Question about JVC RX-6020V Receiver
Digital input has no sound even though all settings have been set correctly
    Brigadier General:
  • 8,546 Answers
New install or new problem on old equipment?
ALL digital inputs or just one?
If just one, look to the source or its cable.
If everything is done correctly it should work.
Posted on Jun 07, 2010
Apex digital LD3288T
Check to see the set is on the right input---the one the Dish is connected to----input or source or even on the Dish remote it is set not to something other than the button for the Dish box.
Jun 07, 2012 | Televison & Video
Wenn I connect the coax cable the display show --------, and the Receiver can't detect the digital audio signal, even though I can mesure a PCM signal with the Osilloscope.
http://www.retrevo.com/support/Sony-STR-DH510-Receivers-manual/id/23637ci375/t/2/
Page 71
There is no sound from digital sources (from COAXIAL or OPTICAL input jack). • Check that the INPUT MODE is not set to "ANALOG" (page 52). • Check that the Analog Direct is not being used. • Check that the "A. ASSIGN" function is not used to reassign the audio input of another source to the selected input (page 53). • Set "ARC" to "ARC OFF" when no sound is output from TV OPTICAL IN jack during TV input (page 58).
Feb 07, 2011 | Sony STRDH510
Hi, just connected a Blu Ray player to my sytem. I connected the player via HDMI direct to the TV and the audio output direct into Optical 2 on the Denon. Problem is that there is no sound. Also...
We can't make assumptions about proper and complete setup if you don't explicitly mention the steps involved, so... did you assign and select the digital inputs properly?
http://www.retrevo.com/s/Denon-AVR-2803-Receivers-review-manual/id/363bh829/t/1-2/
Page 23 etc
BTW: I concur with your decision to send the video directly to the TV from the BD even though Denon and others expect it to make a hop through the receiver first.
Get into your BD and find its audio out setup. Make sure its settings for digital audio output bit rates, speaker presence, type, size, distance and bass-handling are set correctly.
Jan 30, 2011 | Denon AVR-2803 Receiver
I just bought a Playstation 3 for the first time. I have it hooked up through HDMI using an HDMI to DVI converter to my TV. It looks great, but there is no sound. Even hooking the optical sound output to...
On your PS3, go to the Settings tab, then scroll down to the "Sound Settings".
Once in Sound Settings, select "Audio Output Settings"
Here you should have 3 options: HDMI; Optical Digital; and Audio Input Connector
Choose Optical Digital
You should be all set.
Also, make sure after doing this your stereo is on the correct channel.
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
Speakers are the correct wattage. Speakers are attached to stereo correctly. Can't hear music from fm broadcast or from cd player. Is this easily fixed?
Many of the current stereos and receivers have a toggle switch for analog and digital sound input, and many of the devices that are coming out like HD FM, DVD, Blu-Ray players, some higher-end MP3 players...etc. can output in 5.1 or higher surround sound. In order to control the individual speakers in a system like that though they have to send the signal out in a form of data that has to be processed by the receiver before it can be sent to the speakers.
So all that being said if you have an analog (or normal) device plugged into a receiver but it's set to listen for a digital audio signal you won't hear any sound at all. It works the same way if you have a digital device hooked up to an analog input.
To fix this just look through the manual that came with the stereo and see if there's a way to make sure it's set correctly for the device. Some devices also have settings you can alter on them so that they can send analog or digital signals to the receiver. I would say to check into whichever part is newer, and easier to work with. Once you get them talking the same language you shouldn't have any problem with it.
May 20, 2010 | Audio Players & Recorders
I have hooked up the PS3 to my TV with the component cable. The audio is connected to a Denon digital audio device using an optical cable. I cannot get the sound to work, even though I have set up the...
I can't give you the exact steps without knowing the model of Denon receiver you are using, but usually you need to go into the setup of the AV receiver or amp and tell it to associate the digital audio input # you've plugged the PS3 into with a specific 'source'. The optical inputs will be associated by default to CD or DVD or CBL, but you usually need to go into the amps setup to specify exactly how you want it to use it.
I hope that helps.
Dec 19, 2009 | Sony Playstation 3 (PS3) Console
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Have picture and no sound from DVD player
You will need to tell your Denon AVR that you want ANALOG sound from your DVD player now.  Depending on what model AVR you have, it may be as simple as pressing a button on the front panel labeled "AUTO".  If not, the you will need to go into the menu settings and set the DVD input for digital sound to NONE.  Not sure why you would not want digital audio from your DVD player though.
Mar 15, 2009 | Denon AVR-2106 Receiver
OPTICAL INPUT ALWAYS SHOWS LINEAR PCM EVEN THOUGH SKY OPTICAL OUTPUT SET TO DOLBY DIGITAL. HOW DO I CORRECT THIS?
tried 2 expensive leads 30 and above then bought cheap one and it works perfectly ? very strange
Jul 20, 2008 | Televison & Video
Pioneer receiver VSX-D411
Yes techtod you are right you do have to tell the receiver what you want it to do usually on the front panel you can access set up menu and go into input set up This is an example Say you plugged the dvd into optical one or coax 1 you must go to the input that says dvd click down till you highlight dig input and then select optical 1 or coax 1 there can be as many as 8 digital inputs so just check wich one you plugged it into and then tell the amp then you should be back to watching your digital movies
Mar 21, 2008 | Pioneer VSX-D411 Receiver
JVC RX-6020V Receiver Logo
149 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
