Question about Vehicle Parts & Accessories
Hi have a ir-tec ir 580q motion sensor is it possible to make it turn a 12 volt light on when motion is detected.thanks
    Habit-Forming:
  • 193 Answers
Yes you need to cut some tracks on the pcb look for the power relay and remove the track that sends the mains into this relay also note you can also run the whole unit an 12 v d.c by removing the voltage dropping cap and current limiting resistor.if you can send me an email with photo of the electronics i may be able to give more info.
P.hampton25@yahoo.com.au
Posted on Jun 07, 2010
Too much power and now lorex camera wont turn on
CAMMERA DESTROYED !! MOTION LIGHTS USE 120 VOLT AC POWER
CAMERAS USE 12 VOLT DC POWER
WRONG TYPE AND AMOUNT OF POWER !!!
Jan 16, 2014 | Lorex Home Security
Microwave oven activates LED motion light
All electrical and electronic systems give off some amount of radio signals as noise. You might have heard a light switch 'click' on the radio before. It's nothing to worry about, the problem is simply that the sensor is just that, a sensor: and its very close to the microwave - it's probably being set off because its so very close. A microwave uses VERY high power radio waves in a closed metal box to heat things up, thats how they work.
Either move it away, or ignore it. You can try setting the microwave on a very low power level and see if it still happens to confirm this theory.
Dec 17, 2013 | Costco Megabrite 12 LED Wireless Motion...
User manual for fl09sbk light
It appears this device is rate 10 amps at 230 volts = 2300 watts.
Use at least #14 wire and 15 amp breaker.
Connect wire at connection point on light.
Unit appears to have a transformer, and might make humming sound.
There is override located somewhere on unit. Possibly as a button on the motion sensor
If infrared motion detector requires separate wiring connection, then use following wiring illustration:
http://waterheatertimer.org/images/How-to-wire-motion-sensor-230V.jpg
Motion sensor will probably have 2 settings.
1st setting for sensitivity, so it will not activate when cat walks up driveway.
2nd setting for time duration, selectable from 30 seconds to 7 minutes
ML FL09SBK IP44 36W Fluorescent PIR Floodlight c/w Lamp
IP44 Low Energy Floodlight c/w PIR & Override.
Black finish.
T4 twist and lock lampholder.
36 Watt 6500k T4 spiral compact fluorescent lamp included.
(replacement lamp - product code FL09L).
Electrical termination via 10 Amp connector block within secure enclosure c/w cord grip.
PIR detection range of 12 meters at 2 meter height from ground.
Detection arch of 160 degrees.
Time range 30 seconds to 7 minutes.
Manual override.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Nov 12, 2012 | Woods Outdoor Lighting Timer
Tec b-472 gap sensor
use detection transmissve in the driver
Aug 13, 2012 | Toshiba TEC B-472 Thermal Label Printer
Honda 93 will start on for seconds but wont stay started.had to use a jump wire
Hello! Tell me where you placed the jumper wire?...Also is the Check Engine light on?...If it is (See photo below) push a paper clip into the 2 female pins of the OBD 1 connector...Turn on the key and count the Check Engine Light flashes...Example; 5 long flashes followed by 2 short flashes= Code 52...code list below...Guru...saailer
Code 0 and 11 Electronic Control Module (ECM)
Code1 Heated oxygen sensor A
Code 2 Oxygen content B
Code 3 and 5 Manifold Absolute Pressure
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECM
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
Code 30 A/T FI signal A
Code 30 A/T FI signal B
Code 41 Heated oxygen sensor heater
Code 43 Fuel supply system
Code 45 Fuel supply metering
Code 48 Heated oxygen sensor
Code 61 Front heated oxygen sensor
Code 63 Rear heated oxygen sensor
Code 65 Rear heated oxygen sensor heater
Code 67 Catalytic converter system
Code 70 Automatic transaxle
Code 71 Misfire detected cylinder 1
Code 72 Misfire detected cylinder 2
Code 73 Misfire detected cylinder 3
Code 74 Misfire detected cylinder 4
Code 75 Misfire detected cylinder 5
Code 76 Misfire detected cylinder 6
Code 80 Exhaust recirculation system
Code 86 Coolant temperature
Code 92 Evaporative emission control system
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Feb 19, 2012 | Cars & Trucks
Why wont my 1991 accord lx Rev past 3500 with check engine light on
Hello! See photo below of On Board Diagnostic 1 connector location...Push a paper clip into the two female pins...Turn on the key...The Check Engine Light will flash a two digit code...Example ; 5 long flashes folowed by 2 short flashes= code 52...See list below...When you have the code/codes send a comment...Guru...saailer...
Feb 19, 2012 | 1991 Honda Accord
Parkhurst 400W Security Floorlight staying on through day
the switch on this light is usually a photo cell it detects light when it sees darkness it sends a signal to the relay that turns on the light or its on a motion sensor if its only a motion sensor it needs a photo cell too maybe the photo cell is bad possibly the photo cell is bypassed test it by covering it does the light come on now uncover it does it go off
Jan 01, 2012 | Home
Code po 652
P0652 DODGE - 5 Volt Sensor Reference 2 Circuit Low
These 5-volt reference circuits are independent of each other outside the PCM, but are bussed together inside the Engine Control Module (ECM). Therefore a circuit condition on one sensor 5-volt reference circuit may affect the other sensor 5-volt reference circuits. The ECM monitors the voltage on the 5-volt reference circuit.
Possible causes
- Shorted sensor
- Shorted sensor circuit
- Failed ECM
When is the code detected? The ECM has detected an out of voltage range on the 5 volt reference circuit 2.
Hope helps.
Dec 02, 2011 | 2007 Dodge Sprinter
Vehicle Parts & Accessories Logo
29 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
