Question about Cisco 7941G-GE IP Phone
I can call internally but not externally on my network
    Champion:
  • 331 Answers
Hit "9" before dialing a number.
Posted on Aug 27, 2010
Usb hub heats up only when the external power is connected. It eventually fails. Removing the external power it works again. The external 5v measures corectly. Model # U222-004-R
There is a problem with an Ic on the board internally to the Hub. The
DC to DC converter IC inside the hub is defective, just replace the hub.
May 23, 2011 | Tripp Lite (U222-004-R) 4-Port USB Hub
Plugged new pinpad 1000se into my verifone vx570 according to instructions. Pinpad shows the moving arrow to indicate it is on. When I run a debit, it does not switch over to accept the customer's pin...
The terminal has a setting to tell it whether to use the external or internal pinpad. Yours is still set for internal. Call your merchant services provider and they will change the pinpad setting so that you can use the external PP100SE.
Apr 29, 2011 | VeriFone PINPad 1000SE Network Terminal
My computer beyond ISA server and also have note book, when cable wire not attach with router then my wire note book connect easily, when i put my cable connection in router, wireless indication light stop...
First of all, routers come with static ips... (the default is usually 192.168.1.1). So I am going to assume you mean your internet ip is a dynamic ip. Now Im not an ISA expert, so I may be wrong... but ISA should work with a dynamic external IP. And lastly if you cant get it to work, a quick call to your ISP will get you a static IP.
or
Try to configure the IP address of the external NIC in the same network as your router with the default gateway pointing to your router´s IP address.
In the internal NIC, configure the IP address of the internal network in the same subnet as your internal clients, set no default gateway and set an internal DNS.
In the internal network definition, you should put only the networks behind ISA trust interface.
Create access rules according to your needs.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | D-Link DIR-300 Wireless Router
Cannot connect via Remote Desktop Connection
due to the open ended nature of the question ... I am assuming you wish to connect to you rpc from another pc using RDP (Remote Desktop Protocol) or commonly known as remote desktop.
if connecting on internal network without any firewalls, start RDP and connect via name or ip address to the other computer. Follow the steps highlighted HERE and you can't go wrong for windows 7.
If external ... please note ... ports 3389 should be enabled on your firewall router. As there are plenty of routers/modems on the market, it will be too numerous to mention here, however, it is commonly noted as NAT'ing or Port forwarding to enabled ports 3389 and redirect the link to you local machine on the internal side of the network. from an external network ... just connect to it's public ip address and you shoul dbe able to connect to your internal machine via rdp. good luck ...
Sep 28, 2010 | Computers & Internet
Hoow do you open gateway MX6440. No audio. Bootup
Typically, a computer tries to "boot" from several devices:
1. 3.5-inch diskette
2. internal CD-ROM
3. internal disk-drive
4. USB memory-stick
5. network (if a "boot-server" can be found on the network)
6. external diskette
7. external CD-ROM
8. external disk-drive
So, in your case, either
* the "boot-order" _EXCLUDES_ your disk-drive,
* your disk-drive is not connected,
* your disk-drive is connected, but is "dead" (not responding)
Not being able to boot from the disk-drive, your computer probes, via the network, for a "boot-server". Finding none, your computer reports, in a strange way, that "network cable is not connected to a boot-server".
So, the "check cable" means that the Ethernet cable between the network-port on your computer and the boot-server may be "unconnected".
What this could mean is that your disk-drive is "dead".
Take the computer to a qualified technician, for more trouble-shooting.
Nov 18, 2009 | Gateway MX6440 (6585) PC Notebook
Dear i have a china phone prince a960 it have no network or low network, plz help me
This may be a cause of faulty antenna ( internal or external ) which is causing the phone being not able to recognize the network. Replacing the antenna will help.
Sep 04, 2009 | Cell Phones
Can the second card over ride the internal card?
Yes they are able to work with the internal and external smart cards. The internal is not really a card at all and is over ridden by the external device. In order to get the new smartcard to operate you need to follow the instructions that came with it. In some cases you may need to call dish and have them associate the new smartcard with the receiver and have it forced through on their end. Thanks for using Fix Ya.
Mar 16, 2009 | DISH Network 311 DTV Receiver
Internal led of ML350 server is glowing.......how do i resolve it?
Hi Franceso, plz specify
Is it powering ON ?
Which LED is glowing?
These leds are there on the front panel :
1 Power On/Standby button
2 System power LED
Green = Power on
Amber = System shut down, but power still applied
Off = No power
3 Internal health LED (Wave sign in BOX)
Green = Normal
Amber = System degraded. To identify the component in a degraded state, refer to system board LEDs.
Red = System critical. To identify the component in a critical state, refer to system board LEDs.
Off = Normal (when in standby mode)
4 External health LED (power supply)
Green = Normal
Amber = Power redundancy failure
Red = Critical power supply failure
5 NIC 1 activity LED Green = Network link
Flashing = Network link and activity
Off = No link to network.
6 UID LED Blue = Activated
Flashing = System remotely managed
Off = Deactivated
7 UID button
If it is Internal health led then any internal h/w issue is suspected.
If it is external health led then any power supply or power source related issue is suspected.
Also check the status of the server & its IML (Integrated Management Logs) in ilo (Integrated Lights Out ) if it is configured. (2nd RJ45 port in rear)
Also make sure the cabinet is properly closed.
Nov 18, 2008 | HP Compaq ProLiant ML350 G3 Server
Web cam
You need to NAT first. Just NAT internal ip :internal port with External IP :external port.
May 11, 2008 | D-Link DCS-6620 Network Camera
Cisco 7941G-GE IP Phone Logo
61 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
