Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
you need to have a video capture card installed at a computer input the video output of your cam to the video capture card video in.on the software of the card play the video and capture the selected video image .thats it.
can mean that the memory card is locked. take out the memory card and check for a lock slide at the sides of the card that you can adjust to a lock and unlock position, then test the card again.
Ok, this means that the memory card is locked. Her is how we fix this problem. If you take out your card from your camera,you will see that there s a little switch on the side.
Just push the switch to the other side to unlock the card. This should do the trick.
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
most camera data cards have a 'write protect' slide switch on the side of them, which if it is in the 'write protect' mode, nothing can modify, or put new files onto it. Basically what it's telling you is that you can't take pictures with that card until you pop it out and slide the switch to an 'unlock' or 'non-write-protect' position.
yeah there should be software on the olympus site.
In fact I have the 310 and dont use any software.
Go to my computer > onto your cam > and copy your files off manually.
