Question about Lexmark X5070 ALL-IN-ONE InkJet Printer
Will not switch to copy mode
My Lexmark printer will not switch from fax mode to copy mode or scan mode. I have turned it off and on again several times, but it will not change to copy mode.
    Genius:
  • 1,087 Answers
Make sure the Fax Mode button is not stuck in the printer. If not, unplug the power supply of the printer. The power supply is the black box behind the printer where the power cord is attached. Then, hold down Start and Cancel buttons at the same time while plugging back the power supply in the printer. Hold down the two buttons firmly while the printer is powering on until Language Selection appears on the LCD screen. Then, release the two buttons. Choose your preferred language. Set your printer like how you set it the first time. If this doesn't help, I strongly suggest you contact Lexmark Technical Support for further assistance.
Posted on Jun 07, 2010
I cannot get the printer to operate in copy, fax or scan modes.
Seems there is a fault in the software. Have you tried a full reset of the printer?
Mar 13, 2016 | Dell 2335dn Multifunction Laser Printer
Grinding noise in copy mode?
The Grinding Noise has something to do with the scanner not the Printing Part, I think the scanner could have something stuck on the moving tray....!!!!!!
Apr 18, 2013 | Lexmark X8350 Print, Scan, Copy and Fax...
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
My lexmark X7170 keeps printing black pages instead of what I am trying to copy. It used to be black stripes but now is completely black.
Do you get the same result/image when scanning to your computer? Remove the cartridges from your computer. Then close the printer cover.Unplug the power adapter from the printer.
Wait at least 10 seconds before replugging the adapter into the printer. This will give enough time for the printer to reset. When the printer turns on, reinsert the cartridges. Try to make a copy or scan again. If you're still getting the same result, I would strongly suggest you to contact Lexmark technical support for additional assistance.
May 09, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Will print but not copy or scan
sir,
click this link to solve your problem
thanks
good luck
Nov 26, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark x7350 will not scan, fax or copy
If under warranty contact mfg for warranty repair locations
Sep 09, 2017 | Lexmark X6170 All-In-One InkJet Printer
Printer want print
OK Try this
Resetting purge counter:
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
Need help on my lexmark x 4270
Fax does not require installation on the PC. Driver for Vista is here: http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:438:0:0
Aug 29, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X5070 ALL-IN-ONE InkJet Printer Logo
135 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
