Question about LG Dishwashers
What is the problem when the screen reads OE?
  • LG Master
  • 12,061 Answers
This means the Outlet cannot Dump out, to waste, or, in it is Blocked some where?
1. If the drain hose is kinked, water will not drain properly. Kinks will also catch food debris as it passes, clogging drain hose. Straighten any kinks or bends in the hose. Make certain that drain hose does not exceed 10 feet for proper drainage.
2. Check the drain air gap anytime the dishwasher is not draining properly. if the air gap is clogged the unit will not drain. The air gap is not part of the dishwasher. It is located on the sink and attached through the drain hose and garbage disposal. Not all homes are required to have an air gap installed.
3. Food residue or particles can prevent proper draining of dishwasher. Remove bottom rack and check unit for food debris or items that may have fallen into the bottom of the unit. Remove any items or food debris that may be preventing proper drainage.
4. If the unit is not leveled properly, OE Error may occur. Use a level to check sides and top of unit. if the unit is not level, adjust the leveling legs in the front and back (use leveling kit). Also check the mounting brackets. If one is tightened more than the other, it will offset the cabinet.
* Note: To adjust leveling legs on the front, use a 1/4" square drive wrench. Turn clockwise as needed to adjust level. To adjust rear legs, use a standard Phillips head screw driver. On the left side rear, turn the screw counterclockwise to lower the leg and raise the rear. To adjust right side rear, turn the adjusting screw clockwise to lower the leg and raise the rear of dishwasher. Using a level while adjusting the legs will help aid in proper leveling.
Posted on Jun 07, 2010
DRYER READS CODE OE
read your costumer manual then check what code oe means..
Mar 08, 2014 | Kenmore Dryers
What does oe mean on the front loader lg tromm and how do I fix it?
Not sure what the OE is, but I;ve been having the same letters flashing on my washer this week. I checked the filter at the bottom and it was totally plugged up ! I would check your filter.
Jun 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing machine 12401td front load-on its digital screen tells m
hello,
what this means is that
The "oe" is an error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
an also means indication that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
what you need to do to fix up this problem is to do what is call general clean up on it by unscrew the key (stroll) and then clean the dry and any form of water in then make sure that all wire are well connected to the position.
Good lock and thanks for using fixya.
Jun 03, 2010 | Washing Machines
It is not completing the cycle and flashin oe on the time screen its a lg wm 14336fdk
hello
The "oe" error code is an indication of a water temperature sensor error. There is a chance that there is a loose wire connection on the water temperature
mean while "oe" error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F).
however,what you need to do tp fix up the problem is to unscrew the washer then clean up all forms of dry and water you can seen in it with this the problem of the "oe" error code is solve .
please make sure that all form of power supply is put OFF before you can do this
thank you and thanks for using fixya.
My lg front load washing machine is reading oe
oe is drain error, which means that the machine is slow/or not emptying..Most likely you have to clean the pump filter...This is accessed via the small door at floor level..Unscrew the pump cover andclean the filter...Remember that any water will drain from the machine from here, unless the machine is empty...Leaning the machine back can help...Good luck...Nomess
May 20, 2010 | Washing Machines
Starts to run and when i come back it reads "OE"
just check in your user manual. there will be a trouble shootin section. just check over there what the code oe means and repost it again.
Sep 07, 2009 | LG WM-2277HW Front Load Washer
LG WASHER/DRYER
OE is a drainage error.
This can be anything from a plugged filter screen to a faulty drain pump.
The filter screen location and cleaning procedure can be found in your owner's manual or online at the LG website.
Aug 05, 2008 | LG WD-12126RD Front Load Washer / Dryer
Dishwashers Logo
81 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
