Question about Canon LaserClass 2050 Plain Paper Fax
Cheak cover why - Canon LaserClass 2050 Plain Paper Fax
  • 1,219 Answers
When you open cover, from left inner side of cover is plastic nose, that fits into sensor hole. With screwdriver, remove 4 screws, remove fax cover, and put sensor in upper position.
Posted on Jun 25, 2010
HI, This is IRFAN, i have Canon IR 3300 copier machine i got a error e007 000, i know the that is fuser film rotation error, but, i had remove the Fuser unit (FG6-6040-000) from the machine and manually...
If you confirm about film's inside lubrication then cheak out for gear inside fixing drive assembly . open front door , open inner cover then open the drive assembly from the left and cheak the gears.
Aug 25, 2017 | Canon Ir 3300i 3300g 2800i 2800g 2800 2200...
My printers and cash drawers (printers on the network) won't function. All of them work indivudually when test pages are printed. How do I get the network to see them?
please cheak the following
for printer to weork in the network you need network ,network printing sharing driver, or apllication of printer i.e. software you are using it should share the network.
please cheak the following thing
cheak if you have a network then rj45 cable is attached or not on computer side .cheak it is blinking grren &orange light. green is for power &orange light is for data transfer
cheak you have shared your printer driver for network printing
cheak your software is compatible with network printing or not
waiting for your reply
thanks &regartds
vijay p. patel
Apr 06, 2011 | ACM Supplies POSMicro Premier Retail...
Printer shows red light
please cheak the following thing carefullly
1.cheak the cable connection
2.cheak the paper or label setting cheak whather it is alligned properly or not if that is not alligned properly then it will show error light
3.cheak printer configuration setting
4.cheak the printer mode you can also do the auto calibration of printer by using printer setting options
5.it may be sernsor issue. clean the sensor
thanks&regards
your faithfully
vijay p. patel
Mar 08, 2011 | Samsung CLP 300 Laser Printer
Printer si not working
PLEASE CHEAK THE CABLE CONNECTION
CHEAK THE PAPER SETTING
CHEAK THE PRINTER DRIVER IS INSTALLED ON YOUR COMPUTER OR NOT
CHEAK THE PORT SETTING WHEATHER YOU SELECT A USB,SERIAL OR PARELLEL
WAITING FOR YOUR REPLY
THANKS &REGARDS
YOUR FAITHFULLY
vijay p. patel
Mar 07, 2011 | Samsung ML-2510 Laser Printer
Envelope jams printer
cheak the cable connectivirty
cheak the paper seeting
cheak the printer configuration setting
if printer is to old then it is a issue of friction
thanks &regards
youur faithfully
vijay p .patel
Mar 07, 2011 | Brother DCP-7020 All-In-One Laser Printer
1990 Accord all forward gears work fine but Reverse makes a clicking noise and the car will not move in reverse.
bent or broken reverse gear linkage, inside the trans.or broken sliding reverse gear.
Sep 09, 2010 | 1991 Honda Accord
My Bosch washing machine is leaving sludge like marks on my clothes. Ran the machine at 90 degrees with soap but no load. Didn't solve the problem. Any ideas?
Make sure the draw is 100% clean inside the draw compartment to if the draw is all clean next thing to cheak is the rubber door seal make sure it is clean all the way round next thing to cheak is the pump at the front of the machine pull down the cover and undo the the pump cover by tuning anti clock wise water will come out when you cheaked it is 100%clean put it back together if you get stuck read manual if all toughs things are clean or bean cleaned. do a 90 again with washer cleaning detergent with you can buy at the super market hope this helped.
Aug 26, 2009 | Bosch Classixx WFO 2466 Front Load Washer
I have no sound in my "compaq presario SR 1520 IL" computer
first u cheak the speaker connection on ur mother board.after u cheak the volume options I think u select the mute option cheak box.remove the rightmark on cheak box,Or disble the soubd option in BIOS settings.First ucheak the total options after reinstall the sound drivers.
Jul 18, 2009 | Compaq Creative Sound Blaster PCI 128...
Dryer gets to hot clothes still wet. Insulator piece covers coil flame retardant material broke loose started to char. where do we find a piece like that or does it sound like that is why our clothes
That piece you are thinking of is a flame retardant but is not the problem.To me it sounds like you have a plugged vent cheak outside when your dryer is running and cheak the air flow If not you may have a dead short on the element your element may be shorting on the housing.
May 18, 2009 | Frigidaire FDE436RE Dryer
No display
it may be the problem of your monitor.check it
Jan 11, 2009 | Intel Motherboard
Canon LaserClass 2050 Plain Paper Fax Logo
269 people viewed this question
old marine
old marine
