Question about Vehicle Parts & Accessories
How do you reset a Steelmate 838 car alarm?
Hi, I have a Steelmate 838 car alarm with a learning function. I used this function to enable it to use two new remotes these remotes will lock the car but not unlock it. Is there any way to re-set this alarm so I can go back to using the original remote?
short shadey
  • 421 Answers
SOURCE: Car Alarm
sounds like the drivers side key switch has failed remove the interior door panel and there will be a switch attached to the back of the key lock cylinder or around there it should be two or three wires also check the door jamb wire harness where the door closes for any broken or damaged wires, use a vot meter and see if you get power or ground to the opposite side of the switch when you use the key to lock and unlock the door if nothing changes and there is power or ground! at this switch i would replace it, i don't think there is one but if the car has a passenger side key hole try to unlock the car from that side and see if you get the same problem -jeff
Posted on Aug 31, 2008
doin12volt
  • 233 Answers
SOURCE: car starter not working
look under the dash for a small silver toggle switch....this is a disable switch for the remote start portion of the system..you may have kicked it / bumped it with your foot, causing the remote start portion to be deactivated. Just flip the switch the opposite way and try again..
Also, there may have been a pin style switch installed under the hood...Check to see if it is bent or broken, if it is, simply disconnect it and insulate the wire that was going to it.
This wire is used as a safety to keep the vehicle from remote starting while the hood is up..to keep people from being injured if the remote start is activated while the engine is being worked on.
Have whatever shop installed the system replace your pinswitch if that is the problem.
Posted on Dec 19, 2008
jmgldsmth
  • 1889 Answers
SOURCE: alarm remote dropped in water alarm enabled on car..no entry
open your remote soak the circuit board in 90% rubbing alcohol then blow dry on medium heat it should work as good as new
Posted on May 03, 2009
  • 33 Answers
SOURCE: How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Posted on Jun 20, 2009
raygin
  • 322 Answers
SOURCE: Jag S-Type -intermitent fault where the remote fob does not work
This does not sound like a fob fault - but a locking control module fault , either in the hardware or software of the unit. Get it checked at a Jaguar dealers. When unlocking using the key - as soon as the door is opened you should hear a chime sounding inside the car - this is a timer counting down to sounding the alarm. If you put your key in the ignition as soon as you open the door the alarm should not go off and the chime should stop. If it does not this again points to a fault in the locking controller.
hope this helps - good luck.
Posted on Jul 08, 2009
My car steelmate alarm goes on without any reason. How do i stop this
My car alarm had the exact problem; clean or replace the hood ajar sensor located right next to the windshield washer reservoir. I little rubber nub. I never even knew mine was there. I cleaned it and so far so good. You could also just purchase a new one, easy to replace with a 10mm socket.
Mar 21, 2016 | Cars & Trucks
My Hornet alarm doesn't chirp, activate, or go off anymore. I've tried to check the valet mode, but it doesn't do anything. The remote still locks and unlocks door's and it cranks.
My car alarm doesn't chirp all the time, but it still unlocks the ...
forums.anandtech.com > Social > Off Topic
AnandTech
Feb 3, 2003 - 11 posts - ‎7 authors
My car alarm doesn't chirp all the time, but it still unlocks the doors. ... Distributed Computing. ·, Security. ·, Social. ·, Off Topic ... The rest of the electrical systemseems fine. ... Just read the owners manual and find out to to re-enable the ... but like when I arm my alarm it arms but then it'll go off for no reason.
Alarm Troubleshooting Help Tips - Dr.Detail
www.drdetailshop.com/TROUBLE.html
When you try to start the car the alarm goes off.. It could be your battery. 3. Try to start no sound, nothing lights up, alarm doesn't work. It could be a loose battery ...
Viper Alarm won't chirp help!! - 12 Volt Forum : Car security ...
www.tintdude.com > ... > 12 Volt Forum : Car security / Convenience
Sep 11, 2006 - 7 posts
posted in 12 Volt Forum : Car security / Convenience: Hi I am new to this site ... Myproblem is when I lock it it won't chirp or roll my windows up ... If I hold the lock button the siren will go off,and if I press and hold the AUX my windows will go down. ... It won't chirp when activated or when I hold the arm button.Missing: hornet
How To program DEI Viper Python Avital Sidewinder Valet ...
? 3:34
https://www.youtube.com/watch?v=r01ntAXGxBw
Mar 10, 2011 - Uploaded by Lessco Electronics
hi I have the viper 7142v alarm system,tge problem is I only had one remote,I ordered a spare but ... My alarm only chirps when i am programming lock and unlock functions. it does not ... As soon as I connect car battery my alarm goes off. ... I obviously don't have a remote, and it doesn't have a valet switch.
Jan 06, 2016 | Vehicle Parts & Accessories
Hi I have 2003 Rav4, I lost transponder key with the remote locking. Made another key without remote locking. Bought remote locking kit from third party and need to fix. It contains 2 remote and one device...
for a start,the transponder KEY, HAS to be coded into the car to start it.the remote is a seperate item but works in conjunction with the key.buying a seperate system is a waste of money,as it CANNOT be used in conjunction with the fitted system.buy a remote and get it coded with the spare(s) into the car, by a dealer that can do the job.the alarm works this way....the remote has TWO codes one fixed the other rolling,every time you operate it the rolling code changes(stops others from "learning")the fixed code allows the key to be recognised when put into the ignition and start the car(if the remote battery goes flat you can still start the car with the key but the alarm may sound if the doors have been locked by the remote).without the remote/key the car is effectively dead.stops theives from stealing your car cos they need to replace the whole ingnition system to get it going.
Jan 26, 2011 | 2004 Toyota RAV4
I need an installation manual for a steelmate 858 remote start alarm system
car alarm installation manuals for steelmate car alarm 858
Oct 11, 2010 | GPS
2006 kia spectra. The power door locks
security ----encrypted software dealer only
Dec 03, 2009 | 2006 Kia Spectra
Car Alarm User Manual aolin al 838
I have steel mate car alarm system 838, it locked my doors and I cnat open them.
can you help
thanks
jose
Mar 24, 2009 | Vehicle Parts & Accessories
My battery died after recharging it the alarm buttom needs to be reset. I need to know where the reset buttom is
HI ! I haven' t researched your car for you just yet !
I thought Id quickly mention the common method for reprogramming your alarm & remote, If you still require assistance then just ask me and I will find more about your car :)
Common Methods for resetting/re-learning code
  • Factory Fitted Alarms/ Central Locking / remote comes on ignition key.
Insert ignition key , turn key to accessories / red , press & hold lock/unlock for a few secs.remove key,exit vehicle and try un/lock doors &/or alarm (Some models differ slightly & require engine on or manual use of door locks whilst resetting.
  • Aftermarket /Non-Factory / remote is separately operated
Most use a small back-up battery usually located within the loudspeaker/Alarm unit itself under the bonnet,
Remove this battery for a short period to reset the remote code
The access panel for the backup battery is never in an obvious place. look carefully :)
Jul 14, 2008 | Hyundai Sonata Cars & Trucks
Vehicle Parts & Accessories Logo
980 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
