Question about Thermador SGS36GS Gas Cooktop
My daughter spilled some water on the cooktop. Now the electric flame igniter won't stop sparking (unless the burner is on). If I turn on the flame, the clicking/sparking stops. But as soon as I turn off the flame, the clicking starts again. Please advise!
  • Thermador Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 18, 2010
Large burner elements ignite, and igniter spark fails to stop, then the burner shuts off as if ignition failed. Tiny central burner element does NOT light at any time. Apparently the safety cutoff...
There is a thermistor that must be in the flame area that needs to get hot. When hot it will turn the igniter off and keep the flame on. Check it's location and if it is in the flame then it needs to be replaced. not sure about the central flame problem. could be the switch.
Sep 20, 2010 | Gaggenau 36 in. KG 291 Dual (Electric &...
One front burner ignites but the igniters continue to spark. when all other burners ignite the igniters immediately stop sparking. this problem started right after spilling some water on burner.
I would make sure you have wiped up all the water you spilled, You may need to take the burners off the stovetop and make sure the tiny little pinholes for the gas to come out are fully dry, Than re-assemble everything and try again.
Jun 06, 2010 | Cooktops
When i turn on a burner, it lights, but all 5 igniters continue to ignite
I have the same problem all but one burner. When using the other burners the igniters keep sparking after being lit. What do I replace?
Oct 04, 2009 | DCS 36 in. CTD365N / CTD365L Gas Cooktop
One of the igniters does not click. they were wet and popped the breaker over a week ago . all but one now clicks and lites burners. it was sparking a weekago and blowing the breaker.
Make sure the area of the burner base around the spark electrode is clean (use a fine sand paper). The little hole for the gas is open (use a paper clip). You won’t see a flame unless the burner head is on. If this doesn’t help, check the bottom of the spark electrode visually. Make sure the wire is attached to the electrode and is not loose (pull it a little bit.) If the wire or the electrode is damaged, replace it ($25). If not, locate the spark module and switch the connection with another one (they are different colors). If you get flame on the same burner, but not on the other one, replace the spark module ($60). When you work with electrical components, turn the breaker off. When you test, turn it on. Good luck.
Sep 14, 2009 | GE 36 in. Profile JGP962SECSS Gas Cooktop
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Feb 13, 2009 | Amana AKS3040 Gas Cooktop
Old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Dec 22, 2008 | Thermador PSC364GDZS Gas Cooktop
No Ignition
Dirt. Spilled oil, grease, milk etc. act as isolator and prevent contact between burner and casing (mass). You need to clean up burners, scrub all the dirt and make sure their seats are cleaned too (brass elements below burners).
Mar 14, 2008 | Cooktops
Thermador SGS36GS Gas Cooktop Logo
1,049 people viewed this question
Top Thermador Cooktops Experts
Justin Duby
Justin Duby
tom wright
tom wright
jasbo
jasbo
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
