Question about Compaq 217843-001 (  217843-001) Motherboard
My computer displays a fan not detected and does an automatic shut down
Recently my computer will display an automatic shut down for my computer saying fan not detected, but the fan is running...after about 10 mins it will allow me to get back on for about another half an hour or so before doing it again
    Champion:
  • 207 Answers
Install speedfan to check rpm of the fan in question. It might be running but slowing down as it heats up. http://www.almico.com/speedfan.php
Posted on Apr 10, 2008
    Genius:
  • 1,913 Answers
Your pc got hitting event.
so pls put extra cooling fan.also check your processor sitted correctly and in working condition.
When Win XP restarts display is black.
Have you considered a Exorcist? Have you cleaned the fan, vents, heatsink recently? Take a look at this it may help in troubleshooting: http://www.youtube.com/watch?v=2Yi6GNFcP3w
Apr 28, 2013 | Acer Aspire 1640Z Notebook
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
The pc not starting up as it should. it displays on the black screen, 511-CPU fan not detected. I use F1 to continue the start up. but shuts down in about 10 minutes.
withtout the fan the computer will overheat and shutdown.
open the case and see if the fan moves at all.. is it to clogged to move. can of air will fix the problem. blow the dust away then vacume the stuff that falls out.
if not dirty then you need to replace the fan.
Aug 29, 2011 | HP Compaq d530 SFF PC Desktop
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
I've had a bad dust problem and my cpu fan began making a loud whirring noise and finally the computer shut down altogether. Took the cover off totally cleaned out the dust and turned the power back on....
If the computer detects overheating or fan failure it will shut down automatically. If you replace the fan you should be fine. Remove your old fan and try to get one that connects the same way, some of them connect directly to the heat sink, others to the motherboard.
Apr 16, 2009 | Sony CPU FAN CPU Fan
When booting i hear a beep sound then it displays F1 to resume or F2 for setup...i just keep on rebooting and displaying the same thing till it goes to Windows, but after a few minutes it automatically...
Just get your CMOS battery checked with your vendor.
I assume that your laptop is atleast an year old.
If any error message is displayed please let me know, this way, i would be able to provide you exact solution.
Hope this helps.
Thanks.
Mar 19, 2009 | Acer Aspire 5100 Notebook
My new 21' flatscreen monitor keeps shutting off :(
Usually when an LCD display shuts off on it's own this can be a power supply issue. I would say if you checked all the connections you may want to contact the manufacturer. If it is only a few months old then you should be able to get it replaced under warranty.
Also, you may have an auto shut off feature enabled on the display itself. You may want to go through the display's menu to very that this is not the case.
Mar 08, 2009 | HP Pavilion F1703 17" LCD Monitor
Power,but nothing on screen
refix your ram after clean dust from it. aslo reset your bios settings,remove cmos cell for 15 minutes.then check.
Jan 04, 2009 | Intel Motherboard
Sony vaio VGN FS 570 no display
Try having your battery tested. There may be not enough power to run everything on your comp.
Anotherthing to consider, if your CPU fan isnt working the bios wont start the O.S. as the CPU will overheat and shut down automatically. Good Luck
Oct 14, 2008 | Computers & Internet
Gigabeat System Error Problem
Error message 0000020 - System Error displayed whenevr devide powered up. Only way to shut down is by turning battery off. Gigabeat Software on PC not able to detect device, not listed in Device Manager or as an external drive in My Computer. (As it normally is) Is there a way to reinstall firmware from PC when device not detected?
Aug 14, 2006 | Toshiba Gigabeat MEG-F20S MP3 Player
Compaq 217843-001 (  217843-001) Motherboard Logo
100 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
