Question about Toshiba Satellite A105 Notebook
HARD DISK SMART IS BAD
I have prblem with my laptop toshiba L-40 he is only 3 months old and there is now a problem with the hard disk what i cannot solve actualy i can solve but i do not belive that bying a new hard disk is only solution - the prblem is that SMART is reported bad and that i do not know what to do..
  • Davor Krstevski
    Davor Krstevski May 26, 2008
    No guys if you try any of diagnostic tools you will find out what you allredy know......So i must to say that changing of HD is best solution but.......
    There is more than one solution
    1. I am stil using a my HD and obviosly there are bad sectors so i knw that they are on 25 GB on 33.1 GB nad  89 GB so i try to do not put nothing in that sectors so computer is working fine....
    2 HD Regenerator exelent program who is fixing bad sectors witouth any harm on your sistem so after fixing you DONOT need to reinstal windows , even if there is magnetic damage on sectors this program is fixing.....
    3. HD Spinrite exelent program who is finding bad sectors and isolate them so there is no acces to them and normaly if there is no acces there is no problem....
  • 472 Answers
The smart error can be caused by alot of isses including:
  1. Over heating
  2. The laptop being dropped or the drive experiencing excess shock
  3. Just a bad drive to begin with
Try to get a drive monitoring tool from the net and check the temps etc.(check the manufacturers website) There are also tools to allow you to read what is in the smart record. Hirens Bootdisc also has a lot of tools to do alot of repairs on any computer.
Hope that helps =)
Posted on Apr 10, 2008
    Sergeant:
    Novelist:
  • 166 Answers
Hello there, SMART errors mean you need to contact whoever you purchased the laptop from and they will replace the HDD under warranty (as its only 3 months old). If you are able, I would recommend backing up any data now, before sending the laptop away for repair.
Hope this helps.
    Guru:
  • 1,342 Answers
Go to My Computer.
Right click on your hard drive and select Properties.
Select Tools.
Click "Check Now" to run check disk. If it finds any problems it will fix them.
Hard disk smart capable status bad
SMART is a hard drive utility built into some computer bios'. SMART is informing you that the hard drive is bad.
Jan 20, 2014 | Toshiba MK6028GAL 60 GB EIDE Hard Drive
SMART failure predicted on Hard disk 4 Toshiba: MK2035GSS-(S1)
It means pretty well what it says.
That the hard disk is failing, and you need to back up all of your data from it and get the drive replaced.
You'll need to refer to your manufacturer or manual to check what type of hard disk it needs.
I cannot stress that this is incredibly serious however, backup your data immediately
SMART is a tool that checks for hardware errors. it will detect when there is a Higher power consumption or temperature than usual.
Those things predict a hard drive crash, however it could take months for the drive to fail
(or it could be the next minute).
since it's a hardware problem the drive is going to die on you and you will have to replace it.
Since smart is sometimes triggered by the read heads of the drive that stick to the surface of the drive during boot up (witch results in Higher temp and power rates) you could:
open the laptop
get the drive out
'gently' tap the center a few times
reinsert and check for the smart message again sometimes there is a little dirt on the heads that cause the sticking problem
but, realistically, you're drive is failing and you should back up your data and start shopping for a replacement drive.
hope this helps
Oct 08, 2012 | Toshiba Satellite A215-S4747 Laptop AC...
Help got a toshiba satellite pro l450d I have no backup disk,fails tests on hard drive disk have attempted fac reset several times with no joy help plz
If the hard drive failed a SMART test then the drive is probably bad and needs to be replaced. Then you will need to contact toshiba to buy a set of recovery dics and reinstall windows from them.
Jul 12, 2012 | Toshiba Satellite P105-S6197 Laptop
Errror code 1000-0146 dst short test
If the "short" ("brief") test fails, then the disk-drive is _really_ in bad condition, i.e., not suitable for normal usage, due to its "old age". Copy all the data files from it, to another disk, or to DVD-writable disks, and then replace it.
Feb 20, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
Smart failure hard disk 4 :wd1600bevt-222ct0-(si)
The error S.M.A.R.T. refers to Hard Drive hard drive that has detected damage to the disk and failure of the drive is imminent.
If the computer is booting to Windows after the SMART error, then back up all data on the disk immediately. The hard drive will need to be replaced to resolve this issue.
Also, I suggest that you start the Computer to BIOS and check whether the Hard Drive is detected in BIOS.
If the Hard Drive is detected in BIOS, then try to perform reinstalling Windows supplied in your computer once before getting the hard drive replaced.
Dec 20, 2010 | Toshiba Satellite A215-S5822 Laptop
Hard drive from gateway solo pro 40 gig will it work in toshiba
I'm pretty sure it will. The only thing is that Gateways of that generationn used a custom connector which plugs onto the hard disks standard IDE / ATA connector.Just pull this extra connector off and you can use the disk in any machine.
Also ,Toshiba used similar adapters,so if Toshiba's using one on your model,then you'll need to palce the toshiba adapter onto the hard disk from your Gateway. You may also have to go into your BIOS ,and make sure the BIOS recognizes the disk if your BIOS isn't already set to "auto detect".
Mar 28, 2009 | Gateway Solo 9300 Series (5501056) Plug-In...
Smart failure predicted on hard disk toshiba mk4025gas ( pm )
This means your hard drive is bad or about to go bad and needs to be replaced. If you can still access the drive, immediately back up anything important to you. You will then need to replace the hard drive. Thanks and please take a moment to rate this solution with a fixya rating, even if the news isn't what you wanted to hear. Thanks! :c)
Feb 14, 2009 | HP Business Notebook NX9110 Notebook
Hard disk capacity increase
yeah you need to replace the old hard disk to new IDE 120GB hard disk.
Jan 20, 2009 | Toshiba 100GB Laptop for Satellite 2400,...
I need this driver please
TRY TO CHANGE THIS IN SET UP
Nov 08, 2008 | Computers & Internet
Toshiba Satellite A105 Notebook Logo
385 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
