Question about ASUS WIRELESS ROUTER |WL-520G - RT (WL520G)
Router Password forgotten
Hi I am wanting to connect my iphone to the main computer via Wi Fi and I cannot remember the password for the router. It originally was "admin" but I changed it and cant remember it. Any suggestions on what to do would be greatly appreciated.. Pam
  • 39 Answers
Pam, there is no way to retrieve just the password. You have to reset/reconfigure the router. Have you done router setups before? If not, I suggest you get someone to help you. If you want to try anyway, then have the printed manual next to you as you step through the sequence. Make sure you connect a PC to the router using an ethernet cable & confirm that the PC connects to the router. Admin is the user id. The factory default password is often "password" or "admin", but check on the manufacturer's site to be sure. Let me know if you have questions about any part of this.
Posted on Jun 07, 2010
I am trying to connect my iPhone 5 S to my wireless network and have forgotten my password. HELP. To connect to wi-fi I need a password and can not remember the password as this router was set up years ago
Firstly log into your router from your computer. If you don't know the username and password, try the default one which is Username: admin Password: Admin. Check under Wireless setting and you will see the current password listed there. You can change it to a new one if required. Just remember to save after you've done any changes.
Jun 11, 2014 | Cisco Linksys E2000 Advanced WirelessN...
Wireless g router network set-up
Follow this instructions:1. connect via hard wired connection using your PC (network cable)2. open your internet explorer or any browser.3. type the numbers 192.168.1.1 on the address bar4. you will be routed to your router's settings, type admin for USERNAME: and admin for PASSWORD.5. look for the basic setup/settings6. look for the wireless settings7. under your SSID comes the WEP or WPA-PSK option8. that is your wi-fi password, then modified it and remember the password you use for you will need to enter it on your pc when you are connecting via wireless connection.you can select ASCII for password. it should be alpha numeric or combination of letters and numbers.9. select save and apply. then you are good to go.
thanks for choosing fixya.com and kindly rate this post.
Jan 03, 2012 | Linksys Wireless-G WRT54G Router
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
I want to locate my wi fi password for my iphone.
I am assuming that you are trying to connect to the internet using the built in wifi instead of the 3G. To clarify, iphones don't have passwords for wifi. Wireless access points and wireless routers are the ones that have passwords. If you want to connect to the internet using an access point or router you must get the SSID of the router or access point and also the encryption and password to join said access point or router.
Once you have this information go to your iphone and select the settings icon. Then select the Wi-Fi, then turn on the wi-fi (if it is off), then under choose a network select "Other" and then type in the name (which is the SSID), tap on "Security", select the encryption that matches your access point or router (wep, wpa, wpa2, etc) tap on "Other network" (on the top left hand corner) to go back to the configuration page, and then type in the correct password.
Once you have done this your iphone will automatically connect to the access point or router whenever it is in range and connect to the 3G when it is out of range of the access point or router.
Hope this helps.
Aug 03, 2011 | Computers & Internet
I can not connect my i phone
From your problem description it looks like you want to connect your iPhone to your wireless home network?
Whenever you use a internet enabled application your iPhone will connect to the most recent used Wi-Fi network(access point/router).
If the last used network is not available, then your iPhone will list all available networks in range.
If you are in range of your wireless router, then it will be listed in the available networks box.
To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it. If needed enter a password. The password will be the security password you set on your router(WEP/WPA key).
If you do not know your password, you can read my tech article by clicking here. It will go over how to obtain your router password.
If there are no Wi-Fi networks available then your phone will use the cellular data network and fee's may apply.
Let me know if you have any other questions.
Regards,
G33k
Jun 26, 2011 | D-Link DIR-625 (790069292637) Wireless...
Hi am having prob on setting my WI-FI i forgot the WI-FI/WPA Key
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
May 05, 2011 | Computers & Internet
Hoe can i connect my ipone to wiifi on my belkin router
Wi-Fi settings determine whether iPhone uses local Wi-Fi networks to connect to the Internet.
Turn Wi-Fi on: Choose Wi-Fi and turn Wi-Fi on.
Join a Wi-Fi network: Choose Wi-Fi, wait a moment as iPhone detects networks in range, then select a network. If necessary, enter a password and tap Join (networks that require a password appear with a lock icon).
Once you join a Wi-Fi network manually, iPhone automatically joins it whenever the network is in range. If more than one previously used network is in range, iPhone joins the one last used. When iPhone is joined to a Wi-Fi network, the Wi-Fi icon in the status bar at the top of the screen shows signal strength. The more bars you see, the stronger the signal. Set iPhone to ask if you want to join a new network: Choose Wi-Fi and turn "Ask to Join Networks" on or off. Join a closed Wi-Fi network: To join a Wi-Fi network that isn't shown in the list of scanned networks, choose Wi-Fi > Other, then enter the network name. If the network requires a password, tap Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. You can type it manually by login onto the Belkin's network page using the browser and by copying the static and dynamic IP address.
Feb 05, 2011 | Belkin (F5D7230-4) Router (587009)
I have forgotten my dlink user password for my home network Help?
First connect your router to computer with ethernet cable.
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then go to wi fi security check your WEP code it is your password to connect wi fi network.
Let me know if you need more assistanse.
Thanks
Sep 13, 2009 | D-Link DIR-625 (790069292637) Wireless...
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
282 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
