Question about LG KC910 Renoir Cell Phone
Security lock this hp is locked.. security lock, how may i release it?
  • 112 Answers
Check for master code in manual otherwise contact your manufacturer
Posted on Jun 07, 2010
I have a brand new Travel Pro suitcase. I want to set the combination lock. How?
Some Travelpro bags come with an external lock upon purchase included in the user information package with the user manual and the add-a-bag strap or hook. This external lock can be looped through the zipper openings to secure your bag. To set the lock to your combination, follow these steps.
  1. External Travelpro Lock:
  2. Unlock the mechanism by pulling up on the metal lock rod. The 3 dial combination must be set to (0-0-0) factory combination if new, or the existing combination if used to unlock.
  3. Once released, rotate the lock rod to align with the notch of the dials, usually perpendicular to the long side, or about 90 degrees from its lock position.
  4. Select a new 3 digit combination.
  5. Press down the lock rod all the way and hold in that position while you turn the dials to reflect your new combination. NOTE**The lock rod must be held down all the way until you have your 3 digit combination in place, otherwise an unknown combination will be set while you adjust the dials.**
  6. Once your new combination is in place, release the lock rod. This sets the new combination.
  7. Return the lock rod back to the locking position and double check that your new combination does lock and unlock.
  8. Scramble the dials in order to keep your luggage safe and secure.
Jul 01, 2017 | Luggage & Travel
Phone is locked
Hi, What kind of lock has your phone been locked to?
If it is a security lock, You can take it to a local mobile store. They would do a master reset and release the security code. If it is a network lock, You can unlock it safer and easier using unlock code. You can get the unlock code from www.classicunlocking.com/sony-ericsson/rs17wp8/ at affordable cost with easy unlocking instructions.
Oct 10, 2012 | Sony Ericsson Cell Phones
How do you lock it?
Hi Celsa,
Please follow the below instructions to unlock and lock depending on the series of sentry fire safe security you have.
H & F Series:
To unlock and open:
1. Insert key in lock and turn counterclockwise.
2. Apply downward pressure on top of the safe, while
pushing the latch in to release.
NOTE: Due to compression of the gasket, the
unit will require slightly more force
than a safe that does not have a gasket.
To close and lock:
1. Close and press down on lid to engage latch.
Safe can now be transported without locking it.
2. Insert key in lock and turn clockwise.
HD & FD Series:
To unlock and open:
1. Insert key in lock and turn clockwise.
2. Pull up from bottom
of latch while pushing
down on lid to release.
To close and lock:
1. Close and while pushing down on the lid, press down on
the latch until it is secure.
2. Insert key in lock and turn counterclockwise.
For the complete manual with images you can click on this link :- http://bit.ly/lzdBP2
Hope this helps.
May 11, 2011 | Sentry 1110 Fire Safe Security Chest
HP Photosmart 3310 All-in-One Printer - I opened the ink cartridge door & it now seems locked in open position - won't close.
Your printer does have a lock that clicks in when you open the printer to replace ink catridges. The User Manual has no specific comment on steps required to release the lock.
Is there a release tab/button that you grip when lifting? If so, suggest you try pressing this same release as you lift the cover, lifting slightly higher to see if the lock will disengage allowing you to close.
If no release tab/button simply try lifting slightly higher as above to see if the lock will disengage.
If either of these does not resolve isse I would inspect losely to see if there is a way to disengage the lock; simply using more force may result in damage.
Dec 22, 2010 | HP Photosmart 3210 Printer
Battery release latch locked in open -hp pavilion dv4 1313dx
The same thing happened to my HP laptop. The sliding lock mechanism relies on three little hooks to hold the battery in place. What had happened to mine was that one of the hooks (the one nearest to the switch) had gotten stuck (this is quite difficult to explain, but just examine the three little hooks closely and you'll notice it the difference.) I freed it simply by pushing it with my thumb to unsnag it. The battery is now securely back in place, where it will stay!
Jan 13, 2010 | Computers & Internet
How to open the evo 500 compact black box
Hi maybi,
The evo's have two senarios that you may be facing.
First is Smark Cover locking. If you enable the Smart Cover Lock and cannot enter your password to disable the lock, you will need a Smart Cover FailSafe Key to open the computer cover.
You will need the key in any of the following circumstances:
Power outage
Startup failure
PC component (for example, processor or power supply) failure
Forgotten password,
If you don't have the Key, To obtain a FailSafe Key:
Contact an HP reseller or service provider.
Refer to the HP's Web site (www.HP.com) for ordering
information.
Call the appropriate number listed in the warranty.
To open the computer cover:
1. Turn off the computer and any external devices.
2. Disconnect the power cord from the power outlet, and disconnect
3. Using the Smart Cover FailSafe Key, remove the two
tamper-proof screws that secure the Smart Cover Lock to the
chassis.
4. Remove the Smart Cover Lock.
To reattach the Smart Cover Lock, secure the lock in place with the
tamper-proof screws
Or the non- Smart Cover Case:
1. åWARNING: Before removing the computer cover, ensure that the
computer is turned off and that the power cord is disconnected from the
electrical outlet.
2. Turn off the computer and any external devices.
3. Disconnect the power cord from the power outlet, and disconnect
4. Press in the button on each side of the front bezel to release the
quick release cover latches.
5. As you slide the computer cover forward, release the buttons and
allow them to return to the original position, then lift the cover up
and off the unit.
✎ To replace the cover, reverse this procedure.
f7b910a.jpg Good Luck,
Mark
Oct 16, 2009 | Compaq EVO 500 DT/MT S478 P4 Motherboard...
I just bought a 2004 Impala and the remote will not open the trunk. Neither will the release button on the dash over the hood release.
sounds like the power release in the trunk is not going bad some of these cars have a key lock inside the car that locks the trunk from the power mode
Aug 31, 2009 | Vehicle Parts & Accessories
Card lock release
I have a hp 733 photosmart and to release my card lock I just use my thumbnail to slide the door open a the depress the card slightly and the card is released enough to remove the SD card. Hope this helps you.
Oct 03, 2008 | HP Hewlett-Packard Photosmart Camera Dock...
Keypad lock
To lock the keypad so that you don't accidentally call anyone, simply press AND HOLD the red "end call" button.
To release the lock, press the left menu button, then hash (#)
Sep 15, 2008 | HTC S710 Smartphone
Trunk latch locked
It seems someone has activated the lock release lever security. This prevents entry into the boot from inside the car as a security measure. You do need the master key which is the key that works in every lock not just ignition ie glove box. Cheers Nick
Aug 14, 2008 | 1997 Toyota Camry
LG KC910 Renoir Cell Phone Logo
61 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
