Question about Centrios Audio Players & Recorders
I have a Centrios 6311404 - time/date/etc data is wrong a
I have a Centrios 6311404 - a clock/date/month/temperature clock with a glass panel in it. I can't figure out how to reset it to the current date. Do you have a manual for me?
SOURCE: Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Posted on Jan 28, 2008
It's so simple. Go to http://www.centrios.com/ >Timekeepers >Support >Online Support >Centrios Manual> Category"Clocks" >Model"6316006/C864" >Manual"English" >Download.
Posted on Feb 16, 2008
SOURCE: buttons not working.....
In the battery compartment is a small button marked "reset". Push this in after the batteries are installed and the buttons should work. You will have to reset everything.
Posted on Jun 26, 2008
  • 5 Answers
SOURCE: reset cd clock radio? (manual missing)
Make sure the clock is in standby mode, as opposed to playback mode. Press time set button — the clock digits will blink. If they don't, you're in playback mode. Press the hour button to adjust the hour. Press the minute button to adjust the minute. Press time set button to confirm the time.
Posted on Feb 15, 2009
  • 16 Answers
SOURCE: Changing the date
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS to get a manual.
Posted on Feb 22, 2009
I have a centrios clock that has an alarm, tells the time and temperature. I need the manual for it
So you worked out you need to specify a make :-)
Try these instructions or post to this forum. If you provide a model number for the clock which should be underneath it or at the back, I will try to find the specific model. They seem to make a few models. Post as a comment to this posting rather than starting a new one. Thanks
http://mb.nawcc.org/showthread.php?107852-Centrios-Atomic-Clock-Instructions
Nov 04, 2015 | Centrios Televison & Video
Ipod got wrong time,date and data
Go into your settings, go to clock, change it to what is correct.
Jan 20, 2014 | Apple Audio Players & Recorders
How to set the time on Centrios atomic clock?
I had the same issue. This s a great clock radio, but not very intuitive. I've uploaded a PDF of the manual from my clock radio, I hope it is useful.
Nov 30, 2012 | Centrios Audio Players & Recorders
Needmanual for centrios clock 6311404
Try to Google the model number with "manual" or see if the maker has a website.
Nov 06, 2012 | Televison & Video
Digital settings
Buttons are: A or Adjust (10 o’clock position), B or Time Memo (2 o’clock), C or Mode (8 o’clock), D or Receive (4 o’clock) and L or Light (6 o’clock)
To manually change time, date, year, month and day, hold A until beep and city code appears; press A again until 12H/24H flashes; press C to cycle through options as hour, minutes, year, month, and day flash; use B or D to change flashing option.
Aug 03, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Centrios DVD Recorder
Setting the clock
1. Press SETUP in no disc mode or full stop mode,MENU screen
appears on the TV screen.
2. Using v select SETUP MENU, then press ENTER or >,
BASIC SETUP is highlighted.
3. Using v to select “Set Clock ”, then press ENTER or >,
“Set Clock Setup ”screen appears.
4. Press</>/^/v repeatedly (or numeric buttons) to set the
date and time.
5. Press > to select “Done”or“Cancel ”, and then press ENTER ,
BASIC SETUP returns.
6. To exit, press SETUP.
7. Press POWER to turn off the unit, the clock appears on
the VFD display.
link to manual http://www.centrios.com/content/support.aspx?language=en-CA#
Mar 03, 2008 | Centrios EDW8020 DVD Recorder
Manual Information/Owner Guide
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
FixerUpper
Feb 02, 2008 | SkyScan 86709 Atomic Wall Clock
Nov 08, 2007 | Audio Players & Recorders
Wrong date on the radio.
RESETTING THE CLOCK AFTER A TOTAL MEMORY LOSS
If you do not change the built in lithium battery within a reasonable period of time after you see the ‘flashing’ LOW BATT. warning indicator, the lithium battery may become exhausted and will no longer be able to supply back up power to the SmartSet internal computer.
If the unit is disconnected from the AC outlet after the battery is exhausted, or if a power interruption occurs, the SmartSet memory will be lost and the clock will need to be reset when the power is restored. Be sure to install a fresh lithium battery before you reset the clock, otherwise the clock will need to be reset each time the power is interrupted.
If the lithium battery is exhausted and you experience an interruption in the AC power supply, the clock will reset itself to its initial default setting when the power is restored.
The initial default setting is “12:00 AM, Saturday, January 1
(1 1), 2005”.
If you notice that the time on your SmartSet clock radio is completely incorrect, and the day indicator is also wrong, press the MONTH/DATE button to see the date. If the date display is showing “1 1” (January 1 ), you probably experienced
a total memory loss. To reset the clock after a total memory loss, proceed as follows:
1.) Install a new CR2430 lithium battery in the battery compartment.
2.) Connect the radio to your AC outlet and let the clock set itself.
3.) Depress the MONTH/DATE and TIME buttons together. The display will change from ‘time’ to ‘year’. While holding the MONTH/DATE and TIME buttons, press the UP button to
set the display to the correct year, then release the buttons.
4.) Depress the MONTH/DATE button. The display will change from ‘time’ to 'month/date’ (mm/dd). While holding the MONTH/DATE button, press the UP button to set the display
to the correct month and date. The Day indicator will change automatically as you adjust the month/date settings. When the correct month and date appear on the display, release the buttons.
5.) Depress the TIME button and the UP button to set the display to the correct time. Be sure to confirm that you have set the time correctly to ‘AM’ or ‘PM’ by observing the AM indicator.
6.) After you set the time, reconfirm that the Day, and Month/Date displays are still correct. Make final adjustments if necessary.
The SmartSet clock memory is now reset and the new lithium battery will maintain it for the next 5 to 8 years, depending on the number and duration of the power outages you experience.
IMPORTANT NOTE:
After resetting the clock, don’t forget to reset your wake up times, and alarm mode settings, and sleep timer settings as well.
Oct 22, 2007 | Emerson SmartSet CKS1850 Clock Radio
Want to set the clock
Each time you press the set button on the back it selects one of the items that you can set. For example if the "month" is selected by pressing the "set" button then press the "+" key to change it from 1->2->3->4 etc. Each time you press "+" key the month will go up by one. Stop when you reach the correct month. You can do the same for each item including the time zone and daylight savings time and whether you want your temperature to be in Celcius or Farenheit. Hope this helps...
FixerUpper
Sep 15, 2007 | SkyScan 86709 Atomic Wall Clock
93 people viewed this question
Top Centrios Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you a Centrios Audio Player and Recorder Expert? Answer questions, earn points and help others
