda CBR600F4i Owner Manual
Mar 29, 2014 | 1992 Honda CBR 600 F(2)N
2005 Honda Activa air-fuel mixture adjustment
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Adjusting air fuel mixture screw
Honda Activa Fuel Mixture screw Actual Adjustment and RPM Adjustment
http://www.family-motorsports.net/GY6-50cc-150cc.pdf
Honda activa 2009 Owner Manual
Feb 14, 2014 | 2005 Honda Activa
How do i tune the carby on a peewee 50? the bike wont run properly
Hi, Anonymous and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Yamaha PW 50 checking carb
Life On 2 Wheels
https://books.google.com/books?id=ozV8-Aer4N8C&pg=PA84&dq=pw50+manual&hl=en&ei=TCS2TcbdJ4PW0QG0z9jmDw&sa=X&oi=book_result&ct=result&resnum=1&ved=0CGUQ6AEwAA#v=onepage&q=pw50%20manual&f=false
OEM parts for Yamaha
Yamaha PW50 Owner Manual
Apr 09, 2012 | Yamaha PW 50 Motorcycles
98-99 Yamaha royal star, air fuel mixture screw settings, thanks
Hi, Rbmotorsport it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
7. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
8. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
Royal Star Airbox Modifications
Setting carb fuel mixture screws
Yamaha XVZ13TFL Service Manual
Yamaha Royal Star XVZ13CTV Owner Manual
Nov 02, 2010 | 2005 Yamaha Royal Star Tour Deluxe
2003 Yamaha TW 125 A/F mixture adjustment
Hi, Revasns2001 it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
Life On 2 Wheels
Yamaha TW125 1999 Service Manual
YAMAHA TW125 Owner Manual
Aug 23, 2010 | 2003 Yamaha TW 125
Will start with some amonut of choke on, but will ...
Carby carby carby!
Give the carby a flush with some Carby Cleaner. (retail 400g aerosol can)
Check condition and clamping of inlet manifold for cracks, warping or air leaks.
Reset Slide Needle one notch down.
Turn air mixture screw fully in and back out one and one half turns and try idling now.
When you get engine idling turn the air mixture screw in or out to the highest revs without use of throttle. Reset idle to optimum speed with throttle stop or idle screw.
Cheers.
May 19, 2010 | 2001 Yamaha SR 125
Garden Logo
125 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
