Question about Hitachi Heating & Cooling
Hi i have a hitachi RA-3186CHA room air-conditioner heat/cool if u turn it on fan works fine but when put on HEAT OR COOL makes a loud errrrrr noise then just blows fan then 30sec or so later makes the same noise like its trying to kick into heat or cool but cant
    President:
  • 1,469 Answers
Is the air conditioner completely dead? See section 1. Is the thermostat knob turned to the proper setting? Is the compressor motor running? The compressor is a football-sized case with no apparent moving parts. It is located inside the air conditioner at the center. Is it humming or making any kind of continuous noise or causing the lights to dim? If it is making a continuous noise, and your air conditioner is still not cooling at all, there may be a serious problem with one or more of these areas:
Compressor Condenser Evaporator These items are not user serviceable. You will need to contact a qualified appliance repair technician to repair these components. If the compressor is not running but you do have power to the air conditioner there may be a problem in one or more of these areas: Compressor Overload and/or relay Thermostat (Open thermostat) Burnt wiring Bad selector switch Capacitor.
Take care.
Posted on Jun 07, 2010
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
Kenmore 12,000 BTU Room Air Conditioner ENERGY STAR
How many Square Feet is the ac rated for?How large of room are you trying to cool??
May 27, 2010 | Heating & Cooling
My LG 7000 BTU Heat / Cool Window Air Conditioner does not cool and the fan speed F1 will not work. Fan runs on F2. The heat works fine. Any suggestions?
You have a control board issue. You can get a new control board by Google searching the make and the model of the unit. There are several sites that sell them
May 24, 2010 | LG Heat cool Window Air Conditioner
Fan outside ac/unit
Hi; are You trying to cool or heat Your house. Also do You have a heat pump...need more info.
Jan 18, 2010 | Hitachi RAS-09UH Air Conditioner
Just had a new 3.5 Ton Goodman GSZ13-13 SEER, heatpump installed. Its working OK in Cooling, however whe switched over to heating mode the indor unit makes a loud grumbling sound. The installer stated that...
I install them every day and I have not had one make a loud grumbling sound. Sounds like you might have a low voltage (Thermostat) wiring problem. The only thing different inside the indoors unit from heat and cool is the fan speed, electric heat when on. The fan might be loose or out of balance and it only shows up at low speeds. Either way, the noise is not normal.
Oct 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Apr 01, 2009 | Fedders AEY18F7G Y Chassis Heat/Cool Room...
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
Centrex air conditioner
Here are some icon that may help you.
COOL- this icon cool your room.
Dry- this icon control the humidity in your room but limit the coolness in your room (24deg C).
Fan- this icon run for fan only.
Heat- this icon heat your room.
Mar 11, 2008 | Heating & Cooling
Cooling on and off
Behind the filter there should be a small metal tube that senses the temp. entering the unit sometime this is too close to the metal fins and sense the cold from the fins and not the air coming in. Make sure this is away from the fins and try a different temp. setting.And relocating the unit. These units tend to give off more heat that cooling because the hot air is returned to the inside of the room and not vented outside like window units.This is an  EdgeStar 12,000 BTU unit, correct?
Oct 22, 2007 | EdgeStar Portable Air Conditioner Heater
Heating & Cooling Logo
115 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
