Question about Samsung SGH-d807 Cellular Phone
Screen freezes When I turned on my phone it just froze at the Samsung D807 screen and then I took out the battery and the SIM Card and waited for a couple of mins and put it back in and it stil froze. I have been using a 1 GB microSD card, could this be the problemor is it something else?
  • 2 more comments
  • Anonymous Apr 11, 2008
    I have the same problem
  • Mozo123 Jun 14, 2008
    Phone turned off by itself. Took out battery and sim card many time, tried turning on and off but all that shows up is the SGH-D807 screen. Please help. Where do i type in that pass code?
  • basb2dabone Jun 23, 2008
    The same thing and the phone gets hot if you leave it on with that screen. I tried the code offered and it didn't work. My daughter has the same phone and hers does it too, but when she takes out the battery it works.
  • philly2723 Sep 30, 2008
    i have the same problem, a solution is to give a passcode but where do you type it in?lease i really can't afford to fix it at a cell place.
    Brigadier General:
  • 7,752 Answers
No the memory has nothing to do with the issue...try a hard reset *2767*3855# is that does not work them take the phone and have the firmware reflash.
Posted on Jun 03, 2008
I tried to master reset, the phone froze, so i took the battery out and now it will not turn on. it gets to the last little tiny bit of loading and freezes.
hi mate
start the phone without the sim, and when the insert sim screen comes up, just put in the following codes
*2767*2878#
then
*2767*3855#
phone will reset, and should fix the problem.
If this was useful leave a good testimonial
cheers nick
Sep 09, 2010 | Samsung Memoir SGH-T929 Cell Phone
I have a Nokia 5800 Express Music, I tried restoring my phone to its factory settings and it froze for ages on a white screen with Nokia written on it in blue, I took the battery out, turned it on again,...
hey guy ptoblem is not in the sim or battery. it is the memory card who is the culprit.teke out memory card , back up data on computer ,format ihe memory card.
now copy the backed up data to memory card again .
switch on your phone now and then insert the memory card.
Everything is fine now.
For detailed explaition read this tip by clicking here
Sep 05, 2010 | Nokia N70 Cellular Phone
Need master password for my samsung sgh-c425
I found this off another site. I have tested this withy my D807 and it works.
1. If you have changed your phone password, change your password back to the default 8 zeros (00000000).
1a. NOTE (Modification here by my experience): Goto SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
2. Put a SIM card that is from a network other than the one your phone is locked to (I used a TMOBILE card from my buddy Darin)
3. When Incorrect SIM (I got invalid card and there was a sim card graphic spinning) error comes up, type *#9998*3323#.
4. White screen will appear with an exit option. Press the right softkey. (I ended up pushing the down key to get a menu)
5. From the menu that appears, select the Malloc Fail option. This will reboot the phone and the normal service screens will appear.
6. Type *0141# and then press the green call key. "Personalization" or "Personalized" will appear.
7. Turn off your phone and put the original SIM back in.
8. Turn on your phone. You will receive a prompt to enter a password.
9. Type 8 zeros (00000000) (This is because the SIM LOCK Mentioned earlier gets switched back on)
10. Completed. You have now unlocked your phone.
Easy as pie. Now you have an UNLOCKED Samsung D807 =) worked on my brand new 2 day old Samsung D807 phone.
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone.
Jan 03, 2009 | Samsung SGH-C425 Cellular Phone
SGH-D807
D807 Unlock Samsung SGH-D807 SOLUTION
for those that need this code. It's a lot cheaper than 29.00 from some of these websites....
Oh also guys I called Cingular (on hold for 1 hour with these losers) and they told me there is no way to SAVE phonebook contacts from the phone to your sim card. Now this really pisses me off. So I did some searching and found out that with the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card. Just thought you all should know as there is no menu option on the phone only you will need a data cable..
Mar 05, 2008 | Samsung SGH-d807 Cellular Phone
Freezing screen
remove the battery for few minute if it still dont work look in the manuel how to reset normally they put it in the back small push it with a pen hope it work cheers
Jan 18, 2008 | Samsung SGH-d807 Cellular Phone
Unlock code
    NOTE (Modification here by my experience): Go to SETTINGS, SECURITY, then SIM LOCK and disable this before proceeding.
  2. Put a SIM card that is from a network other than the one your phone is locked to.
  3. When Incorrect SIM error comes up, input *#9998*3323#.
    You now have an UNLOCKED Samsung D807
  11. With the studio software from samsung you are able to edit and move contacts from your phone to the sim and back. Or copy from the phone and put them on the sim card.
Jan 14, 2008 | Samsung SGH-d807 Cellular Phone
Unlocking my Samsung-d807
okkk now turn off your phone and remove sim card then start your phone without sim card then type this code *2767*2878#
Dec 11, 2007 | Samsung SGH-d807 Cellular Phone
My phone crashed
Call the service provider for a firmware update if your able to get it past the logo screen. I went thru 3phones and 2 had the problem.. I just hit the back top of the phone on the ground it went fine :-)
Oct 30, 2007 | Samsung SGH-d807 Cellular Phone
Turns on and Off by its self
try to tun it on by taking out memory card if its get strated then ur h set is hitted with virus format memory card if problem persists contact motorola service centre coz hardware issue
Sep 14, 2007 | Samsung SGH-d807 Cellular Phone
Samsung SGH-d807 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
