Hi my keyboard is typing wrong keys when I pressed them...not all.but some keys when shift key is pressed along with 3.It is not printing hash..instead printing someother character. Also if I press Shift+2 it is not printing @,instead it is printing @ when I press shift+''. Thats my problem.Please send me as soon as possible.Thank u.
  • BlessAlways Jun 07, 2010
    Sometime, as you continue using your computer, the keyboard and mouse drivers get corrupted due to viruses, so the keys can get swapped. So try download the keyboard drivers and installing them or re-install the operating system.
    Novelist:
    Champion:
  • 250 Answers
Did you check your layout options ? Go to control panel, then regional options, then Input, then select the right layout.
Make sure you do not have several active layout, you might have switch the layout with a keystroke ! Thanks and have a nice day Julien
Posted on Jun 07, 2010
What is "FN" key
Most laptop keyboards have a key marked "FN" or "fn". This is just another shift key, like the shift, control, and alt keys. If the instructions say something like "Press fn+F1" then press and hold the fn key, press and release the F1 key, then release the fn key. Exactly the same type of procedure as when the instructions say something like "Press Control+P".
Mar 19, 2013 | Computers & Internet
The @ symbol is on the wrong key it is on " key ,
Hold down the ALT(ernate) GR(aphic) key (to the right of the SPACE BAR).
Hold down the SHIFT key.
Press the '@' key.
Release the '@' key.
Release the SHIFT key.
Release the ALT GR key.
Feb 26, 2011 | Acer NSK8458AN Keyboard
My nb100 laptop. keyboard some keys not working.
There are various ways of solving this issue. Some of them has these broad explanation.
Problem #1 - My Laptop Keyboard Keys Not Working
Sometimes you may find certain keys of your laptop keyboard not working properly. You type those keys but there is no output on the screen or you need to press these keys firmly to get a result. You face this problem if you accidentally spill any liquid substance on your keyboard, or due to dust accumulating on the inside of the keys, pressing certain keys really hard while playing games or even due to absence of lubrication. Therefore you are suppose to maintain your laptop keyboard by cleaning and lubricating it regularly.
Troubleshooting Steps
  1. To start with, take out each key out from the laptop keyboard. Use a small screwdriver to carefully pry each key by making it loose. As they become loose, keys will simply pop off. Also, take out the rubber piece present under every key. Keep the keys and rubber pieces in different containers.
  2. Once you have removed all keys from the keyboard, you will have to clean the keyboard from the inside. Use cotton swabs or ear bubs and slightly dip them in water. Avoid getting them too moist, as excess water can damage the keyboard. Meticulously clean the whole keyboard using moist cotton swabs, laying extra emphasis on key spaces.
  3. Now, start cleaning keys you had earlier removed and kept in the container. Use foam rubber and lighter fluid to clean each key alone. This will help in removing any sticky substance present on keys. Apply any household cleaner on these keys and let them stay for about 15 minutes. After this, wash all the keys properly using hot water and let the keys dry completely.
  4. The small rubber pieces which you took out earlier and kept in the container have to be thoroughly rinsed in warm water, after you have sprayed a household cleaner on them. Soak these rubber pieces up in paper napkins so that they dry quickly.
  5. To lubricate the keys, place all keys (facing top-down) on a flat surface. Apply mild lubricant from all sides, on all keys and leave them to dry. Avoid applying too much lubricant instead go for a light coat.
  6. Similar to the manner in which you lubricated the keys, apply mild lubricant on the keyboard surface and let it dry.
  7. Once you have cleaned and lubricated all the parts, carefully reassemble the laptop keyboard. Begin with placing all rubber components on the keyboard. Next, fix all keys in their respective positions cautiously securing the wire in these keys. Use your finger and press down all keys, one at a time, firmly so that they fit properly in the slots. That is it.
The complete process will take you a maximum of 2 hours. Cleaning and lubricating the laptop keyboard in the above prescribed manner once a year, can prevent many 'laptop keyboard not working' situations.
Problem#2 - My Laptop Keyboard Types Wrong Characters
When your laptop keyboard types wrong characters, it is because of a software problem and not a hardware one. If you accidentally press specific keys on your keyboard, it can activate a particular function responsible for the problem.
  1. Select the control panel option
  2. Click on ? 'Regional and Language Services' ? 'Languages' ? 'Details' ? 'Key Settings'
  3. Choose the option 'Switch Between Input Languages' and click on 'Change Key Sequence'
  4. Make sure that all the check boxes in the window are unchecked and repeat the same for 'Switch to..... (Keyboard Type)'
  5. Click ?'Ok' ? 'Ok' ? 'Apply' ? 'Ok'.
Problem#3 - My Laptop Keyboard Types Numbers Instead of Letters
This is another laptop keyboard problem due to some software issue. It is possible you may have enabled a digital lock unknowingly.
Pressing the 'Function' key along with the 'Num lock' key (Fn + Numlock) or press the 'Function' Key along with the 'Shift' and 'Num Lock' key (Fn +Shift + NumLock). This will disable the lock and consequently solve your problem
Dec 20, 2010 | Computers & Internet
I get the wrong symbol when typing on my new dell
Hold-down the ALT GR ("alternate graphic") key, to the right of the space-bar, and press the '2' key, release the ALT GR key, and you should get '@'.
Jan 23, 2010 | Dell 0Y3740 Keyboard
The keys are not synchronised properly. The @ key and the " are typing each others symbol. ie I have to press shift 2 to get the @ symbol and vice versa.
you are using a usa keyboard.
if you want to use the uk keyboard layout change the regional settings, go to languages and there is an option to change the keyboard.
uk keyboard will print " when pressing shift+2
Jan 12, 2010 | Dell 0Y3740 Keyboard
Can't type anything without weird things happening the \'p\' prints,
hi, check that Sticky-keys arent turned on.
to toggle Sticky-keys on and off, press the shift key 5 times fast, then either Disable the sticky-keys tickbox, or click Settings for more configuration settings.
when sticky-keys are enabled, you can press shift and release, and the shift key is still enabled. this also goes for Alt, and CTRL.
so if it is enabled, pressing P will attempt to be Ctrl-P - which is print.
Sep 10, 2009 | Acer NSK8458AN Keyboard
My keyboard letter types wrongly to type @ I have to press shift and 2
UK keyboards use a different key for @.
If you wish to change the keyboard layout, you can do this by right clicking on your taskbar and select "language bar". When this is done, right click on the keyboard symbol and select "settings". Change the default language (to UK) and your keyboard will type correctly.
Jul 18, 2009 | Gateway 7001433 Keyboard
Compaq keyboard
Try pressing the ALT GR-key instead of the up (shift-key).
Sep 04, 2007 | Compaq 118003-008 Keyboard
Datalogic Heron D130 (Barcode Reader) Header setup
Whether or not you can set this feature depends on which interface type you are using if you are using wedge interface then the procedure is described below: The extended Header/Terminator keys for Wedge Interface users can be customized by defining them through a simple keyboard setting procedure. For example, the Numeric Keypad keys can be set for use as Headers or Terminators by substituting the default extended keys using this procedure. The type of computer or terminal must be selected before activating the keyboard setting command. Press and release a key to set it. Some characters may require more than one key pressed simultaneously during normal use (refer to the manual of your PC or terminal for keyboard use). The exact sequence must be indicated to the reader in this case pressing and releasing the different keys. Example: If one has to press the "Shift" and "4" keys simultaneously on the keyboard to transmit the character "$" to the video, to set the "$", press and release "Shift" then press and release "4". Each pressed and released key must generate an acoustic signal on the reader, otherwise repress the key. Never press more than one key at the same time, even if this corresponds to the normal use of your keyboard. Press "Backspace" to correct a wrong key entry. In this case the reader emits 2 beeps. Note: "CAPS LOCK" and "NUM LOCK" must be off before starting the keyboard setting procedure. "SHIFT" must be repressed for each character and cannot be substituted by "CAPS LOCK". Check page 31-33 of the "heron reference manual", downloadable near the bottom of this link page; http://www.datalogic.com/_vti_g2_dwnlDett.aspx?idCF=1&idC=44&rpstry=13_ Hope this helps :)
Mar 19, 2007 | Datalogic Heron D130 Handheld Barcode...
Computers & Internet Logo
394 people viewed this question
David Payne
David Payne
