Question about Hotpoint Aquarius WF000 Front Load Washer
When the machine goes onto a spin it makes a very loud noise and vibrates.
  • Hotpoint Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
Posted on Jun 08, 2010
What causes our front loading washer to make exceeding loud noise when it enters a spin?
Sounds like a bearing seal is going. The seal has ruptured and grease of seeping out. The loud noise is the bearings rubbing against each other without adequate grease to reduce the friction. Failure will come soon if it is not fixed. The vibration is coming from the friction and possibly damaged ball bearings .
Mar 11, 2015 | Washing Machines
Wash machine won't spin all the time and makes a loud banging noise.
Check to make sure that your clothes are not piled to one side causing the load to be off-balance. If that does'nt fix it then, It may be that your machine has a balance stabilizer on it that has worked its way loose or even off.
Jun 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a maytag mah8700aww washer,when it goes into spin,there a loud knocking sound
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
heatman101
Aug 13, 2011 | Maytag Neptune MAH5500B Front Load Washer
Washing machine makes a loud vibrating noise when spinning and sprays grease onto washing
It sounds like the main bearings have failed, try turning the drum by hand, if it feels rough or is niosy, then the bearings have failed.
Oct 25, 2010 | Hotpoint Washing Machines
Into the spin dry cycle a loud hammering noise appears. Immediately goes away when powered off and drum speed drops. Can you please advise. Regards Geoff
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Oct 05, 2010 | Hoover H130E Front Load Washer
Machine making a loud noise in spin cycle. We
Inspect the outer drum to see if one of your springs has popped off. You can also inspect the lower drum area to see if your vibration dampener has worn out or broken free. Also you may need to check your rear bearing just between the large pulley and the drom to make sure is hasn't separated from it's mount.
Mar 02, 2010 | Frigidaire ATF6000ES Front Load Washer
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Loud noise
it sounds like you have something stuck under the agitator thats causing a rubbing noise when it goes to spin or agitate.maybe a penny or something like that
Dec 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
131 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
